實物調(diào)試
游客,本帖隱藏的內(nèi)容需要積分高于 1 才可瀏覽,您當(dāng)前積分為 0
程序
- #include<reg52.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit SCL=P0^2;
- sbit SDA=P0^3;
- //xainshi
- unsigned char z; //運行的電機
- unsigned char x; //正反
- unsigned char c; //數(shù)字加
- uchar code FFW1[8]={0x10,0x30,0x20,0x60,0x40,0xc0,0x80,0x90}; //四相八拍正轉(zhuǎn)編碼 前四
- uchar code FFW[8]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09}; //四相八拍正轉(zhuǎn)編碼 后四
- uchar code REV1[8]={0x90,0x80,0xc0,0x40,0x60,0x20,0x30,0x10}; ////四相八拍反轉(zhuǎn)編碼 前四
- uchar code REV[8]={0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01}; ////四相八拍反轉(zhuǎn)編碼 后死
- sbit BEEP = P0^7; //蜂鳴器
- sbit K1 = P0^4; //cwshi
- sbit K111 = P1^0; //
- sbit K112 = P1^1; //
- sbit K121 = P1^2; //
- sbit K122 = P1^3; //
- sbit K131 = P1^4; //
- sbit K132 = P1^5; //
- sbit K141 = P1^6; //
- sbit K142 = P1^7; //
- sbit K166 = P0^5; //全套動作
- unsigned char keyval; //定義變量儲存按鍵值
- unsigned char jianzhi; //定義變量儲存按鍵值
- unsigned char M1;
- unsigned char i1;
- unsigned char t,shi,ge,bai,dadt;
- unsigned char code xsbcdbuf[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77};
- LCD WRITE 模式 連續(xù)寫入數(shù)據(jù)
- *IIC_delay
- void led_delay(void)
- unsigned char j;
- for(j=0;j<200;j++)
- void delay(uint t)
- uint k;
- while(t--)
- for(k=0; k<130; k++)
- //電機運轉(zhuǎn)延時函數(shù)
- void delayB(uchar x) //x*0.14MS
- uchar i;
- while(x--)
- for (i=0; i<13; i++)
- //dengmingqi
- void beep()
- uchar i;
- for (i=0;i<100;i++)
- // delayB(4);
- BEEP=!BEEP; //BEEP取反
- BEEP=1; //關(guān)閉蜂鳴器
- //一號主控電機
- //正轉(zhuǎn)
- void motor_ffw10()
- uchar i;
- // uint j;
- // for (j=0; j<8; j++) //轉(zhuǎn)1*n圈
- for (i=0; i<8; i++) //一個周期轉(zhuǎn)45度
- {P2=FFW1[i]; //取數(shù)據(jù)
- delay(1); //調(diào)節(jié)轉(zhuǎn)速
- c=i;
- //反轉(zhuǎn)
- void motor_rev11()
- uchar i;
- uint j;
- x=0;
- z=1;
- // for (j=0; j<8; j++) //轉(zhuǎn)1×n圈
- // if(K3==0)
- // {break;} //退出此循環(huán)程序
- P2 = REV1[i]; //取數(shù)據(jù)
- c=i;
- //二號主控電機
- //電機正轉(zhuǎn)動
- void motor_ffw20()
- uchar i;
- uint j;
- x=1;
- z=2;
- // if(K3==0)
- //{break;} //退出此循環(huán)程序
- P2 = FFW[i]; //取數(shù)據(jù)
- c=i;
- //反轉(zhuǎn)
- void motor_rev21()
- uchar i;
- uint j;
- x=0;
- z=2;
- //if(K3==0)
- c=8;
- P2 = REV[i]; //取數(shù)據(jù)
- c=i;
- //三號主控電機
- //電機正轉(zhuǎn)動
- void motor_ffw30()
- uchar i;
- uint j;
- x=1;
- z=3;
- //for (j=0; j<8; j++) //轉(zhuǎn)1*n圈
- P3=FFW1[i]; //取數(shù)據(jù)
- delay(1);
- c=i; //調(diào)節(jié)轉(zhuǎn)速
- //反轉(zhuǎn)
- void motor_rev31()
- uchar i;
- uint j;
- x=0;
- z=3;
