2019-10-13 17:41 上傳
2019-10-13 17:41 上傳
2019-10-13 17:41 上傳
- //包含頭文件
- #include <REG51.h>
- #include<intrins.h>
- //宏定義
- #define LCM_Data P0 //將P0口定義為LCM_Data
- #define uchar unsigned char
- #define uint unsigned int
- //1602的控制腳
- sbit lcd1602_rs=P2^5;
- sbit lcd1602_rw=P2^6;
- sbit lcd1602_en=P2^7;
- sbit rs= P2^5;
- sbit en = P2^7;
- sbit rw = P2^6;
- sbit busy=P0^7;//LCD1602顯示漢字的管腳
- sbit Scl=P3^4; //24C02串行時鐘
- sbit Sda=P3^5; //24C02串行數據
- sbit ALAM = P2^1; //報警
- sbit KEY = P3^6; //開鎖
- bit pass=0; //密碼正確標志
- bit ReInputEn=0; //重置輸入允許標志
- bit s3_keydown=0; //3秒按鍵標志位
- bit key_disable=0; //鎖定鍵盤標志
- unsigned char countt0,second; //t0中斷計數器,秒計數器
- void Delay5Ms(void); //聲明延時函數
- unsigned char code a[]={0xFE,0xFD,0xFB,0xF7}; //控盤掃描控制表
- //液晶顯示數據數組
- unsigned char dui[] = {0x0,0x0,0x1A,0xA,0x1A,0x12,0x12,0x15}; //隊的字符表
- unsigned char dian[]={0x4,0x1F,0x15,0x1F,0x15,0x1F,0x4,0x7}; //大的字符表 //月的字符表
- unsigned char lan[] ={0xA,0x1B,0xA,0xC,0x1F,0x1A,0xE,0x1F}; //藍的字符表
- unsigned char da[] ={0x0,0x4,0x4,0x1F,0x4,0xA,0x11,0x0};//大的字符表
- unsigned char code start_line[] = {"password: "};
- unsigned char code name[] = {"== =="}; //顯示名稱
- unsigned char code Correct[] = {" correct "}; //輸入正確
- unsigned char code Error[] = {" error "}; //輸入錯誤
- unsigned char code codepass[] = {" pass "};
- unsigned char code LockOpen[] = {" open "}; //OPEN
- unsigned char code SetNew[] = {"SetNewWordEnable"};
- unsigned char code Input[] = {"input: "}; //INPUT
- unsigned char code ResetOK[] = {"ResetPasswordOK "};
- unsigned char code initword[] = {"Init password..."};
- unsigned char code Er_try[] = {"error,try again!"};
- unsigned char code again[] = {"input again "};
- unsigned char InputData[6]; //輸入密碼暫存區
- unsigned char CurrentPassword[6]={0,0,0,0,0,0}; //讀取EEPROM密碼暫存數組
- unsigned char TempPassword[6];
- unsigned char N=0; //密碼輸入位數記數
- unsigned char ErrorCont; //錯誤次數計數
- unsigned char CorrectCont; //正確輸入計數
- unsigned char ReInputCont; //重新輸入計數
- unsigned char code initpassword[6]={0,0,0,0,0,0}; //輸入管理員密碼后將密碼初始為000000
- unsigned char code adminpassword[6]={2,0,1,9,0,1}; //輸入管理員密碼后將密碼初始為000000
- //函數功能:LCD延時子程序
- //入口參數:ms
- //出口參數:
- void DelayUs2x(unsigned char t)
- while(--t);
- void DelayMs(unsigned char t)
- while(t--)
- //大致延時1mS
- DelayUs2x(245);
- DelayUs2x(245);
- 函數功能:測試LCD忙碌狀態
- 入口參數:
- 出口參數:busy_flag
- bit lcd_check_busy()
- P0=0Xff;
- rs = 0;
- rw = 1;
- en = 0;
- _nop_();
- en=1;
- return busy;
- 函數功能:寫指令數據到LCD子程序
- 入口參數:cmd
- 出口參數:
- void lcd_wcmd(unsigned char cmd)
- while(lcd_check_busy()); //判斷LCD是否忙碌
- rs = 0;
- rw = 0;
- en = 1;
- P0 = cmd;
- _nop_();
- en = 0;
- 函數功能:設定顯示位置子程序
- 入口參數:pos
- 出口參數:
- void lcd_pos(unsigned char pos)
- lcd_wcmd(pos | 0x80);
- 函數功能:寫入顯示數據到LCD子程序
- 入口參數:dat
- 出口參數:
- void lcd_wdat(unsigned char dat)
- rs = 1;
- rw = 0;
- en = 1;
- P0 = dat;
- _nop_();
- en = 0;
- 函數功能:LCD初始化子程序
- 入口參數:
- 出口參數:
- void lcd_init1()
- lcd_wcmd(0x38);
