查看: 3264|回復: 0
stm8 stm8s單片機浮點數轉四字節串口輸出方案源程序(親測可用)
ID:610433 發表于 2019-10-9 10:43 | 顯示全部樓層 |閱讀模式
注釋掉的為轉四字節方案
未注釋掉的為直觀顯示數據方案
定時器1中斷1ms
INTERRUPT_HANDLER(TIM1_UPD_OVF_TRG_BRK_IRQHandler, 11)
  /* In order to detect unexpected events during development,
     it is recommended to set a breakpoint on the following instruction.
//  uint16_t i, j;
//  TIM1_ClearITPendingBit(TIM1_IT_UPDATE);
//  GPIO_WriteHigh(GPIOD, GPIO_PIN_3);
//  while(( UART3_GetFlagStatus(UART3_FLAG_TXE)==RESET));
//  UART3_SendData8(1);
//  for(i = 0; i < 60000; i++);
//  GPIO_WriteLow(GPIOD, GPIO_PIN_3);
  static u16 time = 0;
  float root = 0;
//  u8 * p;
//  u8 ftc1, ftc2, ftc3, ftc4;
//  u8 high3, low3;
  UartReadMonitor(1);
  if(time == 100)
    root = SF6Root(273,0.5);
    UART3_SendData8((u8)((unsigned int)(root/100)%10)+48);
    UART3_SendData8((u8)((unsigned int)(root/10)%10)+48);
    UART3_SendData8((u8)((unsigned int)(root/1)%10)+48);
    UART3_SendData8('.');
    UART3_SendData8((u8)((unsigned int)(root*10)%10)+48);
    UART3_SendData8((u8)((unsigned int)(root*100)%10)+48);
    UART3_SendData8((u8)((unsigned int)(root*1000)%10)+48);
//    p = (u8 *)(&root);
//    high3 = (u8)root;
//    low3 = (u8)((root - high3)*100);
//    ftc1 = *p++;
//    ftc2 = *p++;
//    ftc3 = *p++;
//    ftc4 = *p;
//    UART3_SendData8(high3);
//    UART3_SendData8(low3);
//    UART3_SendData8(ftc4);
//    UART3_SendData8(ftc3);
//    UART3_SendData8(ftc2);
//    UART3_SendData8(ftc1);
    time = 0;
  time++;
