查看: 2727|回復: 1
LCD1602 proteus仿真及代碼
ID:609397 發表于 2019-9-9 10:38 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
#include<intrins.h>
#define out P0
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
void lcd_initial();
void check_busy();
void write_command(uchar com);
void write_data(uchar dat);
void string(uchar ad,uchar *s);
void delay(uint);
    lcd_initial();
     string(0x85,"WLECOME");
     string(0xC2,"Harbin CHINA");
     delay(100);
     write_command(0x01);
     delay(100);
void delay(uint j)
    uchar i=250;
    for(;j>0;j--)
        while(--i);
        i=249;
        while(--i);
        i=250;
void check_busy()
    uchar dt;
    do
        dt=0xff;
        E=0;
        RS=0;
        RW=1;
        E=1;
        dt=out;
    }while(dt&0x80);
        E=0;
    check_busy();
    E=0;
    RS=0;
    RW=0;
    out=com;
    E=1;
    _nop_();
    E=0;
    delay(1);
    check_busy();
    E=0;
    RS=1;
    RW=0;
    out=dat;
    E=1;
    _nop_();
    E=0;
    delay(1);
void lcd_initial()
    write_command(0x38);
    write_command(0x0C);
    write_command(0x06);
    delay(1);
    write_command(ad);
    while(*s>0)
        write_data(*s++);
        delay(100);
LCD.zip
108.97 KB, 下載次數: 50, 下載積分: 黑幣 -5
參與人數 1黑幣 +9 收起 理由
殘...月 + 9 贊一個!
ID:419166 發表于 2019-10-13 14:54 | 顯示全部樓層
感謝分享
