六位數碼管時鐘,時、分、秒。附件里有程序和電路圖,喜歡DIY的朋友可以自己動手做一個數碼管鐘表。電路簡單,使用的是89c51或89c52單片機。
電路原理圖如下:
- uv3編譯生成hex文件燒入單片機
- 六位數碼管顯示時分秒
- 二十四小時制和十二小時制可切換
- #include<reg52.h>
- #define uc unsigned char
- #define ui unsigned int
- sbit LED=P3^2;
- sbit key0=P3^3;
- sbit key1=P3^4;
- sbit key2=P3^5;
- sbit key3=P3^6;
- sbit wan=P3^7;
- uc min,hour,sec,num;
- bit bdata zhi;
- uc code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};/*0,1,2,3,4,5,6,7,8,9,.*
- void delay(ui x)
- ui i,j;
- for(i=0;i<x;i++)
- for(j=0;j<121;j++);
- void display()
- P0=tab[hour/10];
- P2=0xdf;//11011111
- delay(1);
- P2=0xff;
- P0=(tab[hour%10])|0x80;//給第二位后加“點
- P2=0xef;//11101111
- delay(1);
- P2=0xff;
- P0=tab[min/10];
- P2=0xf7;//11110111
- delay(1);
- P2=0xff;
- P0=(tab[min%10])|0x80;
- P2=0xfb;//11111011
- delay(1);
- P2=0xff;
- P0=tab[sec/10];
- P2=0xfd;//11111101
- delay(1);
- P2=0xff;
- P0=tab[sec%10];
- P2=0xfe;//11111110
- delay(1);
- P2=0xff;
- void keyscan()
- if(key0==0)
- delay(5);
- if(key0==0)
- LED=~LED;
- zhi=~zhi;
- if((hour>=12)&&(zhi==0))
- hour=hour-12;
- if((zhi==1)&&(wan==1))
- hour=hour+12;
- while(!key0) display();
- if(key1==0)
- delay(5);
- if((key1==0)&&(zhi==0))
- hour++;
- if(hour==12)
- hour=0;
- wan=~wan;
- if((key1==0)&&(zhi==1))
- hour++;
- if(hour==24)
- hour=0;
- while(!key1) display();
- if(key2==0)
- delay(5);
- if(key2==0)
- min++;
- if(min==60)
- min=0;
- while(!key2) display();
- if(key3==0)
- delay(5);
- if(key3==0)
- {sec=0;}
- while(!key3) display();
- void init()
- sec=0;
- min=30;
- hour=12;
- LED=1;
- zhi=1;
- wan=1;
- TMOD=0x01;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- EA=1;
- ET0=1;
- TR0=1;
- void shizhi()
- if(hour>=12)
- wan=1;
- if((hour<12)&&(zhi==1))
- wan=0;
- void main()//主函數
- init();
- while(1)
- display();
- keyscan();
- shizhi();
- void time0() interrupt 1
- num++;
- if(num==20)
- num=0;
- sec++;
- if(sec==60)
- sec=0;
- min++;
- if(min==60)
- min=0;
- hour++;
- if((hour==12)&&(zhi==0))
- wan=~wan;
- hour=0;
- if((hour==24)&&(zhi==1))
- hour=0;
六位數碼管時鐘.zip
(68.79 KB, 下載次數: 13)
2019-9-11 12:06 上傳
數碼管時鐘
