查看: 1780|回復: 3
單片機藍牙小車的程序,中斷PWM與串口中斷在一起出錯
已經做了快2周了。差程序。一個中斷PWM,一個串口中斷。兩個在一起不會寫。。。前后是通過一個電機驅動,左右是通過舵機控制。,寫的程序問題好多。希望有大神指點迷津~~~
#include<reg52.h>
sbit pwm = P0^0;
sbit E1 = P2^0;
sbit E2 = P2^1;
sbit jia =P2^2;
sbit jan =P2^3;
unsigned char jd = 3;
unsigned char count;
void UART_int(unsigned char baud);
void Timer_int0();
void Init()
  E1 = 0;
  E2 = 0;
  jd = 4;
  count = 0;
void QJ()
  E1 = 1;
  E2 = 0;
void HT()
  E1 = 0;
  E2 = 1;
void TZ()
  E1 = 0;
  E2 = 0;
void ZUO()
    count = 0;
      jd = 4;
void YOU()
    count = 0;
      jd = 2;
void ZHONG()
  count = 0;
  jd=3;
  Init();
  Timer_int0();
   UART_int(9600);
      switch(SBUF)
      case 'Q': QJ();   break;
      case 'H': HT();   break;
      case 'K': TZ();   break;
      case 'Z': ZUO();  break;
      case 'Y': YOU();  break;
      case 'T': ZHONG();break;
  SCON = 0x50;
  TMOD |= 0x21;
  TH1 = 256 - (11059200/12/32)/baud;
  TL1 = TH1;
  ET1 = 0;
  ES  = 1;
  TR1 = 1;
  EA  = 1;
void Timer_int0()
    TR0 =0;
    TH0 = 0xFE;
    TL0 = 0x33;
    ET0 = 1;
    TR0 = 1;
void InterruptTimer1() interrupt 4
  if(RI)
    RI = 0;
void InterruptTime0() interrupt 1
  TH0 = 0xFE;
  TL0 = 0x33;
  if(count<jd)
      pwm = 1;
      pwm =  0;
  count = (count+1);
  count = count%40;
ID:621199 發表于 2019-10-20 15:40 | 只看該作者
這個問題還沒解決,,希望大佬們指點迷津!~~~
ID:213173 發表于 2019-10-20 20:39 | 只看該作者
學子喲 發表于 2019-10-20 15:40
void UART_int(unsigned char baud)   baud的數據范圍0~255,溢出部分無效,只剩128。
應改為void UART_int(unsigned int baud)
這樣改更好
void UART_int()
  SCON=0x50;
  TMOD|=0X21;
  TH1=TL1=-(11059200L/12/32/9600);
  ET1 = 0;
  ES  = 1;
  TR1 = 1;
  EA  = 1;
ID:621199 發表于 2019-10-21 21:28 | 只看該作者
wulin 發表于 2019-10-20 20:39
應改為void UART_ ...
嗯,我試了。但是舵機依舊不能轉動。是什么原因呢,望大佬解惑~
