查看: 1290|回復: 0
51單片機按鍵控制舵機程序有問題 求幫助
ID:623569 發表于 2019-10-15 00:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我這也有個程序不好用 有大神幫忙看看問題出在哪了
#include <reg52.h>
#define Stop 0    //宏定義,停止
#define Left 1      //宏定義,左轉
#define Right 2      //宏定義,右轉
sbit ControlPort = P1^0;  //舵機信號端口
sbit KeyLeft = P1^1;      //左轉按鍵端口
sbit KeyRight = P1^2;      //右轉按鍵端口
sbit KeyStop = P1^3;      //歸位按鍵端口
unsigned char TimeOutCounter = 0,LeftOrRight = 0;  //TimeOutCounter:定時器溢出計數      LeftOrRight:舵機左右旋轉標志
void InitialTimer ( void )
    TMOD=0x10;   //定時/計數器1工作于方式1
    TH1 = ( 65535 - 500 ) / 256;      //0.25ms
    TL1 = ( 65535 - 500 ) % 256;
    EA=1;        //開總中斷
    ET1=1;       //允許定時/計數器1 中斷
    TR1=1;       //啟動定時/計數器1 中斷
void ControlLeftOrRight ( void )   //控制舵機函數
    if( KeyStop == 0 )
        while ( !KeyStop );       //使標志等于Stop(0),在中斷函數中將用到
        LeftOrRight = Stop;
    if( KeyLeft == 0 )
        while ( !KeyLeft );       //使標志等于Left(1),在中斷函數中將用到
        LeftOrRight = Left;
    if( KeyRight == 0 )
        while ( !KeyRight );   //使標志等于Right(2),在中斷函數中將用到
        LeftOrRight = Right;
void main ( void )     //主函數
    InitialTimer();
    for(;;)
        ControlLeftOrRight();
void Timer1 ( void ) interrupt 3  //定時器中斷函數
    TimeOutCounter ++;
    switch ( LeftOrRight )
        case 0 :      //為0時,舵機歸位,脈寬1.5ms
            if( TimeOutCounter <= 6 )
                ControlPort = 1;
                ControlPort = 0;
            break;
        case 1 :     //為1時,舵機左轉,脈寬1ms(理論值),實際可以調試得出
            if( TimeOutCounter <= 2 )
                ControlPort = 1;
                ControlPort = 0;
            break;
        case 2 :   //為2時,舵機右轉,脈寬2ms(理論值),實際可以調試得出
            if( TimeOutCounter <= 10 )
                ControlPort = 1;
                ControlPort = 0;
            break;
        default : break;
    if( TimeOutCounter == 80 )     //周期20ms(理論值),比較可靠,最好不要修改
        TimeOutCounter = 0;
