查看: 1895|回復(fù): 1
更新安卓客戶端控制
ID:564334 發(fā)表于 2019-10-10 14:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這個是主程序
package
com.example.a123.myapplication;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.Toast;
import java.io.IOException;
import java.io.PrintStream;
import java.net.Socket;
public class MainActivity extends AppCompatActivity implements View.OnClickListener {
    private EditText mIp;   //  IP
private EditText mPort;     //  端口號
private String mStrIp;      //  字符串類型ip
private int miPort;    //  字符類型端口
private Button mBtnConnect; //  連接
private Socket mSocket;     //  套接字
private PrintStream out;    //  打印輸出流
private ConnectThread mConnectThread;   //  TCP連接線程
private Button mMotorZ;      //  按鈕LED燈開
private Button mMoyorF;     //  按鈕LED燈關(guān)
@Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        mBtnConnect=(Button)findViewById(R.id.mBt1);
        mMotorZ=(Button)findViewById(R.id.mBt2);
        mMoyorF=(Button)findViewById(R.id.mBt3);
        mIp=(EditText)findViewById(R.id.mEtIP);
        mPort=(EditText)findViewById(R.id.mEtPort);
        mBtnConnect.setOnClickListener(this);
        mMotorZ.setOnClickListener(this);
        mMoyorF.setOnClickListener(this);
    @Override
    public void onClick(View v) {
        switch(v.getId()){
            case R.id.mBt1:
                if( mSocket == null || ! mSocket.isConnected()) {
                    mStrIp = mIp.getText().toString();
                    miPort = Integer.valueOf(mPort.getText().toString());
                    mConnectThread = new ConnectThread(mStrIp, miPort);
                    mConnectThread.start();
                    if(mSocket != null && mSocket.isConnected()){
                        try {
                            mSocket.close();
                            mSocket=null;   //  清空mSocket
mBtnConnect.setText("連接");
                            Toast.makeText(MainActivity.this,"連接已關(guān)閉", Toast.LENGTH_LONG).show();
                        } catch (IOException e) {
                            e.printStackTrace();
                          break;
                    case R.id.mBt2:
                        if(out!=null){
                            out.print("0");
                            out.flush();
                        break;
                        case R.id.mBt3:
                          if (out!=null){
                         out.print("1");
                         out.flush();
                             break;
    private class ConnectThread extends Thread{
        private String ip;
        private int port;
        public ConnectThread(String ip,int port){
            this.ip=ip;
            this.port=port;
        @Override
        public void run() {
            try {
                mSocket=new Socket(ip,port);
                out = new PrintStream(mSocket.getOutputStream());
                runOnUiThread(new Runnable(){
                    @Override
                    public void run() {
                        mBtnConnect.setText("斷開");
                        Toast.makeText(MainActivity.this,"連接成功",Toast.LENGTH_LONG).show();
                @Override
                public void run() {
                        Toast.makeText(MainActivity.this,"連接失敗",Toast.LENGTH_LONG).show();
以下是AndroidManifest.xml文件的配置
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    package="com.example.a123.myapplication">
添加以下的才能與esp8266通信
<uses-permission android:name="android.permission.INTERNET"></uses-permission>
    <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE"></uses-permission>
    <uses-permission android:name="android.permission.READ_EXTERNAL_STORAGE"></uses-permission>
以下是界面的一些程序
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
android:layout_width="match_parent"
android:layout_height="match_parent"
android:orientation="vertical"
tools:context=".MainActivity"
tools:ignore="Deprecated">
    <TextView
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:layout_x="9dp"
android:layout_y="24dp"
android:text="服務(wù)器IP:"
android:textSize="20dp"
tools:ignore="HardcodedText,MissingConstraints,ObsoleteLayoutParam,SpUsage" />
    <EditText
android:id="@+id/mEtIP"
android:layout_x="112dp"
android:layout_y="20dp"
android:ems="10"
android:inputType="textPersonName"
android:text="192.168.4.1"
tools:ignore="HardcodedText,LabelFor,ObsoleteLayoutParam" />
    <TextView
android:layout_x="36dp"
android:layout_y="86dp"
android:text="端口:"
    <EditText
android:id="@+id/mEtPort"
android:layout_x="113dp"
android:layout_y="66dp"
android:ems="10"
android:text="8089"
    <Button
android:id="@+id/mBt1"
android:layout_height="59dp"
android:layout_x="155dp"
android:layout_y="173dp"
android:text=""
tools:ignore="HardcodedText,ObsoleteLayoutParam"
tools:layout_editor_absoluteX="144dp"
tools:layout_editor_absoluteY="163dp" />
    <Button
android:id="@+id/mBt2"
android:layout_height="69dp"
android:text="開"
tools:ignore="HardcodedText" />
    <Button
android:id="@+id/mBt3"
android:layout_height="72dp"
android:text="關(guān)"
</LinearLayout>
ID:1 發(fā)表于 2019-10-10 22:33 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
