這是做的數碼管我做了一個下午時間
里面有單片機的源代碼
keil做的程序
有proteus做的仿真
2019-10-10 01:21 上傳
- #include<reg51.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define SEG P0
- sbit PB1=P2^0;
- sbit PB2=P2^2;
- uchar TAB[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x83,0xf8,0x80,0x98};
- uchar TAB1[]={0x90,0xf8,0x90,0x92,0xa4,0xc0,0xf9,0xb0,0xf9,0x99};
- uchar TAB2[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
- void delay_1ms(uint t)
- uint k;
- while(--t)
- for(k=0;k<600;k++);
- main()
- unsigned char i;
- for(i=0;i<10;i++)
- SEG=TAB[i];
- delay_1ms(500);
- if(PB1==0)
- for(i=0;i<10;i++)
- SEG=0xff;
- delay_1ms(800);
- SEG=TAB1[i];
- delay_1ms(800);
- if(PB2==0)
- for(i=0;i<12;i++)
- SEG=TAB2[i];
- delay_1ms(200);
數碼管1.zip
(346.4 KB, 下載次數: 3)
2019-10-9 17:11 上傳
下載積分: 黑幣 -5