- // if(K3==0)
- // {break;}
- //退出此循環(huán)程序
- c=j;
- P3 = REV1[i]; //取數(shù)據(jù)
- //調(diào)節(jié)轉(zhuǎn)速
- //四號主控電機
- //電機正轉(zhuǎn)動
- void motor_ffw40()
- uchar i;
- uint j;
- x=1;
- z=4;
- // if(K3==0)
- // {break;}
- //退出此循環(huán)程序
- P3 = FFW[i]; //取數(shù)據(jù)
- c=i;
- delay(2); //調(diào)節(jié)轉(zhuǎn)速
- //反轉(zhuǎn)
- void motor_rev41()
- uchar i;
- uint j;
- x=0;
- z=4;
- c=j;
- P3 = REV[i]; //取數(shù)據(jù)
- //一號主控電機
- //正轉(zhuǎn)
- void motor_ffws10()
- uchar i;
- // uint j;
- c=i;
- //反轉(zhuǎn)
- void motor_revs11()
- uchar i;
- uint j;
- x=0;
- z=1;
- // if(K3==0)
- c=i;
- //二號主控電機
- //電機正轉(zhuǎn)動
- void motor_ffws20()
- uchar i;
- uint j;
- x=1;
- z=2;
- // if(K3==0)
- c=i;
- //反轉(zhuǎn)
- void motor_revs21()
- uchar i;
- uint j;
- x=0;
- z=2;
- //if(K3==0)
- c=8;
- c=i;
- //三號主控電機
- //電機正轉(zhuǎn)動
- void motor_ffws30()
- uchar i;
- uint j;
- x=1;
- z=3;
- delay(1);
- //反轉(zhuǎn)
- void motor_revs31()
- uchar i;
- uint j;
- x=0;
- z=3;
- // if(K3==0)
- // {break;}
- //退出此循環(huán)程序
- c=j;
- //四號主控電機
- //電機正轉(zhuǎn)動
- void motor_ffws40()
- uchar i;
- uint j;
- x=1;
- z=4;
- // if(K3==0)
- // {break;}
- //退出此循環(huán)程序
- c=i;
- //反轉(zhuǎn)
- void motor_revs41()
- uchar i;
- uint j;
- x=0;
- z=4;
- c=j;
- //一號主控電機
- //正轉(zhuǎn)
- void motor_ffwA10()
- uchar i;
- uint j;
- x=1;
- z=1;
- for (j=0; j<50; j++) //轉(zhuǎn)1*n圈
- P2 = FFW1[i]; //取數(shù)據(jù)
- delay(50); //調(diào)節(jié)轉(zhuǎn)速
- c=i;
- z=1;
- //反轉(zhuǎn)
- void motor_revA11()
- uchar i;
- uint j;
- x=0;
- z=1;
- for (j=0; j<50; j++) //轉(zhuǎn)1×n圈
- // if(K3==0)
- z=1;
- c=i;
- //二號主控電機
- //電機正轉(zhuǎn)動
- void motor_ffwA20()
- uchar i;
- uint j;
- x=1;
- z=2;
- for (j=0; j<20; j++) //轉(zhuǎn)1*n圈
- // if(K3==0)
- c=i;
- z=2;
- //反轉(zhuǎn)
- void motor_revA21()
- uchar i;
- uint j;
- x=0;
- z=2;
- for (j=0; j<20; j++) //轉(zhuǎn)1×n圈
- //if(K3==0)
- c=8;
- c=i;
- z=2;
- //三號主控電機
- //電機正轉(zhuǎn)動
- void motor_ffwA30()
- uchar i;
- uint j;
- x=1;
- z=3;
- delay(1);
- z=3;
- //反轉(zhuǎn)
- void motor_revA31()
- uchar i;
- uint j;
- x=0;
- z=3;
- // if(K3==0)
- // {break;}
- //退出此循環(huán)程序
- c=j;
- z=3;
- //四號主控電機
- //電機正轉(zhuǎn)動
- void motor_ffwA40()
- uchar i;
- uint j;
- x=1;
- z=4;
- for (j=0; j<30; j++) //轉(zhuǎn)1*n圈
- // if(K3==0)
- // {break;}
- //退出此循環(huán)程序
- c=i;
- z=4;
- //反轉(zhuǎn)
- void motor_revA41()
- uchar i;
- uint j;
- x=0;
- z=4;
- for (j=0; j<30; j++) //轉(zhuǎn)1×n圈
- c=j;
- delay(2);
- z=4;
- void motor_ffw1A40()
- uchar i;
- uint j;
- x=1;
- z=4;
- // if(K3==0)
