查看: 3944|回復: 5
Keil環境中怎么替代#pragra
ID:272602 發表于 2019-9-9 18:19 | 顯示全部樓層 |閱讀模式
88黑幣
本帖最后由 thinkingpadcui 于 2019-9-10 16:24 編輯
#pragma location="LCD_region"
char lcd_buffer[8][256];
#pragma location="BG_region"
long lcd_points[8*256*8]
這段代碼在IAR下能正常運行,移植到keil5上面就報warning;
keil環境下可以用什么代碼代替這四段代碼!在線等
gui\LCD\lcd.c(18): warning:  #161-D: unrecognized #pragma
這兩個數組應該是定義12864LCD RAM的
void drawPoint(short x, short y, char value)
        unsigned short location;
        assert( (x<132));assert((y<64));
        assert( x>=0); assert((y>=0));
        location= y&0x7;
        location +=(y>>3)<<11;
        location += (x<<3);
        lcd_points[location]=value;
void paintRect(short x0, short y0, short x1, short y1)
        char *pchar;
        char temp_x0;
        y0 =y0>>3;
        y1 =(y1+7)>>3;
        for(;y0<=y1;y0++)
                 WriteCommand(0xb0 | (y0));
                WriteCommand(0x10 | (x0>>4));
                WriteCommand(0x0F & (x0));
                WriteCommand(0xE0);
                pchar = &lcd_buffer[y0][x0];
                temp_x0=x0;
                for(;temp_x0<=x1;temp_x0++){
                        WriteData(*pchar++);
}這個兩個數組只用在這兩個函數里面  然后這兩個函數被LCD底層驅動函數調用
下面是IAR .icf文件內容  在keil里面 應該怎么實現
#define symbol __ICFEDIT_region_RAM_LCD_start__ = 0x20004000;
#define symbol __ICFEDIT_region_RAM_LCD_end__   = 0x20004FFF;
#define symbol __ICFEDIT_region_RAM_BG_start__  = 0x22080000;
#define symbol __ICFEDIT_region_RAM_BG_end__    = 0x2208FFFF;
#define region LCD_region = mem:[from __ICFEDIT_region_RAM_LCD_start__   to __ICFEDIT_region_RAM_LCD_end__];
#define region BG_region = mem:[from __ICFEDIT_region_RAM_BG_start__   to __ICFEDIT_region_RAM_BG_end__];
ID:235200 發表于 2019-9-9 22:17 | 顯示全部樓層
去掉兩行,然后
long lcd_points[8*256*8];
這兩行根據自己的存儲器可定義為:
char xdata lcd_buffer[8][256];
long xdata lcd_points[8*256*8];
這樣編譯就不會出錯了
ID:272602 發表于 2019-9-10 12:18 | 顯示全部樓層
csmyldl 發表于 2019-9-9 22:17
去掉兩行,然后
        location= y&0x7;
        location += (x<<3);
        char *pchar;
        char temp_x0;
        y0 =y0>>3;
        y1 =(y1+7)>>3;
        for(;y0<=y1;y0++)
                WriteCommand(0xE0);
                temp_x0=x0;
ID:272602 發表于 2019-9-10 12:36 | 顯示全部樓層
去掉兩行,然后
謝謝!不太明白您的意思 我的問題加了補充了  麻煩看一下  謝謝
ID:272602 發表于 2019-9-10 22:41 | 顯示全部樓層
看了很多資料問題已解決,下面兩行代碼完美解決
char lcd_buffer[8][256]__attribute__((at(0x20004000)));
long lcd_points[8*256*8]__attribute__((at(0x22080000)));
ID:272602 發表于 2019-9-10 22:42 | 顯示全部樓層
查了很多資料,問題已解決。替換成下面兩行代碼。完美解決
