#include "ioCC2530.h"
#include "VL53L0X.h"
typedef union
uint16 u16; // element specifier for accessing whole u16
int16 i16; // element specifier for accessing whole i16
struct
uint8 u8L; // element specifier for accessing low u8
uint8 u8H; // element specifier for accessing high u8
} s16; // element spec. for acc. struct with low or high u8
} nt16;
void Delay_5us()
uint8 i;
for (i=0; i<8; i++)
asm("NOP");
void Delay_ms(uint16 sec)
uint16 i;
while (sec --)
for (i = 0; i < 1500; i ++)
asm("NOP");
return;
void initUARTSEND(void)
//時鐘配置
CLKCONCMD &= ~0x40; //設置系統時鐘源為32MHZ晶振
while(CLKCONSTA & 0x40); //等待晶振穩定
CLKCONCMD &= ~0x47; //設置系統主時鐘頻率為32MHZ
//端口配置
PERCFG = 0x00; //位置1 P0口
P0SEL = 0x0c; //P0_2,P0_3用作串口
P2DIR &= ~0XC0; //P0優先作為UART0
//串口配置
U0CSR |= 0x80; //UART方式
U0GCR |= 11; //U0GCR.BAUD_E
U0BAUD |= 216; //波特率設為115200 UxBAUD.BAUD_M
UTX0IF = 0; //UART0 TX中斷標志初始置位0
void UartSendString(char *Data, uint16 len)
uint16 j;
for (j = 0; j < len; j++)
U0DBUF = *Data++;
for (; 0 == UTX0IF ;);
UTX0IF = 0;
void uart0PutChar(char c)
uint16 i;
for(i=0; i<10000; i++)
if(!(U0CSR & 0x01))
break;
U0DBUF = c;
if(!(U0CSR & 0x01))
break;
uint16 makeuint16(int lsb, int msb)
return ((msb & 0xFF) << 8) | (lsb & 0xFF);
void uartPutInt16(uint16 c)
uart0PutChar((c & 0xFF00) >> 8);
uart0PutChar(c & 0xFF);
void GPIO_Init(void)
P0SEL &= ~0x12; //將P0_1、P0_4設置為通用I/O端口功能
P0DIR |= 0x02; //將P0_1的端口傳輸方式設置為輸出
P0DIR &= ~0x10; //將P0_4的端口傳輸方式設置為輸入
P1SEL &= ~0x08; //將P1_3設置為通用I/O端口功能
P1DIR |= 0x08; //將P1_3的端口傳輸方式設置為輸出
P0INP &= ~0xef;
P2INP &= ~0x20;
KK_wakeup = 1;
KK_Xshut = 0;
void I2C1_Init(void)
SCL_1_W();
SDA_1_W();
I2C1_SCL_HIGH;
I2C1_SDA_HIGH;
void I2C1_Start(void)
SCL_1_W();SDA_1_W();
I2C1_SDA_HIGH;
I2C1_SCL_HIGH;
Delay_5us();
I2C1_SDA_LOW;
Delay_5us();
Delay_5us();
I2C1_SCL_LOW;
void I2C1_Stop(void)
I2C1_SDA_LOW;
I2C1_SCL_LOW;
Delay_5us();
I2C1_SCL_HIGH;
Delay_5us();
Delay_5us();
I2C1_SDA_HIGH;
uint8 I2C1_WaitAck(void)
uint8 ErrTime = 0;
// 將 SCL 引腳和 SDA 引腳設置為輸出模式
I2C1_SDA_HIGH; // SDA 置高
I2C1_SCL_HIGH; // SCL 置高
Delay_5us();
SDA_1_R(); // SDA 設置為輸入模式
while(I2C1_SDA_STATE)// 當 SDA 為低電平時退出循環
ErrTime++;
if(ErrTime>250)
I2C1_Stop();
return true;
I2C1_SCL_LOW;
Delay_5us();
return false;
void I2C1_SendAck(void)
I2C1_SDA_LOW;
I2C1_SCL_LOW;
Delay_5us();
I2C1_SCL_HIGH;
Delay_5us();
I2C1_SCL_LOW;
void I2C1_SendNoAck(void)
I2C1_SCL_LOW;
I2C1_SDA_HIGH;
Delay_5us();
I2C1_SDA_HIGH;
Delay_5us();