- // {break;}
- //退出此循環(huán)程序
- c=i;
- z=4;
- //反轉(zhuǎn)
- void motor_rev1A41()
- uchar i;
- uint j;
- x=0;
- z=4;
- c=j;
- delay(2);
- z=4;
- void Init_Timer0(void)
- TMOD |= 0x01; //使用模式1,16位定時器,使用"|"符號可以在使用多個定時器時不受影響
- TH0=0x00; //給定初值,這里使用定時器最大值從0開始計數(shù)一直到65535溢出
- TL0=0x00;
- EA=1; //總中斷打開
- ET0=1; //定時器中斷打開
- TR0=1; //定時器開關(guān)打開
- void init()
- TMOD=0X01;
- TH0=(65535-50000)/256;
- TL0=(65535-50000)%256;
- ET0=1;
- EA=1;
- TR0=1;
- void IIC_delay(void)
- unsigned char i;
- for(i=0;i<20;i++) _nop_();
- 啟動IIC
- void start_IIC(void)
- SCL=1; //給芯片發(fā)送開始信號
- SDA=1;
- IIC_delay();
- SDA=0;
- IIC_delay();
- SCL=0; //開始信號傳送完
- IIC_delay();
- 停止IIC
- void stop_IIC(void)
- SCL=0;
- IIC_delay();
- SDA=0;
- IIC_delay();
- SCL=1;
- IIC_delay();
- SDA=1;
- void ack_IIC()
- SCL=0;
- _nop_();_nop_();_nop_();
- while(SDA);
- SCL=1;
- SCL=0;
- 寫一個字節(jié)數(shù)據(jù)
- void WriteByte(unsigned char WriteData)
- unsigned char i;
- for(i=0;i<8;i++)//開始傳送8位數(shù)據(jù),每循環(huán)一次傳送一位數(shù)據(jù)
- SCL=0;
- IIC_delay();
- WriteData=WriteData>>1;
- SDA=CY;
- IIC_delay();
- SCL=1;
- IIC_delay();
- //8位數(shù)據(jù)傳送完
- ack_IIC(); //判斷芯片發(fā)過來的ACK應(yīng)答信號
- 寫一字節(jié)數(shù)據(jù)到LEDSROM
- void write_LEDSROM(unsigned char addr,unsigned char WData)
- start_IIC(); //調(diào)用開始信號
- WriteByte(addr); //寫起始地址命令(0C0H),地址00H單元。
- WriteByte(WData);//給顯示寄存器寫顯示數(shù)據(jù),值可根據(jù)實參改變
- stop_IIC(); //調(diào)用結(jié)束信號,一個字節(jié)命令發(fā)送完畢,可以發(fā)送下一個命令
- 分開寫數(shù)據(jù)到LED
- void xsled(void)
- SDA=1;
- SCL=1;
- WriteByte(0x44);//寫命令40H(數(shù)據(jù)設(shè)置)
- write_LEDSROM(0xC0,0x00); //第一個數(shù)碼管
- write_LEDSROM(0xC1,xsbcdbuf[bai]); //第二個數(shù)碼管
- write_LEDSROM(0xC2,xsbcdbuf[shi]); //第三個數(shù)碼管
- write_LEDSROM(0xC3,xsbcdbuf[ge]);//第四個數(shù)碼管
- IIC_delay();
- WriteByte(0x8a); //送開屏命令,(8BH),亮度可以根據(jù)低三位調(diào)節(jié)。//顯示亮度
- void jisuan()
- bai=z ;
- shi=x ;
- ge=c;
- //bai=dadt/100;
- // shi=dadt/10%10;
- // ge=dadt%10;
- main()
- P0=0xff;
- M1=1;//chuzhi
- // unsigned char z;
- z=1;
- //P1=0xff;
- init();
- while(1)
- //motor_revA11();
- //motor_revA10();
- // jisuan();
- // xsled();
- jisuan();
- xsled();
- K166=0;
- P2=0x00;
- P3=0x00;
- P1=0x00;
- if(t==1000)
- t=0;
- //1號電機
- if(K111==1)
- // K1=1; //端口測試
- // beep();
- motor_ffw10(); //電機正轉(zhuǎn)
- if(K112==1)
- motor_rev11(); //電機反轉(zhuǎn)
- //2號電機
- if(K121==1)
- motor_ffw20(); //電機正轉(zhuǎn)
- if(K122==1)
- motor_rev21(); //電機反轉(zhuǎn)
- //3號電機
- if(K131==1)
- motor_ffw30(); //電機正轉(zhuǎn)
- if(K132==1)
- motor_rev31(); //電機反轉(zhuǎn)
