查看: 3497|回復: 0
STM8L151實現AD測量程序_寄存器版調試成功
ID:600674 發表于 2019-8-16 11:18 | 顯示全部樓層 |閱讀模式
#include "ADC.h"
#include "iostm8l151f2.h"
#include "stdbool.h"
#include "stdint.h"
uint16_t Vbat1=0;
uint16_t Vbat0=0;
uint16_t Vusbin=0;
uint16_t Vbutton0=0;
uint16_t Vbat=0;
static uint16_t temp=0;
void delay_500ms(void)    //粗略延時程序
  uint16_t i,j;
  for(i=0;i<1000;i++)//2*1000個指令周期
    for(j=0;j<500;j++);//2*500個指令周期
  //1000*2*500+2*500=1.001M,延遲1/16s=62.5ms
  //16M 一個指令周期為1/16us
void ADC1_Init()
   CLK_PCKENR2_PCKEN20=1; //開啟ADC1外設時鐘
   ADC1_CR1_ADON=1;  //wakes up the ADC from Power down mode
   ADC1_CR1_CONT=0; //單次轉換模式
   ADC1_CR2_PRESC=1;//Select a sample time of 1μs  //   0: f(ADC_CLK) = CK
                     //   1: f(ADC_CLK) = CK/2  //系統時鐘此時為默認的16M/8=2M,這里分頻后,fadc=2M/2=1M
   ADC1_SQR1_DMAOFF=1;    //關閉DMA通道
   //ADC1_CR3_SMTP2=0x06;  //設置內部參考電壓通道的采樣時間
   ADC1_CR2_SMTP1=0x03;//外部0-23通道的采樣時間為24 ADC clock cycles,也就是24*1us=24us
//  ADC1_CR1_EOCIE=1; //中斷
//#pragma vector=COMP_EF2_vector
//__interrupt void ADC1_ISR(void
//測量VDD
uint16_t get_VDD()
   Vbat=0;
   ADC1_SQR1_CHSEL_S28=1;  //選擇ADC通道28,內部參考電壓通道
   ADC1_TRIGR1_VREFINTON=1;//打開內部參考電壓源1.225v
   for(char j=0;j<10;j++)
        ADC1_CR1_START=1 ;//開始轉換
        while(!(ADC1_SR_EOC==1));//等待轉換結束,清除標志位
        temp = ADC1_DRH;
        temp = (temp<<8)+ADC1_DRL;
        temp=(uint32_t)2400*4096/temp;   //由于VREF與VDD接在同一引腳上,內部參考電壓輸出通道實際電壓不知,
                                        //因此無法采用內部參考電壓測量VDD,用電壓表多點測量的方法測得實際VDD=1.790V
        Vbat+=temp;
   Vbat = Vbat/10;
   asm("nop");
   ADC1_SQR1_CHSEL_S28=0; //關閉通道
   return Vbat;
uint16_t get_Vbat1()
   Vbat1=0;
   static uint16_t temp1=0;
   ADC1_SQR3_CHSEL_S11=1;  //選擇ADC通道11
   ADC1_TRIGR3_TRIG11=1;  //關閉通道11的施密特觸發器
        temp1 = ADC1_DRH;
        temp1 = (temp1<<8)+ADC1_DRL;
        temp1=(uint32_t)1800*temp1/4096;
        Vbat1+=temp1;
    Vbat1 = Vbat1/10;
    Vbat1=3*Vbat1;//實際電壓值為3倍的AD電壓值
    ADC1_SQR3_CHSEL_S11=0;
   asm("nop");
     return Vbat1;
uint16_t get_Vbat0()
   Vbat0=0;
   static uint16_t temp0=0;
   ADC1_SQR3_CHSEL_S12=1;  //打開ADC通道12
   ADC1_TRIGR3_TRIG12=1;  //關閉通道12的施密特觸發器
  for(char k=0;k<10;k++)
        temp0 = ADC1_DRH;
        temp0 = (temp0<<8)+ADC1_DRL;
        temp0=(uint32_t)1800*temp0/4096;
        Vbat0+=temp0;
    Vbat0 = Vbat0/10;
    Vbat0=3*Vbat0;
     asm("nop");
      ADC1_SQR3_CHSEL_S12=0;
     return Vbat0;
uint16_t get_Vusbin()
   Vusbin=0;
   static uint16_t temp2=0;
   ADC1_SQR4_CHSEL_S4=1;  //打開ADC通道4
   ADC1_TRIGR4_TRIG4=1;  //關閉通道4的施密特觸發器
        while(!(ADC1_SR_EOC==1));//等待轉換完成
        temp2 = ADC1_DRH;   //先存MSB
        temp2 = (temp2<<8)+ADC1_DRL; //(MSB)*256+LSB
        temp2=(uint32_t)1800*temp2/4096;  //   VDD/4096=Vx/AD值
        Vusbin+=temp2;
      Vusbin = Vusbin/10;
      Vusbin =3*Vusbin;//USB輸入電壓
      asm("nop");
     ADC1_SQR4_CHSEL_S4=0;
     return Vusbin;
uint16_t get_Vbutton0()
     Vbutton0=0;
   static uint16_t temp3=0;
   ADC1_SQR3_CHSEL_S13=1;  //打開ADC通道13
   ADC1_TRIGR3_TRIG13=1;  //關閉通道13的施密特觸發器
        temp3= ADC1_DRH;
        temp3 = (temp3<<8)+ADC1_DRL;
        temp3=(uint32_t)1800*temp3/4096;
        Vbutton0+=temp3;
        Vbutton0 =Vbutton0/10;  //button0對應的電壓值
        asm("nop");
        ADC1_SQR3_CHSEL_S13=0; //關閉通道
        return Vbutton0;
  // CLK_Init();
  ADC1_Init();
  delay_500ms();
  delay_500ms();
  delay_500ms();//延時等待ADC穩定之后再進行轉換,能夠準確讀取對應通道的電壓
  get_Vusbin();
  delay_500ms();
  delay_500ms();
  get_Vbat0();
  delay_500ms();
  get_Vbutton0();
  delay_500ms();
  get_Vbat1();
