查看: 1241|回復: 0
AD1100.h單片機驅動源碼
ID:618096 發表于 2019-9-29 17:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
僅供學習
  1. #include<intrins.h>
  2. sbit SDA=P1^0;
  3. sbit SCL=P1^1;
  4. #define VREF 5.0
  5. /****************開始位********************/
  6. void start()
  7. {
  8.         SDA = 1;
  9.         SCL = 1;
  10. delaynus(50);
  11.         SDA = 0;
  12. delaynus(50);
  13.         SCL = 0;
  14. }
  15. // 停止位
  16. void stop()
  17. {
  18.         SDA = 0;
  19. delaynus(50);
  20.         SCL = 1;
  21. delaynus(50);
  22.         SDA = 1;
  23. }
  24. bit ACK()
  25. {
  26.    bit ack_bit;
  27.         SCL = 1;
  28. delaynus(50);
  29.         ack_bit = SDA;
  30.         SCL = 0;
  31.         return ack_bit;
  32. }
  33. unsigned char ReadData()
  34. {
  35.         unsigned char i;
  36.         unsigned char x;
  37.         for(i = 0; i < 8; i++)
  38.         {
  39.                 SCL = 1;
  40.                 x<<=1;
  41.                 x|=(unsigned char)SDA;
  42.                 SCL = 0;
  43.         }
  44.         return(x);
  45. }
  46. void WriteCurrent(unsigned char y)
  47. {
  48.         unsigned char i;
  49.         for(i = 0; i < 8; i++)
  50.         {
  51.             SDA = (bit)(y&0x80);
  52. delaynus(50);
  53.            SCL = 1;
  54. delaynus(50);
  55.                   SCL = 0;
  56.                 y <<= 1;
  57.         }
  58. }
  59. float ReadVoltage()
  60. {
  61. unsigned char dat1,dat2;
  62. unsigned int dat3;
  63. start();
  64. WriteCurrent(0x97);
  65. ACK();
  66. dat1=ReadData();
  67.   ACK();
  68. dat2=ReadData();
  69. ACK();
  70. dat3=ReadData();
  71. ACK();
  72. stop();
  73. delay(20);
  74. dat3=(int)(dat1*256+dat2);
  75.   return (dat3*VREF/32768);
  76. }
  77. /*
  78. *配置寄存器
  79. *BIT  7      6      5      4     3      2      1      0
  80. *   ST/BSY          0                 0                SC         |DR1  DR0|   |PGA1   PGA0|
  81. */
  82. void AD1100_initi(unsigned char com)
  83. {
  84. start();
  85. WriteCurrent(0x96);
  86. ACK();
  87. WriteCurrent(com);
  88. ACK();
  89. stop();
  90. delay(10);
  91. }
AD1100.zip (56.68 KB, 下載次數: 5)