- //4號電機
- if(K141==1)
- motor_ffw40(); //電機正轉(zhuǎn)
- if(K142==1)
- motor_rev41(); //電機反轉(zhuǎn)
- //quantao
- if(K166==1)
- uchar i;
- for (i=0; i<1; i++)
- K1=1;
- // motor_ffwA20(); //電機正轉(zhuǎn)
- motor_revA21();
- jisuan();
- xsled();
- jisuan();
- xsled();
- delay(2000);
- jisuan();
- xsled();
- //#############################################################shang
- // if(100>t>1)
- motor_ffwA10(); //電機正轉(zhuǎn)
- jisuan();
- xsled();
- delay(2000);
- jisuan();
- xsled();
- //######################################################################xaunzhuanzhenti
- // if(30>t>25)
- motor_ffwA30(); //電機正轉(zhuǎn)
- jisuan();
- xsled();
- jisuan();
- xsled();
- delay(1000);
- jisuan();
- xsled();
- //if(30>t>25)
- motor_revA31(); //電機正轉(zhuǎn)
- jisuan();
- xsled();
- delay(100);
- jisuan();
- xsled();
- //#####################################################xuanzhaunshouwan
- //下降之前展開機
- //下降
- //if(40>t>30)
- jisuan();
- xsled();
- motor_revA41();
- // motor_ffwA40(); //電機正轉(zhuǎn)
- jisuan();
- xsled();
- delay(3000);
- jisuan();
- xsled();
- // if(250>t>120) #############################################xaijiang
- motor_ffwA20(); //電機正轉(zhuǎn)
- // motor_revA21();
- motor_ffwA20();
- jisuan();
- xsled();
- jisuan();
- xsled();
- delay(2000);
- jisuan();
- xsled();
- jisuan();
- xsled();
- //#####################################################jiajing
- // if(40>t>30)
- // motor_revA41(); //電機正轉(zhuǎn)
- motor_ffwA40();
- jisuan();
- xsled();
- M1=0;
- jisuan();
- xsled();
- // if(100>t>1)
- jisuan();
- xsled();
- motor_revA21();
- jisuan();
- xsled();
- delay(2000);
- jisuan();
- xsled();
- jisuan();
- xsled();
- //if(20>t>13)#####################################################huizhuan
- motor_revA11(); //電機正轉(zhuǎn)
- jisuan();
- xsled();
- // delay(2000);
- jisuan();
- xsled();
- //z =0;
- // x
- // if(30>t>25)
- /// motor_ffwA30(); //電機正轉(zhuǎn)
- jisuan();
- xsled();
- // delay(10000);
- jisuan();
- xsled();
- //if(40>t>30)
- // delay(1000);
- jisuan();
- xsled();
- //if(20>t>13)
- // motor_revA11(); //電機正轉(zhuǎn)
- // delay(2000);
- jisuan();
- xsled();
- //if(25>t>20)
- // motor_revA21(); //電機正轉(zhuǎn)
- // delay(2000);
- jisuan();
- xsled();
- //if(30>t>25)
- // motor_revA31(); //電機正轉(zhuǎn)
- // delay(1000);
- jisuan();
- xsled();
- // if(40>t>30)
- M1=0;
- jisuan();
- xsled();
- // delay(2000);
- jisuan();
- xsled();
- c =0;
- void T0_time() interrupt 1
- TH0=(65535-80000)/256;
- TL0=(65535-60000)%256;
- // TH0 = 0x0FC;
- // TL0 = 0xEC;
- t++;
