查看: 3318|回復: 0
ADS111的STM32驅動程序 含配置代碼以及IIC通訊驅動
ID:616761 發表于 2019-9-26 16:20 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
內含ADS111配置代碼以及IIC通訊驅動
  1. #include "stm32f10x_lib.h"
  2. #include "ADS1115.h"
  3. #include "stm32f10x_i2c.h"
  4. #ifndef __cplusplus
  5. #endif
  6. /*--Private Value----------------------------------------------------------*/
  7. enum TestPort {BatVal,BatCur};
  8. unsigned char AD_BUF[2]={0};
  9. #define SCLH        GPIOB->BSRR = GPIO_Pin_6
  10. #define SCLL        GPIOB->BRR  = GPIO_Pin_6
  11. #define SDAH        GPIOB->BSRR = GPIO_Pin_7
  12. #define SDAL        GPIOB->BRR  = GPIO_Pin_7
  13. #define SCLread     GPIOB->IDR  & GPIO_Pin_6
  14. #define SDAread     GPIOB->IDR  & GPIO_Pin_7
  15. void I2C_GPIO_Config(void)
  16. {
  17.         GPIO_InitTypeDef  GPIO_InitStructure;
  18.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  19.
  20.         // Configure I2C1 pins: SCL and SDA
  21.         GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6;
  22.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  23.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  24.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  25.         GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_7;
  26.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  27.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  28.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  29.         GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_4;//assert管腳
  30.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  31.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  32.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  33. }
  34. void I2C_delay(void)
  35. {  unsigned char i=30; //
  36.    while(i)
  37.    {
  38.        i--;
  39.    }
  40. }
  41. bool I2C_Start(void)
  42. {
  43.         SDAH;
  44.         I2C_delay();
  45.         SCLH;
  46.         I2C_delay();
  47.         if(!SDAread)return FALSE; //SDA線為低則總線忙,退出
  48.         SDAL;
  49.         I2C_delay();
  50.         if(SDAread)
  51.         return FALSE; //SDA線為高則總線出錯,退出
  52.         SDAL;
  53.         I2C_delay();
  54.         return TRUE;
  55. }
  56. void I2C_Stop(void)
  57. {
  58.         SCLL;
  59.         I2C_delay();
  60.         SDAL;
  61.         I2C_delay();
  62.         SCLH;
  63.         I2C_delay();
  64.         SDAH;
  65.         I2C_delay();
  66. }
  67. void I2C_Ack(void)
  68. {
  69.         SCLL;
  70.         I2C_delay();
  71.         SDAL;
  72.         I2C_delay();
  73.         SCLH;
  74.         I2C_delay();
  75.         SCLL;
  76.         I2C_delay();
  77. }
  78. void I2C_NoAck(void)
  79. {
  80.         SCLL;
  81.         I2C_delay();
  82.         SDAH;
  83.         I2C_delay();
  84.         SCLH;
  85.         I2C_delay();
  86.         SCLL;
  87.         I2C_delay();
  88. }
  89. bool I2C_WaitAck(void)  //返回1有ACK,返回0無ACK
  90. {
  91.         SCLL;
  92.         I2C_delay();
  93.         SDAH;
  94.         I2C_delay();
  95.         SCLH;
  96.         I2C_delay();
  97.         if(SDAread)
  98.         { SCLL;
  99.           return FALSE;
  100.         }
  101.         SCLL;
  102.         return TRUE;
  103.         }
  104.
  105. void I2C_SendByte(u8 SendByte) //數據從高位到低位//
  106. {
  107.         u8 i=8;
  108.         while(i--)
  109.         {
  110.           SCLL;
  111.           I2C_delay();
  112.           if(SendByte&0x80)
  113.           SDAH;
  114.           else
  115.           SDAL;
  116.           SendByte<<=1;
  117.           I2C_delay();
  118.                 SCLH;
  119.           I2C_delay();
  120.         }
  121.         SCLL;
  122. }
  123. u8 I2C_ReceiveByte(void) //數據從高位到低位//
  124. {
  125.         u8 i=8;
  126.         u8 ReceiveByte=0;
  127.         SDAH;
  128.         while(i--)
  129.         {
  130.                 ReceiveByte<<=1;
  131.                 SCLL;
  132.                 I2C_delay();
  133.                 SCLH;
  134.                 I2C_delay();
  135.                 if(SDAread)
  136.                 {
  137.                  ReceiveByte|=0x01;
  138.                 }
  139.         }
  140.         SCLL;
  141.         return ReceiveByte;
  142. }
  143. /****************************************************************************
  144. * 名    稱: ADS1115_Init
  145. * 功    能: 初始化ADS1115
  146. * 入口參數:id:設備地址;write_address寄存器 ;byte1:高字節配置;byte2:低字節 最高轉換速度
  147. * 出口參數: 無
  148. * 說    明:  完成ADS1115的配置寄存器的初始化