I2C1_SCL_LOW;
void I2C1_Send_Byte(uint8 txd)
uint8 t = 0;
for (t = 0; t < 8; t ++)
if ((txd & 0x80) >> 7)
I2C1_SDA_HIGH;
I2C1_SDA_LOW;
txd <<= 1;
Delay_5us();
I2C1_SCL_HIGH;
Delay_5us();
I2C1_SCL_LOW;
Delay_5us();
uint8 I2C1_Read_Byte(uint8 ack)
uint8 i = 0;
uint8 receive = 0;
SDA_1_R();
for (i = 0; i < 8; i ++)
I2C1_SCL_LOW;
Delay_5us();
I2C1_SCL_HIGH;
receive <<= 1;
if (I2C1_SDA_STATE)
receive ++;
Delay_5us();
if (ack)
I2C1_SendAck();
I2C1_SendNoAck();
return receive;
函數功能:IIC連續寫
主要參數:
addr-->器件地址
reg-->寄存器地址
len-->寫入長度
buf-->數據區
返回值:0,正常
uint8 VL53L0X_Write_Len(uint8 reg,uint8 len,uint8 const *buf)
uint8 i;
I2C1_Start();
I2C1_Send_Byte(0x52); //發送器件地址+寫命令
if(I2C1_WaitAck()) //等待應答
I2C1_Stop();
return true;
I2C1_Send_Byte(reg); //寫寄存器地址
I2C1_WaitAck(); //等待應答
for(i=0;i<len;i++)
I2C1_Send_Byte(buf[i]); //發送數據
if(I2C1_WaitAck()) //等待ACK
I2C1_Stop();
return true;
I2C1_Stop();
return false;
函數功能:IIC連續讀
主要參數:
addr-->器件地址
reg-->寄存器地址
len-->讀取長度
buf-->數據區
返回值:0,正常
uint8 VL53L0X_Read_Len(uint8 reg,uint8 len,uint8 *buf)
I2C1_Start();
I2C1_Send_Byte(0x52);//發送器件地址+寫命令
I2C1_Stop();
return true;
I2C1_Start();
I2C1_Send_Byte(0x53);//發送器件地址+讀命令
while(len)
if(len==1)*buf=I2C1_Read_Byte(0);//讀數據,發送nACK
else *buf=I2C1_Read_Byte(1); //讀數據,發送ACK
len--;
buf++;
I2C1_Stop(); //產生一個停止條件
return false;
uint8 VL53L0X_Write_Byte(uint8 reg,uint8 data)
I2C1_Start();
I2C1_Stop();
return true;
I2C1_Send_Byte(data); //寫入數據
I2C1_Stop();
return true;
I2C1_Stop();
return false;
uint8 VL53L0X_Read_Byte(uint8 reg)
uint8 VL53L0X_data;
I2C1_Start();
I2C1_Start();
I2C1_Send_Byte(0x53); //發送器件地址+讀命令
VL53L0X_data=I2C1_Read_Byte(0);//讀取數據,發送ACK
return VL53L0X_data;
uint8 gbuf[16];
uint8 val = 0;
uint32 cnt = 0;
uint16 Distance = 0;
GPIO_Init();
Delay_ms(100);
KK_Xshut = 1;
initUARTSEND();
I2C1_Init();
if(KK_lcdctl)
KK_wakeup = 1;
//uartPutInt16(0xff);
VL53L0X_Write_Byte(VL53L0X_REG_SYSRANGE_START, 0x01);//啟動檢測
while(cnt < 65535)//當檢測完成,即讀取距離值
Delay_ms(1);
val = VL53L0X_Read_Byte(VL53L0X_REG_RESULT_RANGE_STATUS);
if( val & 0x01) break;
cnt++;
if( val & 0x01)
VL53L0X_Read_Len(0x1E , 2, gbuf);//讀取數據
// VL53L0X_Write_Byte(0x0b, 0x01);//啟動檢測
Distance = gbuf[0]<<8;
Distance |= gbuf[1];
if((Distance > 20)&&(Distance < 1500))
uartPutInt16(Distance);
if((Distance>=450)&&(Distance<=550))
KK_wakeup = 0;
Delay_ms(200);
Source.zip
2019-8-22 10:50 上傳
下載積分: 黑幣 -5
3.19 KB, 下載次數: 17, 下載積分: 黑幣 -5