- DelayMs(5);
- lcd_wcmd(0x38);
- DelayMs(5);
- lcd_wcmd(0x38);
- DelayMs(5);
- lcd_wcmd(0x38); //8位數據,雙行顯示,5*7點陣
- lcd_wcmd(0x08); //顯示關閉,無光標,光標不顯示
- lcd_wcmd(0x01); //清顯示
- lcd_wcmd(0x06); //光標右移
- DelayMs(5);
- lcd_wcmd(0x0c); //開顯示,有光標,光標閃爍
- 函數功能:建立藍電大隊字符
- 入口參數:
- 出口參數:
- void lcd_setups()
- {unsigned int i;
- lcd_wcmd(0x40);
- for(i=0;i<8;i++)
- lcd_wdat(lan[i]);
- lcd_wcmd(0x48);
- for(i=0;i<8;i++)
- {lcd_wdat(dian[i]);
- lcd_wcmd(0x50);
- for(i=0;i<8;i++)
- {lcd_wdat(da[i]);
- lcd_wcmd(0x58);
- for(i=0;i<8;i++)
- {lcd_wdat(dui[i]);
- //LCD1602顯示漢字子程序
- //=====================5ms延時==============================
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- //===================400ms延時==============================
- void Delay400Ms(void)
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- //================================24C02========================================================
- void mDelay(uint t) //延時
- uchar i;
- while(t--)
- for(i=0;i<125;i++)
- void Nop(void) //空操作
- _nop_(); //僅作延時用一條語句大約1us
- _nop_();
- _nop_();
- _nop_();
- /*****24c02程序參照24c02時序圖*****/
- /*起始條件*/
- void Start(void)
- Sda=1;
- Scl=1;
- Nop();
- Sda=0;
- Nop();
- /*停止條件*/
- void Stop(void)
- Sda=0;
- Scl=1;
- Nop();
- Sda=1;
- Nop();
- /*應答位*/
- void Ack(void)
- Sda=0;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- /*反向應答位*/
- void NoAck(void)
- Sda=1;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- /*發送數據子程序,Data為要求發送的數據*/
- void Send(uchar Data)
- uchar BitCounter=8;
- uchar temp;
- do
- temp=Data; //將待發送數據暫存temp
- Scl=0;
- Nop();
- if((temp&0x80)==0x80) //將讀到的數據&0x80
- Sda=1;
- else
- Sda=0;
- Scl=1;
- temp=Data<<1; //數據左移
- Data=temp; //數據左移后重新賦值Data
- BitCounter--; //該變量減到0時,數據也就傳送完成了
- while(BitCounter); //判斷是否傳送完成
- Scl=0;
- /*讀一字節的數據,并返回該字節值*/
- uchar Read(void)
- uchar temp=0;
- uchar temp1=0;
- Sda=1;
- do
- Scl=0;
- Nop();
- Scl=1;
- Nop();
- if(Sda) //數據位是否為1
- temp=temp|0x01; //為1 temp的最低位為1(|0x01,就是將最低位變為1)
- else //如果為0
- temp=temp&0xfe; //temp最低位為0(&0xfe(11111110)最低位就是0)
- if(BitCounter-1) //BitCounter減1后是否為真
- temp1=temp<<1; //temp左移
- temp=temp1;
- BitCounter--; //BitCounter減到0時,數據就接收完了
- while(BitCounter); //判斷是否接收完成
- return(temp);
- void WrToROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- for(i=0;i<Num;i++)
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Send(*(PData+i));
- Ack();
- Stop();
- mDelay(20);
- void RdFromROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Start();
- Send(0xa1);
- Ack();
- *(PData+i)=Read();
- Scl=0;
- NoAck();
- Stop();
- //=======================================LCD1602====================================================
- #define yi 0x80 //LCD第一行的初始位置,因為LCD1602字符地址首位D7恒定為1(100000000=80)
- #define er 0x80+0x40 //LCD第二行初始位置(因為第二行第一個字符位置地址是0x40)
- //----------------延時函數,后面經常調用----------------------
- void delay(uint xms)//延時函數,有參函數
- uint x,y;
- for(x=xms;x>0;x--)
