來了個大佬666
是這樣的程序的確不是完整的,我上面只發(fā)了有關(guān)AD轉(zhuǎn)換的部分,數(shù)碼管顯示部分我想著關(guān)系不大就省略沒發(fā)出來,那個阻值表是我用的NTC熱敏電阻的溫度—阻值對應(yīng)表,1到100度對應(yīng)的阻值,是問廠家那里拿的;p1口的狀態(tài)我改了高阻態(tài)但是還是不行;還有測溫的電路圖我不太會分析,AD轉(zhuǎn)換得到的Vout和Rt熱敏間的關(guān)系怎樣求,能麻煩大佬幫忙看下嗎 ,謝謝大佬回復(fù)
完整程序:
#include<reg51.h>
#include<intrins.h>
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define FOSC 11059200L
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr ADC_CONTR = 0xBC;
sfr ADC_RES = 0xBD;
sfr ADC_RESL = 0xBE;
sfr P1ASF = 0x9D;
sfr CLK_DIV = 0x97;
sbit STB = P3^3;
sbit CLK = P3^6;
sbit DIO = P3^7;
sbit KEY = P1^5;
#define ADC_POWER 0x80
#define ADC_FLAG 0x10
#define ADC_START 0x08
#define ADC_SPEED 0x60
WORD num;
float n;
uchar u = 1;
void display(uchar K);
void delay(WORD n);
uchar code Duanma[10]={0xfa,0x82,0xb9,0xab,0xc3,0x6b,0x7b,0xa2,0xfb,0xe3};
uchar code zhuzhi[101]={65.83,62.54,59.43,56.49,53.72,51.10,48.62,46.28,
44.06,41.96,39.97,38.09,36.31,34.63,33.03,31.51,
30.07,28.71,27.41,26.18,25.02,23.91,22.86,21.86,
20.90,20.00,19.14,18.32,17.54,16.80,16.10,15.42,
14.78,14.17,13.59,13.04,12.51,12.00,11.52,11.06,
10.62,10.20,9.80,9.42,9.05,8.70,8.37,8.05,7.74,
7.45,7.17,6.90,6.65,6.40,6.17,5.94,5.73,5.52,5.32,5.13,
4.95,4.77,4.61,4.45,4.29,4.14,4.00,3.86,3.73,3.61,
3.48,3.37,3.25,3.15,3.04,2.94,2.85,2.75,2.67,2.58,
2.50,2.42,2.34,2.27,2.20,2.13,2.06,2.00,1.94,1.88,
1.82,1.77,1.71,1.66,1.61,1.56,1.52,1.47,1.43,1.39,
1.35};
void send_8bit(uchar dat)
uchar i;
for(i=0;i<8;i++)
if(dat&0x01)
DIO = 1;
DIO = 0;
CLK = 0;
CLK = 1;
dat=dat>>1;
void command(uchar com)
STB = 1;
STB = 0;
send_8bit(com);
uchar ge,shi,bai;
ge = K%10;
shi = (K/10)%10;
bai = (K/100)%10;
command(0x03);
command(0x40);
command(0xc6);
send_8bit(Duanma[bai]);
send_8bit(0x00);
send_8bit(0x00);
send_8bit(0x00);
send_8bit(Duanma[shi]);
send_8bit(0x00);
send_8bit(Duanma[ge]);
send_8bit(0x00);
command(0x8f);
STB = 1;
void init_ADC()
P1ASF = 0x06;
delay(2);
ADC_RES = 0;
ADC_RESL = 0;
void resetADC(BYTE ch)
ADC_RES = 0;
ADC_RESL = 0;
ADC_CONTR = ADC_SPEED | ADC_START | ADC_POWER | ch;
void delay(WORD n)
uint x;
while(n--)
x = 500;
while(x--);
void get_result()
while (!(ADC_CONTR & ADC_FLAG));
ADC_CONTR &= ~ADC_FLAG;
num = (ADC_RES<<2)|ADC_RESL;
WORD lvbo()
WORD count;
uchar i = 0;
for(i = 0;i<32;i++)
resetADC(u);
delay(2);
get_result();
count += num;
count = count>>5;
return count;
void chselect()
if(KEY == 0)
delay(5);
if(KEY == 0)
while(KEY == 0);
if(2<++u) u = 1;
void data_change()
WORD i;
i = lvbo();
n = i/(55-0.05*i);
void cha_biao()
uint low,high,middle;
low = 0;
high = 100;
middle = (high + low)/2;
if((n<=zhuzhi[low])&&(zhuzhi[high]<=n))
while((high - low) != 1)
if(n < zhuzhi[middle])
low = middle+1;
else if(zhuzhi[middle] < n)
high = middle-1;
if(n == zhuzhi[middle])
display(middle);
return;
if((zhuzhi[low]-n)<(n-zhuzhi[high]))
display(low);
return;
if((n-zhuzhi[high])<(zhuzhi[low]-n))
display(high);
return;
if(n<zhuzhi[high])
display(high);
return;
if(zhuzhi[low]<n)
display(low);
return;
P1M1 = 0x06;
P1M0 = 0x00;
KEY = 1;
init_ADC();
chselect();
lvbo();
resetADC(u);
delay(2);
get_result();
data_change();
cha_biao();
delay(6);
}C:\Users\Administrator\Desktop\01 |
