主程序的一小部分
#include <reg52.h>
#include <string.h>
#include <stdlib.h>
#include "bt.h"
#include "carbasic.h"
#include "timer.h"
#include "track.h"
#include "avoid.h"
extern bit commend_fininsh;
extern unsigned int pwm1;
extern unsigned int pwm2;
extern unsigned char ml[20];
extern unsigned char command_team[3][15];
void main(void){//1
Serial_init();
Timer1_Init();
while(1){//2
if(commend_fininsh==1){//3
commend_fininsh=0;
//LED5=0;
Command_Token(ml);
if(strcmp(command_team[1],"control")==0){//6
if(command_team[2][0]=='0'){
FORWOARD();
if(command_team[2][0]=='1'){
BACK();
if(command_team[2][0]=='2'){
LEFT();
if(command_team[2][0]=='3'){
RIGHT();
if(command_team[2][0]=='4'){
CIECLE_LEFT();
if(command_team[2][0]=='5'){
CIECLE_RIGHT();
if(command_team[2][0]=='6'){
FLOWER();
if(command_team[2][0]=='7'){
STOP();
} //6
智能小車.zip
2019-9-3 17:41 上傳
下載積分: 黑幣 -5
40.96 KB, 下載次數: 4, 下載積分: 黑幣 -5
可以直接使用