- for(y=110;y>0;y--);
- //--------------------------寫指令---------------------------
- void write_1602com(uchar com)//****液晶寫入指令函數****
- lcd1602_rs=0;//數據/指令選擇置為指令
- lcd1602_rw=0; //讀寫選擇置為寫
- P0=com;//送入數據
- delay(1);
- lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準備
- delay(1);
- lcd1602_en=0;//en由高變低,產生下降沿,液晶執行命令
- //-------------------------寫數據-----------------------------
- void write_1602dat(uchar dat)//***液晶寫入數據函數****
- lcd1602_rs=1;//數據/指令選擇置為數據
- P0=dat;//送入數據
- delay(1);
- lcd1602_en=1; //en置高電平,為制造下降沿做準備
- delay(1);
- lcd1602_en=0; //en由高變低,產生下降沿,液晶執行命令
- //-------------------------初始化-------------------------
- void lcd_init(void)
- write_1602com(0x38);//設置液晶工作模式,意思:16*2行顯示,5*7點陣,8位數據
- write_1602com(0x0c);//開顯示不顯示光標
- write_1602com(0x06);//整屏不移動,光標自動右移
- write_1602com(0x01);//清顯示
- //==============將按鍵值編碼為數值=========================
- unsigned char coding(unsigned char m)
- unsigned char k;
- switch(m)
- case (0x11): k=1;break;
- case (0x21): k=2;break;
- case (0x41): k=3;break;
- case (0x81): k='A';break;
- case (0x12): k=4;break;
- case (0x22): k=5;break;
- case (0x42): k=6;break;
- case (0x82): k='B';break;
- case (0x14): k=7;break;
- case (0x24): k=8;break;
- case (0x44): k=9;break;
- case (0x84): k='C';break;
- case (0x18): k='*';break;
- case (0x28): k=0;break;
- case (0x48): k='#';break;
- case (0x88): k='D';break;
- return(k);
- //=====================按鍵檢測并返回按鍵值===============================
- unsigned char keynum(void)
- unsigned char row,col,i;
- P1=0xf0;
- if((P1&0xf0)!=0xf0)
- Delay5Ms();
- Delay5Ms();
- row=P1^0xf0; //確定行線
- i=0;
- P1=a[i]; //精確定位
- while(i<4)
- col=~(P1&0xff); //確定列線
- break; //已定位后提前退出
- else
- i++;
- P1=a[i];
- else
- return 0;
- while((P1&0xf0)!=0xf0);
- return (row|col); //行線與列線組合后返回
- else return 0; //無鍵按下時返回0
- //=======================一聲提示音,表示有效輸入========================
- void OneAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //========================二聲提示音,表示操作成功========================
- void TwoAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //========================三聲提示音,表示錯誤========================
- void ThreeAlam(void)
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //=======================顯示提示輸入=========================
- void DisplayChar(void)
- unsigned char i;
- if(pass==1)
- //DisplayListChar(0,1,LockOpen);
- write_1602com(er); //在二行開始顯示
- for(i=0;i<16;i++)
- write_1602dat(LockOpen[i]); //顯示open 開鎖成功
- else
- if(N==0)
- //DisplayListChar(0,1,Error);
- for(i=0;i<16;i++)
- write_1602dat(Error[i]); //顯示錯誤
- else
- //DisplayListChar(0,1,start_line);
- for(i=0;i<16;i++)
- write_1602dat(start_line[i]);//顯示開始輸入
- //========================重置密碼==================================================
- void ResetPassword(void)
- unsigned char i;
- unsigned char j;
- if(pass==0)
- pass=0;
- DisplayChar(); //顯示錯誤
- ThreeAlam(); //沒開鎖時按下重置密碼報警3聲
- else //開鎖狀態下才能進行密碼重置程序
