查看: 1800|回復: 1
stm32驅動lcd1602程序
ID:617177 發表于 2019-9-27 14:35 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "lcd1602.h"
#include "delay.h"
#include "stdio.h"
void GPIO_Configuration(void)
        GPIO_InitTypeDef        GPIO_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOD,ENABLE);//使能PB,PD端口時鐘
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //普通輸出模式
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽輸出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //IO口速度為50MHz
        GPIO_Init(GPIOD, &GPIO_InitStructure);                                //初始化GPIOD0~7
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;
        GPIO_Init(GPIOB, &GPIO_InitStructure);                                //初始化GPIB15,14,13
/* 等待液晶準備好 */
void LCD1602_Wait_Ready(void)
        u8 sta;
        DATAOUT(0xff);
        LCD_RS_Clr();
        LCD_RW_Set();
        do
                LCD_EN_Set();
                delay_ms(5);        //延時5ms,非常重要
                 sta = GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_7);//讀取狀態字
                LCD_EN_Clr();
        }while(sta & 0x80);//bit7等于1表示液晶正忙,重復檢測直到其等于0為止
/* 向LCD1602液晶寫入一字節命令,cmd-待寫入命令值 */
void LCD1602_Write_Cmd(u8 cmd)
        LCD1602_Wait_Ready();
        LCD_RS_Clr();
        LCD_RW_Clr();
        DATAOUT(cmd);
        LCD_EN_Set();
        LCD_EN_Clr();
    //printf("%d",cmd);
/* 向LCD1602液晶寫入一字節數據,dat-待寫入數據值 */
void LCD1602_Write_Dat(u8 dat)
        LCD_RS_Set();
        LCD_RW_Clr();
        DATAOUT(dat);
        LCD_EN_Set();
        LCD_EN_Clr();
/* 清屏 */
void LCD1602_ClearScreen(void)
        LCD1602_Write_Cmd(0x01);
/* 設置顯示RAM起始地址,亦即光標位置,(x,y)-對應屏幕上的字符坐標 */
void LCD1602_Set_Cursor(u8 x, u8 y)
        u8 addr;
        if (y == 0)
                addr = 0x00 + x;
                addr = 0x40 + x;
        LCD1602_Write_Cmd(addr | 0x80);
/* 在液晶上顯示字符串,(x,y)-對應屏幕上的起始坐標,str-字符串指針 */
void LCD1602_Show_Str(u8 x, u8 y, u8 *str)
        LCD1602_Set_Cursor(x, y);
        while(*str != '\0')
                LCD1602_Write_Dat(*str++);
/* 初始化1602液晶 */
void LCD1602_Init(void)
    GPIO_Configuration();
        LCD1602_Write_Cmd(0x38);        //16*2顯示,5*7點陣,8位數據口
        LCD1602_Write_Cmd(0x0c);        //開顯示,光標關閉
        LCD1602_Write_Cmd(0x06);        //文字不動,地址自動+1
        LCD1602_Write_Cmd(0x01);        //清屏
//    LCD1602_Write_Cmd(0X02);
//    LCD1602_Write_Cmd(0X06);
//        LCD1602_Write_Cmd(0X00);
//        LCD1602_Write_Cmd(0X0C);
//        LCD1602_Write_Cmd(0X38);
//        LCD1602_Write_Cmd(0x01);
ID:1 發表于 2019-9-27 18:19 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
