ADC讀取供電電壓值與內(nèi)部溫度傳感器值.兩路連續(xù)轉(zhuǎn)換模式.
vc_adc.c
- #include "vc_adc.h"
- //__IO u16 ADC_ConvertedValue[4][2];
- u16 ADC_ConvertedValue[4][2];
- /* 這里的ADC是暫時(shí)用來試驗(yàn)兩路AD轉(zhuǎn)換,一路是測量電壓,另一路是讀取內(nèi)部溫度值
- ** 暫時(shí)是用來測試的,以后測量電流一路.*/
- void Vc_AdcInit(void){
- GPIO_InitTypeDef GPIO_InitStructure;
- ADC_InitTypeDef ADC_InitStructure;
- RCC_APB2PeriphClockCmd (RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA ,ENABLE );
- RCC_ADCCLKConfig (RCC_PCLK2_Div6 ); /* 72M/6=12M */
- GPIO_InitStructure .GPIO_Mode = GPIO_Mode_AIN ;
- GPIO_InitStructure .GPIO_Pin = VADC_PIN; // | CADC_PIN 這里暫時(shí)先檢測電壓這一路;
- /* 因?yàn)槭禽斎?所以不需要設(shè)置速度 */
- GPIO_Init (ADC_PORT ,&GPIO_InitStructure );
- ADC_DeInit (ADC1 );
- ADC_InitStructure .ADC_Mode = ADC_Mode_Independent ; /* ADC獨(dú)立模式 */
- //ADC_InitStructure .ADC_ScanConvMode = DISABLE ; /* 單通道模式*/
- ADC_InitStructure .ADC_ScanConvMode = ENABLE ; /* 多通道模式*/
- //ADC_InitStructure .ADC_ContinuousConvMode = DISABLE ; /* 單次模式*/
- ADC_InitStructure .ADC_ContinuousConvMode = ENABLE ; /* 連續(xù)模式*/
- ADC_InitStructure .ADC_ExternalTrigConv = ADC_ExternalTrigConv_None ;
- ADC_InitStructure .ADC_DataAlign = ADC_DataAlign_Right ;
- ADC_InitStructure .ADC_NbrOfChannel = 2; /* 設(shè)置ADC路數(shù)為2路*/
- ADC_Init (ADC1, &ADC_InitStructure );
- ADC_TempSensorVrefintCmd (ENABLE );
- ADC_RegularChannelConfig (ADC1 ,ADC_Channel_4 , 1, ADC_SampleTime_239Cycles5); /* 規(guī)則通道1*/
- ADC_RegularChannelConfig (ADC1 ,ADC_Channel_16 ,2, ADC_SampleTime_239Cycles5); /* 規(guī)則通道2*/
- ADC_DMACmd (ADC1 ,ENABLE );
- ADC_Cmd (ADC1 ,ENABLE );
- ADC_ResetCalibration (ADC1 );
- while(ADC_GetResetCalibrationStatus (ADC1));
- ADC_StartCalibration (ADC1 );
- while(ADC_GetCalibrationStatus (ADC1 ));
- ADC_SoftwareStartConvCmd (ADC1 ,ENABLE );
- void DMA_Config(void){
- DMA_InitTypeDef DMA_InitStructure;
- RCC_AHBPeriphClockCmd (RCC_AHBPeriph_DMA1 ,ENABLE );
- DMA_DeInit (DMA1_Channel1);
- DMA_InitStructure .DMA_PeripheralBaseAddr = (u32)&(ADC1 ->DR);
- DMA_InitStructure .DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue ;
- DMA_InitStructure .DMA_DIR = DMA_DIR_PeripheralSRC ; /* 外設(shè)作為數(shù)據(jù)來源*/
- DMA_InitStructure .DMA_BufferSize =
- DMA_InitStructure .DMA_PeripheralInc = DMA_PeripheralInc_Disable ; /* 外設(shè)地址固定*/
- DMA_InitStructure .DMA_MemoryInc = DMA_MemoryInc_Enable ; /* 內(nèi)存地址增加*/
- DMA_InitStructure .DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord ; /* 16bit*/
- DMA_InitStructure .DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord ;
- DMA_InitStructure .DMA_Mode = DMA_Mode_Circular ;
- DMA_InitStructure .DMA_Priority = DMA_Priority_High ;
- DMA_InitStructure .DMA_M2M = DMA_M2M_Disable ;
- DMA_Init (DMA1_Channel1 ,&DMA_InitStructure );
- DMA_Cmd (DMA1_Channel1 ,ENABLE );
vc_adc.h
- #ifndef _vc_adc_H
- #define _vc_adc_H
- #include "stm32f10x.h"
- /*電壓ADC--PA4(ADC12-IN$)
- **電流ADC--PA3(ADC12-IN3)
- #define VADC_PIN GPIO_Pin_4
- #define CADC_PIN GPIO_Pin_3
- #define ADC_PORT GPIOA
- extern void Vc_AdcInit(void);
- extern void DMA_Config(void);
- #endif
