#ifndef __SYS_H
#define __SYS_H
#include "stm32f10x.h"
//0,不支持ucos
//1,支持ucos
#define SYSTEM_SUPPORT_UCOS 0 //定義系統(tǒng)文件夾是否支持UCOS
//位帶操作,實(shí)現(xiàn)51類似的GPIO控制功能
//具體實(shí)現(xiàn)思想,參考<<CM3權(quán)威指南>>第五章(87頁~92頁).
//IO口操作宏定義
#define BITBAND(addr, bitnum) ((addr & 0xF0000000)+0x2000000+((addr &0xFFFFF)<<5)+(bitnum<<2))
#define MEM_ADDR(addr) *((volatile unsigned long *)(addr))
#define BIT_ADDR(addr, bitnum) MEM_ADDR(BITBAND(addr, bitnum))
//IO口地址映射
#define GPIOA_ODR_Addr (GPIOA_BASE+12) //0x4001080C
#define GPIOB_ODR_Addr (GPIOB_BASE+12) //0x40010C0C
#define GPIOC_ODR_Addr (GPIOC_BASE+12) //0x4001100C
#define GPIOD_ODR_Addr (GPIOD_BASE+12) //0x4001140C
#define GPIOE_ODR_Addr (GPIOE_BASE+12) //0x4001180C
#define GPIOF_ODR_Addr (GPIOF_BASE+12) //0x40011A0C
#define GPIOG_ODR_Addr (GPIOG_BASE+12) //0x40011E0C
#define GPIOA_IDR_Addr (GPIOA_BASE+8) //0x40010808
#define GPIOB_IDR_Addr (GPIOB_BASE+8) //0x40010C08
#define GPIOC_IDR_Addr (GPIOC_BASE+8) //0x40011008
#define GPIOD_IDR_Addr (GPIOD_BASE+8) //0x40011408
#define GPIOE_IDR_Addr (GPIOE_BASE+8) //0x40011808
#define GPIOF_IDR_Addr (GPIOF_BASE+8) //0x40011A08
#define GPIOG_IDR_Addr (GPIOG_BASE+8) //0x40011E08
//IO口操作,只對單一的IO口!
//確保n的值小于16!
#define PAout(n) BIT_ADDR(GPIOA_ODR_Addr,n) //輸出
#define PAin(n) BIT_ADDR(GPIOA_IDR_Addr,n) //輸入
#define PBout(n) BIT_ADDR(GPIOB_ODR_Addr,n) //輸出
#define PBin(n) BIT_ADDR(GPIOB_IDR_Addr,n) //輸入
#define PCout(n) BIT_ADDR(GPIOC_ODR_Addr,n) //輸出
#define PCin(n) BIT_ADDR(GPIOC_IDR_Addr,n) //輸入
#define PDout(n) BIT_ADDR(GPIOD_ODR_Addr,n) //輸出
#define PDin(n) BIT_ADDR(GPIOD_IDR_Addr,n) //輸入
#define PEout(n) BIT_ADDR(GPIOE_ODR_Addr,n) //輸出
#define PEin(n) BIT_ADDR(GPIOE_IDR_Addr,n) //輸入
#define PFout(n) BIT_ADDR(GPIOF_ODR_Addr,n) //輸出
#define PFin(n) BIT_ADDR(GPIOF_IDR_Addr,n) //輸入
#define PGout(n) BIT_ADDR(GPIOG_ODR_Addr,n) //輸出
#define PGin(n) BIT_ADDR(GPIOG_IDR_Addr,n) //輸入
#endif