- if(ReInputEn==1) //開鎖狀態下,ReInputEn置1,重置密碼允許
- if(N==6) //輸入6位密碼
- ReInputCont++; //密碼次數計數
- if(ReInputCont==2) //輸入兩次密碼
- for(i=0;i<6;)
- if(TempPassword[i]==InputData[i]) //將兩次輸入的新密碼作對比
- i++;
- else //如果兩次的密碼不同
- for(j=0;j<16;j++)
- write_1602dat(Error[j]); //顯示錯誤Error
- ThreeAlam(); //錯誤提示
- pass=0; //關鎖
- ReInputEn=0; //關閉重置功能,
- ReInputCont=0;
- DisplayChar();
- break;
- if(i==6)
- //DisplayListChar(0,1,ResetOK);
- for(j=0;j<16;j++)
- write_1602dat(ResetOK[j]); //密碼修改成功,顯示
- TwoAlam(); //操作成功提示
- WrToROM(TempPassword,0,6); //將新密碼寫入24C02存儲
- ReInputEn=0;
- ReInputCont=0;
- CorrectCont=0;
- else //輸入一次密碼時
- OneAlam();
- //DisplayListChar(0, 1, again); //顯示再次輸入一次
- for(j=0;j<16;j++)
- write_1602dat(again[j]); //顯示再輸入一次
- for(i=0;i<6;i++)
- TempPassword[i]=InputData[i]; //將第一次輸入的數據暫存起來
- N=0; //輸入數據位數計數器清零
- //=======================輸入密碼錯誤超過三過,報警并鎖死鍵盤======================
- void Alam_KeyUnable(void)
- P1=0x00;
- ALAM=~ALAM; //蜂鳴器一直閃爍鳴響
- Delay5Ms();
- //=======================取消所有操作============================================
- void Cancel(void)
- unsigned char i;
- unsigned char j;
- //DisplayListChar(0, 1, start_line);
- for(j=0;j<16;j++)
- write_1602dat(start_line[j]); //顯示開機輸入密碼界面
- TwoAlam(); //提示音
- for(i=0;i<6;i++)
- InputData[i]=0; //將輸入密碼清零
- KEY=1; //關閉鎖
- ALAM=1; //報警關
- pass=0; //密碼正確標志清零
- ReInputEn=0; //重置輸入充許標志清零
- ErrorCont=0; //密碼錯誤輸入次數清零
- CorrectCont=0; //密碼正確輸入次數清零
- ReInputCont=0; //重置密碼輸入次數清零
- s3_keydown=0;
- key_disable=0; //鎖定鍵盤標志清零
- N=0; //輸入位數計數器清零
- //==========================確認鍵,并通過相應標志位執行相應功能===============================
- void Ensure(void)
- unsigned char i,j;
- RdFromROM(CurrentPassword,0,6); //從24C02里讀出存儲密碼
- if(N==6)
- if(ReInputEn==0) //重置密碼功能未開啟
- for(i=0;i<6;)
- if(CurrentPassword[i]==InputData[i]) //判斷輸入密碼和24c02中的密碼是否相同
- i++; //相同一位 i就+1
- else //如果有密碼不同
- ErrorCont++; //錯誤次數++
- if(ErrorCont==3) //錯誤輸入計數達三次時,報警并鎖定鍵盤
- for(i=0;i<16;i++)
- do
- Alam_KeyUnable();
- while(1);
- else //錯誤次數小于3次時,鎖死鍵盤3秒,然后重新可以輸入
- TR0=1; //開啟定時
- key_disable=1; //鎖定鍵盤
- pass=0; //pass位清零
- break; //跳出
- if(i==6) //密碼輸入對時
- if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
- WrToROM(initpassword,0,6); //強制將初始密碼寫入24C02存儲
- for(j=0;j<16;j++)
- write_1602dat(initword[j]); //顯示初始化密碼
- TwoAlam(); //成功提示音
- Delay400Ms(); //延時400ms
- N=0; //輸入位數計數器清零
- else
- CorrectCont++; //輸入正確變量++
- if(CorrectCont==1) //正確輸入計數,當只有一次正確輸入時,開鎖
- for(j=0;j<16;j++)
- write_1602dat(LockOpen[j]); //顯示open開鎖畫面
- TwoAlam(); //操作成功提示音
- KEY=0; //開鎖
- pass=1; //置正確標志位
- TR0=1; //開啟定時
- for(j=0;j<6;j++) //將輸入清除
- InputData[i]=0; //開鎖后將輸入位清零
- else //當兩次正確輸入時,開啟重置密碼功能
- for(j=0;j<16;j++)
- write_1602dat(SetNew[j]); //顯示重置密碼界面
- ReInputEn=1; //允許重置密碼輸入
- CorrectCont=0; //正確計數器清零
- else //=========================當第一次使用或忘記密碼時可以用131420對其密碼初始化============
- for(j=0;j<16;j++)
- N=0; //輸入位數計數器清零
- else //密碼輸入錯誤
- for(j=0;j<16;j++)
- write_1602dat(Error[j]); //顯示錯誤信息
