只需一步,快速開(kāi)始
查看: 1941|回復(fù): 1
STC15408AD單片機(jī)搖桿AD轉(zhuǎn)換串口顯示程序
ID:613558 發(fā)表于 2019-9-19 13:55 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
新手上路,求大佬多多指導(dǎo)。
單片機(jī)源程序如下:
  1. #include"stc15f2k60s2.h"
  2. #include <intrins.h>
  3. //sbit URx = P1^0;
  4. //sbit URy = P1^1;
  5. sbit key = P1^2;
  6. unsigned int h = 0 ;
  7. unsigned int l = 0 ;
  8. unsigned int vin = 0;
  9. void ConfigUsart();
  10. void delay_us(unsigned int i);
  11. void ConfigAD();
  12. void ADC_STC15();
  13. void Delay100ms()                //@11.0592MHz
  14. {
  15.         unsigned char i, j, k;
  16.         _nop_();
  17.         _nop_();
  18.         i = 5;
  19.         j = 52;
  20.         k = 195;
  21.         do
  22.         {
  23.                 do
  24.                 {
  25.                         while (--k);
  26.                 } while (--j);
  27.         } while (--i);
  28. }
  29. void main()
  30. {
  31.    EA = 1;
  32.    ES = 1;
  33.    ConfigUsart();
  34.    ConfigAD();
  35.    //IE = 0x80;
  36.   while(1)
  37.   {
  38.            ADC_STC15();
  39.          Delay100ms();
  40.          Delay100ms();
  41.          Delay100ms();
  42.          Delay100ms();
  43.          Delay100ms();
  44.   }
  45. }
  46. void ConfigUsart()
  47. {
  48.         SCON = 0x50;                //8位數(shù)據(jù),可變波特率
  49.         AUXR |= 0x40;                //定時(shí)器1時(shí)鐘為Fosc,即1T
  50.         AUXR &= 0xFE;                //串口1選擇定時(shí)器1為波特率發(fā)生器
  51.         TMOD &= 0x0F;                //設(shè)定定時(shí)器1為16位自動(dòng)重裝方式
  52.         TL1 = 0xE0;                //設(shè)定定時(shí)初值
  53.         TH1 = 0xFE;                //設(shè)定定時(shí)初值
  54.         ET1 = 0;                //禁止定時(shí)器1中斷
  55.         TR1 = 1;                //啟動(dòng)定時(shí)器1
  56. }
  57. void ConfigAD()
  58. {
  59.    CLK_DIV &= ~0x20;   //ADJ = 1  //        高2位低8位
  60.    //EADC = 1;
  61.    P1ASF |= 0x03;
  62.    ADC_RES = 0;
  63.    ADC_CONTR |= 0x80 ; //開(kāi)電源
  64.    ADC_CONTR |= 0x40;  //轉(zhuǎn)換速度
  65.    //ADC_CONTR |= 0x08;
  66.    //ADC_CONTR |= 0x00;        //P1.0
  67.    Delay100ms();
  68.    //delay_us(8000);
  69. }
  70. void ADC_STC15()
  71. {
  72.    unsigned int   s   = 0;
  73.    ADC_RES = 0;
  74.    ADC_CONTR |= 0x80 ; //開(kāi)電源
  75.    ADC_CONTR |= 0x40;  //轉(zhuǎn)換速度
  76.    ADC_CONTR |= 0x08;
  77.   // ADC_CONTR |= 0x00;        //P1.0
  78. //   _nop_();
  79. //   _nop_();
  80. //   _nop_();
  81. //   _nop_();
  82.    while(!(ADC_CONTR & 0x10));   //等待轉(zhuǎn)換完成
  83.    ADC_CONTR  &= ~0x10;                         //關(guān)閉ADC
  84.    //h = ADC_RES;
  85.    //ADC_RES = 0;
  86.    SBUF = ADC_RES;
  87.    while(!TI);
  88.    TI = 0;
  89. ////          static unsigned  int  i =  0;
  90. //        unsigned int   s   = 0;
  91. //
  92. //        ADC_RES  = 0 ;  //  AD轉(zhuǎn)換結(jié)果高位
  93. //        ADC_RESL = 0 ;           //AD轉(zhuǎn)換結(jié)果低位
  94. //        ADC_CONTR |=0x80;  //開(kāi)電源
  95. //        //ADC_CONTR |= 0x08;   //開(kāi)始ad轉(zhuǎn)換
  96. //        ADC_CONTR |= 0x04;
  97. //        ADC_CONTR |= 0x03;
  98. //
  99. ////        while(i==0)
  100. ////        {
  101. ////          i = (ADC_CONTR & 0x10);
  102. ////        }
  103. //
  104. ////        ADC_CONTR &=0xEF;    //清除標(biāo)志位  關(guān)閉轉(zhuǎn)換
  105. //         h = ADC_RES;
  106. //         l = ADC_RESL;
  107. //         s = h<<8|l;
  108. //         vin = s * 1024 / 3 ;
  109. //         SBUF = vin;
  110. //         while(!TI);
  111. //         TI = 0;
  112. //         ADC_CONTR &=0xEF; // 關(guān)電源
  113. }
  114. void delay_us(unsigned int i){
  115.         for(i;i>0;i--)
  116.         {
  117.         _nop_();
  118.         _nop_();
  119.         _nop_();
  120.         }
  121. }
  122. void InterruptUsart() interrupt 4
  123. {
  124.   if(RI)
  125.   {
  126.     RI = 0 ;
  127.
  128.         SBUF = SBUF;
  129.   }
  130.   if(TI)
  131.   {
  132.
  133.          TI = 0;
  134.   }
  135. }
串口實(shí)驗(yàn).rar (32.23 KB, 下載次數(shù): 21)
收藏收藏2 分享淘帖 頂 踩
ID:1 發(fā)表于 2019-9-19 17:49 | 只看該作者
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說(shuō)明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
