現(xiàn)在可以把數(shù)碼管檢測示數(shù)但不懂如何觸發(fā)報警和按鍵儲存溫度上下限,多天無解,還望解惑。
#include<reg52.h>
#include<intrins.h>
typedef unsigned char uchar;
typedef unsigned int uint;
#define MAIN_Fosc 11059200UL
sbit DS = P3^7;
sbit we1=P2^0;
sbit we2=P2^1;
sbit we3=P2^2;
sbit we4=P2^3;
sbit deep=P3^6;
sbit key=P3^5;
sbit key2=P3^4;
sbit key3=P3^3;
sbit key4=P3^2;
uchar temp;
uchar num;
uchar settemp=35;
uchar settemp2=10;
bit DS18B20;
uchar msec, sec;
unsigned char code leddata[]={
0xC0, //"0"
0xF9, //"1"
0xA4, //"2"
0xB0, //"3"
0x99, //"4"
0x92, //"5"
0x82, //"6"
0xF8, //"7"
0x80, //"8"
0x90, //"9"
0x88, //"A"
0x83, //"B"
0xC6, //"C"
0xA1, //"D"
0x86, //"E"
0x8E, //"F"
0x89, //"H"
0xC7, //"L"
0xC8, //"n"
0xC1, //"u"
0x8C, //"P"
0xA3, //"o"
0xBF, //"-"
0xFF, //???
0xFF //?????
void delay (uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=84;y>0;y--);
void us(uchar us)//us???????
while(us--);
void display( uint value)
we1=1;
we1=0;
P0=0xff;
P0=leddata[value/1000];
delay(1);
we1=1;
we2=0;
P0&=0x7f;
P0=leddata[value%1000/100];
delay(1);
we2=1;
we3=0;
P0=0xff;
P0=leddata[value%100/10];
delay(1);
we3=1;
P0=0xff;
P0=leddata[value%10];
we4=0;
delay(1);
we4=1;
void display3( uint value)
we1=1;
we1=0;
P0=0xff;
delay(1);
we1=1;
we2=0;
P0&=0x7f;
delay(1);
we2=1;
we3=0;
P0=0xff;
delay(1);
we3=1;
P0=0xff;
we4=0;
delay(1);
we4=1;
void beep1()
temp=0xfe;
P1=temp;
delay(100);
temp=_crol_(temp,1);
P1=temp;
deep=~deep;
delay(100);
void display2()
if(key == 0)
delay(5);
if(key == 0)
while(!key);
settemp++;
delay(50);
if(settemp==99)
settemp=0;
delay(50);
if(key2 == 0)
delay(5);
if(key2 == 0)
while(!key2);
if(settemp!=0)
settemp--;
delay(50);
if(key3 == 0)
delay(5);
if(key3 == 0)
while(!key3);
settemp2++;
delay(50);
if(settemp2==99)
settemp2=0;
delay(50);
if(key4 == 0)
delay(5);
if(key4 == 0)
while(!key4);
if(settemp2!=0)
settemp2--;
delay(50);
void duan ()
EA=1;
ET0=1;
TR0=1;
TMOD=0x01;
TH0=0x4b;
TL0=0xfd;
void timer0() interrupt 1
TH0=0x4b;
TL0=0xfd;
msec++;
if(msec==20)
msec=0;
bit init()
bit i;
DS = 1;//??????
_nop_();
DS = 0;
us(75); //????????75*6.5+11.95=499.45us ????????????18B20???????????
DS=1;
us(4);//???
i = DS;
us(20); //141.95us ???????
DS = 1;
_nop_();
return (i);
void write (uchar dat)//д ???
uchar i;
for(i=0;i<8;i++)
DS = 0;
_nop_();//????д???
DS = dat & 0x01;//?????????
us(10);//76.95us
DS = 1; //???????????????????д??
_nop_();
dat >>= 1;//??????
uchar read_byte()
uchar i, j, dat;
for(i=0;i<8;i++)
DS = 0;
_nop_();//?????????
DS = 1;
_nop_();//???????
j = DS;
us(10);//76.95us
DS = 1;
_nop_();
dat = (j<<7)|(dat>>1);//????
return (dat);
uint i;
uchar L, M;
init();//?????DS18B20
write(0xcc);//???????ROM???
write(0x4e);//????д????????
write(0x18);
write(0x10);
write(0x7f);
init();
write(0xcc);
write(0x48);
write(0x44);//?????????????
init(); //?????DS18B20
write(0xbe);//???DS18B20??????
L = read_byte();
M = read_byte();
i = M;
i <<= 8;
i |= L;
i = i * 0.0625 * 100 + 0.05;
display(i);
duan();
if(key==0|key2==0|key3==0|key4==0)
{ if(key==0)
settemp=settemp*100;
while(!key);
display3(settemp);}
if(key2==0)
{ settemp=settemp*100;
while(!key2);
display3(settemp);}
if(key3==0)
{ settemp2=settemp2*100;
while(!key3);
display3(settemp2);}
if(key4==0)
{settemp2=settemp2*100;
while(!key4);