  149. *****************************************************************************/
  150. void ADS1115_Init(unsigned char id,unsigned char write_address,unsigned char byte1,unsigned char byte2)
  151. {
  152.         while(!I2C_Start());
  153.   I2C_SendByte(id);//寫器件地址
  154.         while(!I2C_WaitAck());
  155.         I2C_SendByte(write_address);//寄存器地址
  156.         while(!I2C_WaitAck());
  157.         I2C_SendByte(byte1);//發送數據
  158.         while(!I2C_WaitAck());
  159.         I2C_SendByte(byte2);//發送數據
  160.         while(!I2C_WaitAck());
  161.         I2C_Stop();
  162.         I2C_delay();
  163.         I2C_delay();
  164. }
  165. /****************************************************************************
  166. * 名    稱: I2C_AD1115_Point
  167. * 功    能: 指向ADS1115內部特定的寄存器
  168. * 入口參數: id:設備地址;write_address寄存器
  169. * 出口參數: 無
  170. * 說    明: 指向ADS1115內部特定的寄存器
  171. ****************************************************************************/
  172. void I2C_AD1115_Point(unsigned char id,unsigned char write_address)
  173. {
  174.         while(!I2C_Start());
  175.         //產生起始條件
  176.         I2C_SendByte(id);//寫器件地址
  177.         //向設備發送設備地址
  178.         while(!I2C_WaitAck());
  179.         //等待ACK
  180.         I2C_SendByte(write_address);//發送數據
  181.         //寄存器地址
  182.         while(!I2C_WaitAck());
  183.         I2C_Stop();
  184.         //產生結束信號
  185. }
  186. /****************************************************************************
  187. * 名    稱: I2C_Read2
  188. * 功    能: 讀ADS1115轉換結果
  189. * 入口參數: id:設備地址;read_address寄存器地址
  190. * 出口參數: 無
  191. * 說    明: 轉換的值放在BUF【2】
  192. ****************************************************************************/
  193. void I2C_Read2(unsigned char  id, unsigned char read_address)
  194. {
  195.         while(!I2C_Start());
  196.         //產生起始條件
  197.         I2C_SendByte(id);//寫器件地址
  198.         //發送地址
  199.         while(!I2C_WaitAck());
  200.         //等待ACK
  201.         AD_BUF[0] = I2C_ReceiveByte();
  202.         I2C_Ack();
  203.         AD_BUF[1]  = I2C_ReceiveByte();
  204.         I2C_NoAck();
  205.         I2C_Stop();
  206. }
  207. /****************************************************************************
  208. * 名    稱: StartChannel
  209. * 功    能: 選擇通道測量
  210. * 入口參數: 通道0、1、2、3
  211. * 出口參數: 采樣值
  212. * 說    明: 完成ADS1115的采樣工作
  213. ****************************************************************************/
  214. s16 Out,AIN2,AIN1,AIN3,AIN0;
  215. s16 AD_Buff[4];
  216. int temp=0;
  217. float StartChannlel(char Channel)
  218. {
  219.         float AD_Val=0;
  220.
  221.         if(Channel==0)
  222.         {   //First (1001000)Address+0; Second :Point to the Config resgister   BatVal
  223.                 ADS1115_Init(0x90,0x01,0xc2,0xe0); //量程4.096;Continuous conversionmode;AIN1
  224.                 //860SPS;
  225.                 Out=AIN0-AIN1;
  226.         }
  227.         if(Channel==1)
  228.         {
  229.                 ADS1115_Init(0x90,0x01,0xd2,0xe0); //量程1.024;Continuous conversionmode;AIN3  BatCur
  230.                 //860SPS;
  231.                 Out=AIN2-AIN3;//00110110
  232.         }
  233.         if(Channel==2)
  234.          {
  235.            ADS1115_Init(0x90,0x01,0xe2,0xe0); //量程4.096;Continuous conversionmode;GND
  236.           //860SPS;
  237.          }
  238.          if(Channel==3)
  239.          {
  240.            ADS1115_Init(0x90,0x01,0xf2,0xe0); //量程4.096;Continuous conversionmode;GND
  241.           //860SPS;
  242.    }
  243.         while(GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_4));
  244.         I2C_AD1115_Point(0x90,0x00);
  245.         I2C_delay();
  246.         I2C_delay();
  247.         I2C_Read2(0x91,0x00);
  248.   while(!I2C_Start());
  249.         temp=(AD_BUF[0] << 8) | AD_BUF[1];
  250. //        AD_Val=4096*temp/32768.0;
  251.          AD_Val=temp;
  252.          if(Channel==0)
  253.                 {
  254.                          AD_Buff[0]=AD_Val;
  255.                 }
  256.                 if(Channel==1)
  257.                 {
  258.                          AD_Buff[1]=AD_Val;
  259.                 }
  260.                 if(Channel==2)
  261.                 {
  262.                          AD_Buff[2]=AD_Val;
  263.                 }
  264.                 if(Channel==3)
  265.                 {
  266.                          AD_Buff[3]=AD_Val;
  267.                 }
  268.         return AD_Val;
  269.
  270.
  271. }
  272.
ADS115.rar (610.13 KB, 下載次數: 39)
收藏收藏2 分享淘帖 頂 踩
