十位個(gè)位分開,如下錯(cuò)誤
2019-10-10 01:29 上傳
單片機(jī)源程序如下:
- #include<reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- uchar code table[]={0xc0,0xf9,0xa4, 0xb0,0x99,
- 0x92,0x82,0xf8,0x80,0x90};
- sbit gew=P2^1;
- sbit shiw=P2^0;
- sbit k2=P1^0;
- uchar num,num1=60,num2,shi,ge;
- void Init() //初始化子函數(shù)
- TMOD=0X01; //設(shè)定定時(shí)器0的工作方式為1
- TH0=(65536-50000)/256; //定時(shí)器裝初值一個(gè)周期50ms
- TL0=(65536-50000)%256;
- EA=1; //開總中斷
- ET0=1; //開定時(shí)器0中斷
- TR0=1; //啟動(dòng)定時(shí)器0
- void delay(uint xms) //延時(shí)子函數(shù)
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- void scankey() //鍵盤檢測子函數(shù)
- if(k2==0) //檢測鍵是否被按下
- delay(5); //延時(shí)消除抖動(dòng)
- if(k2==0) //重新讀取k2的值
- num2++; //num2為按次數(shù)標(biāo)志位
- while(!k2); //等待按鍵釋放
- if(num2==1) //按鍵一次計(jì)時(shí)停止
- TR0=0;
- if(num2==2) //按鍵兩次計(jì)時(shí)開始
- TR0=1;
- void main() //主函數(shù)
- Init(); //初始化子函數(shù)調(diào)用
- while(1)
- scankey(); //不斷鍵盤掃描
- gew=1; //打開數(shù)碼管個(gè)位位選
- P0=table[ge]; //數(shù)碼管個(gè)位賦值
- delay(1); //延時(shí) 送入數(shù)據(jù)的反應(yīng)時(shí)間
- gew=0; //關(guān)閉數(shù)碼管個(gè)位位選
- delay(1);
- shiw=1; //打開數(shù)碼管十位位選
- P0=table[shi]; //送入數(shù)據(jù)
- delay(1);
- shiw=0; //關(guān)閉數(shù)碼管十位位選
- delay(1);
- void Timer0()interrupt 1
- TH0=(65536-50000)/256; //定時(shí)器重裝初值
- num++;
- if(num==20) //定時(shí)器每進(jìn)行一個(gè)周期num加1,運(yùn)行20個(gè)周期即為1s
- num=0; //到1秒,num清0重新開始
- num1--; //倒計(jì)時(shí)1秒
- if(num1==0)
- num1=60;
- shi=num1/10; //兩位數(shù)分離賦給數(shù)碼管十位顯示
- ge=num1%10; //兩位數(shù)分離賦給數(shù)碼管個(gè)位顯示
復(fù)制代碼- ORG 0000H
- AJMP MAIN
- ORG 0030H
- MAIN: MOV R2,#60
- LOOP1: MOV A,R2
- MOV B,#10
- DIV AB
- MOV DPTR,#TABLE
- MOVC A,@A+DPTR
- MOV P1,A
- MOV A,B
- MOV DPTR,#TABLE1
- MOVC A,@A+DPTR
- MOV P2,A
- MOV R7,#20
- LOOP0: MOV TMOD,#01H
- MOV TH0,#3CH
- MOV TL0,#0B0H
- SETB TR0
- JNB TF0,$
- CLR TF0
- DJNZ R7,LOOP0
- DEC R2
- CJNE R2,#0FFH,LOOP1
- AJMP MAIN
- TABLE1:DB 0C0H,0F9H,0A4H,0B0H
- DB 099H,092H,082H,0F8H
- DB 080H,090H
- TABLE:DB 03FH,06H,05BH,04FH
- DB 066H,06DH,07DH,07H
- DB 07FH,06FH
- END
60s倒計(jì)時(shí)課設(shè).zip
(39.14 KB, 下載次數(shù): 5)
2019-10-9 13:40 上傳
點(diǎn)擊文件名下載附件
60秒倒計(jì)時(shí) 下載積分: 黑幣 -5
