查看: 5068|回復: 10
單片機IIC連續讀的問題
20黑幣
IIC連續讀的問題,請大家幫忙看一下這個程序為什么只能讀一個字節,哪里錯了,,還有程序有什么不太好的地方可以修改,不要重新寫的,要在我原有的程序修改并注釋,這樣我才能看的懂,謝謝
#include"STC89C5xRC.H"
uchar buf[4];
sbit scl=P3^6;
sbit sda=P3^7;
void start();
void Delay1(uchar);
void delay5us();
//void IIC_write(uchar ,uchar );
uchar IIC_read(uchar );
void smg(uint);
void AT24C02_writeData(uchar ,uchar ,uchar*);
void AT24C02_readData(uchar ,uchar );
void main (void)
                uchar arr[4]={3,4,5,6};
                start();
                AT24C02_writeData(0x00,sizeof(arr),arr);
                Delay1(5);
                AT24C02_readData(0,2);
                smg(buf[1]);
void start()
        sda=1;
        scl=1;
        delay5us();
        sda=0;
        delay5us();
        scl=0;
void stop()
        sda=0;
        delay5us();
        scl=1;
        delay5us();
        sda=1;
        delay5us();
void ack()
        uchar i=0;
        scl=1;
        delay5us();
        while((sda==1)&&(i<255))
                i++;
        delay5us();
        scl=0;
void Send_ack()
        scl=0;
        sda=0;
        delay5us();
        scl=1;
        delay5us();
        scl=0;
void nack()
        scl=1;
        delay5us();
        sda=1;
        delay5us();
        scl=0;
        delay5us();
void write_1(uchar i)
        uchar j,temp;
        temp=i;
        for(j=8;j>0;j--)
                temp=temp<<1;
                scl=0;
                delay5us();
                sda=CY;
                delay5us();
                scl=1;
                delay5us();
        scl=0;
        delay5us();
        sda=1;
        delay5us();
uchar read_1()
        uchar i,j,k;
        scl = 0;
        delay5us();
        for(i=0; i<8; i++)
                        scl = 1;
                        delay5us();
                        if(sda==1) j = 1;
                        else j = 0;
                        k = (k<<1)|j;
                        scl = 0;
                        delay5us();
        delay5us();
        return(k);
void IIC_write(uchar address,uchar date)
        start();
        write_1(0xa0);
        ack();
        write_1(address);
        ack();
        write_1(date);
        ack();
        stop();
        Delay1(5);
/*uchar IIC_read(uchar address)
        uchar i;
        start();
        write_1(0xa0);
        ack();
        write_1(address);
        ack();
        start();
        write_1(0xa1);
        ack();
        i = read_1();
        nack();
        stop();
        Delay1(1);
        return(i);
void delay5us()
void Delay1(uchar k)        //Ñóê±5ms
  uchar i, j;
                for(i=(18*k);i>0;i--)
                        for(j=255;j>0;j--)
void AT24C02_writeData(uchar address,uchar numBytes,uchar* buf)
    while(numBytes--)
                                IIC_write(address++,*buf++);
void AT24C02_readData(uchar beginAddr, uchar dataSize)
                uchar i=0;
                start();
    write_1(0xa0);
    ack();
    write_1(beginAddr);
    ack();
    start();
    write_1(0xa1);
    ack();
        while(dataSize--)
                                *(buf+i)=read_1();
                                        i++;
                                 Send_ack();
                nack();
    stop();
                Delay1(1);
ID:373388 發表于 2019-9-3 10:11 | 只看該作者
不是只讀一個,你是只顯示一位
ID:437615 發表于 2019-9-3 11:07 | 只看該作者
xhaity 發表于 2019-9-3 10:11
不是只讀一個,你是只顯示一位
是這樣的,我把4個都寫進去,然后再讀出來,我先顯示buf[0]是正確的,然后我又顯示buf[1],結果就不對了
ID:365802 發表于 2019-9-3 12:52 | 只看該作者
嗯, 你看看是不是操作太快導致的, 我之前就遇到過.
http://m.raoushi.com/bbs/dpj-151160-1.html
ID:437615 發表于 2019-9-3 17:52 | 只看該作者
ping264888 發表于 2019-9-3 12:52
現象是這樣,寫進去后,我用單字節讀,就沒問題,比如
                buf[0]=IIC_read(0 );
                buf[1]=IIC_read(1 );
                buf[2]=IIC_read(2 );
                buf[3]=IIC_read(3 );
這樣就行,所以覺得還是連讀函數有問題
ID:365802 發表于 2019-9-3 18:08 | 只看該作者
zhy123654 發表于 2019-9-3 17:52
建議讀操作之間加一些延時嘗試一下
ID:437615 發表于 2019-9-3 19:07 | 只看該作者
延時的問題試了,除非還有什么我不知道的地方,不然還是不行
ID:437615 發表于 2019-9-3 21:35 | 只看該作者
不用想了,沒辦法,最后用單字節讀再加個循環搞定,就是有點浪費資源
ID:540236 發表于 2019-9-4 20:00 | 只看該作者
                uchar i=0;
                start();
    write_1(0xa0);
    ack();
    write_1(beginAddr);
    ack();
    start();
    write_1(0xa1);
    ack();
        while(dataSize--)          //你上面main里給你參數是2,就是里面循環了兩次
                                *(buf+i)=read_1();
                                        i++;
                                 Send_ack(); //讀兩次是發一個ACK加一個Nack;
                nack();
    stop();
                Delay1(1);
ID:111517 發表于 2019-11-1 15:08 | 只看該作者
樓主問題解決了嗎?我也遇見了同樣的問題
ID:633908 發表于 2019-11-1 17:08 | 只看該作者
很好,只要端口反轉時間不低于要求就行
