查看: 1816|回復(fù): 3
PIC16F917單片機(jī)加入定時(shí)器后,主函數(shù)不能運(yùn)行!
ID:81163 發(fā)表于 2019-8-21 12:45 | 顯示全部樓層 |閱讀模式
求教高手,PIC16F917,沒加定時(shí)器時(shí)主函數(shù)里的按鍵和監(jiān)測函數(shù)運(yùn)行都是正常的,然后增加一個(gè)定時(shí)器做個(gè)蜂鳴器報(bào)警功能!結(jié)果主函數(shù)就運(yùn)行了,后面再屏蔽掉定時(shí)器,主函數(shù)照樣不運(yùn)行!!不知道是怎么回事!求高手幫忙看看!
#include<pic.h>
#define uint  unsigned int
#define        low        RD0
#define        lbt RD3
#define        high RD2
#define flt RD4
#define spk RD5
#define mot RD6
#define ctr RD7
#define        keyin RB0
const uint data[2]={64722,64436};                        //蜂鳴器頻率
uint mode=0,lednum;
uint count=0;
uint vba,isp,k,t,flagb,flagf,jcout,i,p,j,s;
__CONFIG(0x30F5);
void delay(uint x);
void init();
uint get_ad(uchar y);
void monitor();
void key_scan();
void sentchar(uchar data1);
void printcom(const uchar *dat);
void printdata(uint dat);
uint filter();
void speakf();
void speakb();
//void interrupt time1();
        init();
               RD1=!RD1;
                k++;
        //        s++;
                if(k==1000)
                        k=0;
                        monitor();
                if(s>=1000)
                        s=0;
                        RD4=!RD4;
                        TMR1ON=!TMR1ON;
                key_scan();
void delay(uint x){--------}
void init()                                        //初始化:4MHZ,AD, PWM,uart,定時(shí)器012
        OSCCON=0x67;
        TRISA=0x0f;
        TRISB=0x01;
        TRISC=0xc0;
        TRISD=0;
        PORTA=0;
        PORTB=0;
        PORTC=0;
        PORTD=0xE1;
        TXSTA=0x24;
        RCSTA=0x90;
        SPBRG=25;
        RCIE=1;
        ANSEL=0x28;
        ADIE=1;
        ADCON0=0x05;
        ADCON1=0x9e;
        OPTION=0X07;
        TMR0=61;
        T0IE=1;
        INTCON=0xa0;
        GIE=1;
        PEIE=1;
        PIE1=0X03;
        T2CON=0X1C;
        TMR2IE=0;
        CCPR1L=0x5b;                        //C8
        CCP1CON=0x0C;
        TMR2=0;
        PR2=0x7C;
        T1CON=0x01;
        TMR1L=(65536-200)%256;
        TMR1H=(65536-200)/256;
        delay(10);
        T1CON=0X01;
        PORTD=0x81;
uint get_ad(uchar y){----------}
void monitor(){----監(jiān)測電池電壓和總電流--}
void key_scan(){---一鍵開關(guān)機(jī)+功能切換----}
void sentchar(uchar data1){---串口----}
void printcom(const uchar *dat){        ---串口------}
void printdata(uint dat){---串口----}
        if(TMR1IE&&TMR1IF)
                p=data[jcout];
                TMR1IF=0;
                TMR1L=p%256;
                TMR1H=p/256;
                spk=!spk;
                s++;
        //        printdata(s);
uint filter(){----ADC平均值-----}
void speakf() {-------}
void speakb(){------}
ID:81163 發(fā)表于 2019-8-22 12:26 | 顯示全部樓層
沒人??
ID:401564 發(fā)表于 2019-8-22 20:15 | 顯示全部樓層
C不會(huì),看不懂
但PIC用過
PIC的中斷和8051的中斷機(jī)制是不一樣的,PIC的中斷入口只有一個(gè),就是說不管你是ADC的中斷還是定時(shí)器中斷或者是外部,都會(huì)使程序進(jìn)入中斷,然后,在進(jìn)入中斷之后再通過查詢中斷標(biāo)志位來確定是什么中斷
8051就不一樣,對應(yīng)的中斷有對應(yīng)的入口。
如果你開啟了ADC的中斷的話,進(jìn)入中斷函數(shù)就得先查詢是ADC觸發(fā)的中斷還是定時(shí)器觸發(fā)的中斷,然后,再進(jìn)行處理
ID:81163 發(fā)表于 2019-8-23 09:58 | 顯示全部樓層
Y_G_G 發(fā)表于 2019-8-22 20:15
C不會(huì),看不懂
但PIC用過
PIC的中斷和8051的中斷機(jī)制是不一樣的,PIC的中斷入口只有一個(gè),就是說不管你是 ...
謝謝!我只開了定時(shí)器的中斷,ADC等其他的中斷都沒開!測試出主函數(shù)運(yùn)行了892次,期間定時(shí)器1運(yùn)行了大約80多次,然后程序就飛了,主程序不再運(yùn)行,定時(shí)器1一直不停的重復(fù)!