- ThreeAlam(); //錯誤提示音
- pass=0;
- else //當已經開啟重置密碼功能時,而按下開鎖鍵,
- //DisplayListChar(0,1,Er_try);
- for(j=0;j<16;j++)
- write_1602dat(Er_try[j]); //錯誤,請重新輸入
- else //密碼沒有輸入到6位時,按下確認鍵時
- for(j=0;j<16;j++)
- pass=0;
- N=0; //將輸入數據計數器清零,為下一次輸入作準備
- //==============================主函數===============================
- void main(void)
- unsigned char KEY,NUM;
- P1=0xFF; //P1口復位
- TMOD=0x11; //定義工作方式
- TL0=0xB0;
- TH0=0x3C; //定時器賦初值
- EA=1; //打開中斷總開關
- ET0=1; //打開中斷允許開關
- TR0=0; //打開定時器開關
- Delay400Ms(); //啟動等待,等LCM講入工作狀態
- lcd_init(); //LCD初始化
- write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
- lcd_setups(); //建立字符
- for(i=0;i<16;i++)
- write_1602dat(name[i]);//向液晶屏寫開機畫面
- for(i=0;i<16;i++)
- write_1602dat(start_line[i]);//寫輸入密碼等待界面
- write_1602com(er+9); //設置光標位置
- write_1602com(0x0f); //設置光標為閃爍
- Delay5Ms(); //延時片刻(可不要)
- N=0; //初始化數據輸入位數
- lcd_pos(0x04); //起始列位置 //顯示藍
- lcd_wdat(0x00);
- lcd_pos(0x06);//終止列位置
- lcd_pos(0x06); //顯示電
- lcd_wdat(0x01);
- lcd_pos(0x08);
- lcd_pos(0x08); //顯示大
- lcd_wdat(0x02);
- lcd_pos(0x010);
- lcd_pos(0x0a); //顯示隊
- lcd_wdat(0x03);
- lcd_pos(0x0b);
- while(1) //進入循環
- if(key_disable==1) //鎖定鍵盤標志為1時
- Alam_KeyUnable(); //報警鍵盤鎖
- else
- ALAM=1; //關報警
- KEY=keynum(); //讀按鍵的位置碼
- if(KEY!=0) //當有按鍵按下時
- second=0; //秒清零
- else //沒有鎖定鍵盤時
- NUM=coding(KEY); //根據按鍵的位置將其編碼,編碼值賦值給NUM
- switch(NUM) //判斷按鍵值
- case ('A'): ; break;
- case ('B'): ; break;
- case ('C'):
- for(i=0;i<16;i++)
- if(N>=1) N--; OneAlam(); //按鍵提示音
- //DisplayOneChar(6+N,1,'*');
- for(j=N;j<16;j++)
- write_1602com(er+6+j);
- write_1602dat(' ');
- for(j=0;j<N;j++)
- write_1602com(er+6+j); //顯示位數隨輸入增加而增加
- write_1602dat('*'); //但不顯示實際數字,用*代替
- InputData[N]=N+4;
- break; //ABC是無定義按鍵
- case ('D'): ResetPassword(); break; //重新設置密碼
- case ('*'): Cancel(); break; //取消當前輸入
- case ('#'): Ensure(); break; //確認鍵,
- default: //如果不是功能鍵按下時,就是數字鍵按下
- //DisplayListChar(0,1,Input);
- if(N<6) //當輸入的密碼少于6位時,接受輸入并保存,大于6位時則無效。
- for(i=0;i<16;i++)
- write_1602dat(Input[i]); //顯示輸入畫面
- OneAlam(); //按鍵提示音
- for(j=0;j<=N;j++)
- InputData[N]=NUM; //將數字鍵的碼賦值給InputData[]數組暫存
- N++; //密碼位數加
- else //輸入數據位數大于6后,忽略輸入
- N=6; //密碼輸入大于6位時,不接受輸入
- break;
- //*********************************中斷服務函數**************************************
- void time0_int(void) interrupt 1 //定時器T0
- TL0=0xB0;
- TH0=0x3C; //定時器重新賦初值
- //TR0=1;
- countt0++; //計時變量加,加1次時50ms
- if(countt0==20) //加到20次就是1s
- countt0=0; //變量清零
- second++; //秒加
- if(pass==1) //開鎖狀態時
- if(second==1) //秒加到1s時
- TR0=0; //關定時器
- TL0=0xB0;
- TH0=0x3C; //再次賦初值
- second=0; //秒清零
- else //不在開鎖狀態時
- if(second==3) //秒加到3時
- TR0=0; //關閉定時器
- second=0; //秒清零
- key_disable=0; //鎖定鍵盤清零
- s3_keydown=0;
- TL0=0xB0;
- TH0=0x3C; //重新賦初值
- else
- TR0=1; //打開定時器
11-視頻講解.rar
(9.03 MB, 下載次數: 71)
2019-10-12 14:58 上傳
下載積分: 黑幣 -5
密碼鎖2.rar
(66.48 KB, 下載次數: 104)
2019-10-12 14:58 上傳
下載積分: 黑幣 -5
密碼鎖硬件圖.7z
(2.07 MB, 下載次數: 100)
2019-10-13 17:43 上傳
下載積分: 黑幣 -5
