官方驅動源程序如下:
- * \file main.c
- * \brief Ping-Pong example application on how to use Semtech's Radio
- * drivers.
- * \version 2.0
- * \date Nov 21 2012
- * \author Miguel Luis
- #include <string.h>
- #include <stdint.h>
- #include <stdbool.h>
- #include "platform.h"
- #include "led.h"
- #if USE_UART
- #include "uart.h"
- #endif
- #include "radio.h"
- #define BUFFER_SIZE 9 // Define the payload size here
- static uint16_t BufferSize = BUFFER_SIZE; // RF buffer size
- static uint8_t Buffer[BUFFER_SIZE]; // RF buffer
- static uint8_t EnableMaster = true; // Master/Slave selection
- tRadioDriver *Radio = NULL;
- const uint8_t PingMsg[] = "PING";
- const uint8_t PongMsg[] = "PONG";
- * Manages the master operation
- void OnMaster( void )
- uint8_t i;
- switch( Radio->Process( ) )
- case RF_RX_TIMEOUT:
- // Send the next PING frame
- Buffer[0] = 'P';
- Buffer[1] = 'I';
- Buffer[2] = 'N';
- Buffer[3] = 'G';
- for( i = 4; i < BufferSize; i++ )
- Buffer[i] = i - 4;
- Radio->SetTxPacket( Buffer, BufferSize );
- break;
- case RF_RX_DONE:
- Radio->GetRxPacket( Buffer, ( uint16_t* )&BufferSize );
- if( BufferSize > 0 )
- if( strncmp( ( const char* )Buffer, ( const char* )PongMsg, 4 ) == 0 )
- // Indicates on a LED that the received frame is a PONG
- LedToggle( LED_GREEN );
- Buffer[0] = 'P';
- Buffer[1] = 'I';
- Buffer[2] = 'N';
- Buffer[3] = 'G';
- // We fill the buffer with numbers for the payload
- else if( strncmp( ( const char* )Buffer, ( const char* )PingMsg, 4 ) == 0 )
- { // A master already exists then become a slave
- EnableMaster = false;
- LedOff( LED_RED );
- break;
- case RF_TX_DONE:
- // Indicates on a LED that we have sent a PING
- LedToggle( LED_RED );
- Radio->StartRx( );
- break;
- default:
- break;
- * Manages the slave operation
- void OnSlave( void )
- uint8_t i;
- case RF_RX_DONE:
- if( strncmp( ( const char* )Buffer, ( const char* )PingMsg, 4 ) == 0 )
- // Indicates on a LED that the received frame is a PING
- // Send the reply to the PONG string
- Buffer[0] = 'P';
- Buffer[1] = 'O';
- Buffer[2] = 'N';
- Buffer[3] = 'G';
- break;
- case RF_TX_DONE:
- // Indicates on a LED that we have sent a PONG
- break;
- default:
- break;
- * Main application entry point.
- int main( void )
- BoardInit( );
- Radio = RadioDriverInit( );
- Radio->Init( );
- while( 1 )
- if( EnableMaster == true )
- OnMaster( );
- else
- OnSlave( );
- #if( PLATFORM == SX12xxEiger ) && ( USE_UART == 1 )
- UartProcess( );
- uint8_t data = 0;
- if( UartGetChar( &data ) == UART_OK )
- UartPutChar( data );
- #endif
- #ifdef __GNUC__
- return 0;
- #endif
SX12xxDrivers-V2.1.0.7z
(820.95 KB, 下載次數: 46)
2019-10-7 23:04 上傳
