查看: 2603|回復: 1
STC12C5204AD單片機AD轉換,改變檢測電壓后只有重新上電再更新串口數據?
#include<STC12C5A60S2.h>
unsigned int a;
unsigned int res;
//定義延時函數
void delay(a){
while(--a!=0){
unsigned int i;
for(i=0;i<600;i++);
//串口初始化函數
void UART_INT(void){
PCON=0X80;
TMOD=0X20;
SCON=0X50;
TH1=0XF3;
TL1=0XF3;
EA=1;
ES=1;
TR1=1;
//AD轉換函數初始化
void ADC_INT()
P1ASF=0X01;//選擇P1.0口作AD轉換輸入口;
ADC_RES=0;//轉換結果寄存器清零
ADC_CONTR=ADC_CONTR|0x80;         //          讓第七位ADC_POWER置1,打開電源
EADC=1;         //打開AD轉換開關
delay(2);        //延時等待電源穩定
ADC_CONTR=ADC_CONTR|0x08; //讓第3位ADC_START置1,開始轉換
//AD中斷函數
ADC_ISR() interrupt 5 using 1
while((ADC_CONTR&0x10)==0);         //        等待轉換完成,第四位ADC_FLAG標志位為0時等待
res=ADC_RES;//轉換完成后,將值賦給串口數據寄存器
SBUF=res;
ADC_CONTR|=0x08;//重新啟動ADC轉換
void main(void)
UART_INT();
ADC_INT();
while(1){
while(!TI);
SBUF=res;
TI=0;
ID:213173 發表于 2019-8-16 06:28 | 只看該作者
  1. /*------------------------------------------------------------------*/
  2. /* --- STC MCU Limited ---------------------------------------------*/
  3. /* --- STC12C5Axx Series MCU A/D Conversion Demo -------------------*/
  4. /* --- Mobile: (86)13922805190 -------------------------------------*/
  5. /* --- Fax: 86-0513-55012956,55012947,55012969 ---------------------*/
  6. /* --- Tel: 86-0513-55012928,55012929,55012966----------------------*/
  7. /* --- Web: www.STCMCU.com -----------------------------------------*/
  8. /* --- Web: www.GXWMCU.com -----------------------------------------*/
  9. /* If you want to use the program or the program referenced in the  */
  10. /* article, please specify in which data and procedures from STC    */
  11. /*------------------------------------------------------------------*/
  12. #include "reg51.h"
  13. #include "intrins.h"
  14. #define FOSC    11059200L
  15. #define BAUD    9600
  16. typedef unsigned char BYTE;
  17. typedef unsigned int WORD;
  18. /*Declare SFR associated with the ADC */
  19. sfr ADC_CONTR   =   0xBC;           //ADC control register
  20. sfr ADC_RES     =   0xBD;           //ADC hight 8-bit result register
  21. sfr ADC_LOW2    =   0xBE;           //ADC low 2-bit result register
  22. sfr P1ASF       =   0x9D;           //P1 secondary function control register
  23. /*Define ADC operation const for ADC_CONTR*/
  24. #define ADC_POWER   0x80            //ADC power control bit
  25. #define ADC_FLAG    0x10            //ADC complete flag
  26. #define ADC_START   0x08            //ADC start control bit
  27. #define ADC_SPEEDLL 0x00            //420 clocks
  28. #define ADC_SPEEDL  0x20            //280 clocks
  29. #define ADC_SPEEDH  0x40            //140 clocks
  30. #define ADC_SPEEDHH 0x60            //70 clocks
  31. void InitUart();
  32. void SendData(BYTE dat);
  33. void Delay(WORD n);
  34. void InitADC();
  35. BYTE ch = 0;                        //ADC channel NO.
  36. void main()
  37. {
  38.     InitUart();                     //Init UART, use to show ADC result
  39.     InitADC();                      //Init ADC sfr
  40.     IE = 0xa0;                      //Enable ADC interrupt and Open master interrupt switch
  41.                                     //Start A/D conversion
  42.     while (1);
  43. }
  44. /*----------------------------
  45. ADC interrupt service routine
  46. ----------------------------*/
  47. void adc_isr() interrupt 5
  48. {
  49.     ADC_CONTR &= !ADC_FLAG;         //Clear ADC interrupt flag
  50.     SendData(ch);                   //Show Channel NO.
  51.     SendData(ADC_RES);              //Get ADC high 8-bit result and Send to UART
  52. //if you want show 10-bit result, uncomment next line
  53. //    SendData(ADC_LOW2);             //Show ADC low 2-bit result
  54.
  55.     if (++ch > 7) ch = 0;           //switch to next channel
  56.     ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | ch;
  57. }
  58. /*----------------------------
  59. Initial ADC sfr
  60. ----------------------------*/
  61. void InitADC()
  62. {
  63.     P1ASF = 0xff;                   //Set all P1 as analog input port
  64.     ADC_RES = 0;                    //Clear previous result
  65.     ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | ch;
  66.     Delay(2);                       //ADC power-on delay and Start A/D conversion
  67. }
  68. /*----------------------------
  69. Initial UART
  70. ----------------------------*/
  71. void InitUart()
  72. {
  73.     SCON = 0x5a;                    //8 bit data ,no parity bit
  74.     TMOD = 0x20;                    //T1 as 8-bit auto reload
  75.     TH1 = TL1 = -(FOSC/12/32/BAUD); //Set Uart baudrate
  76.     TR1 = 1;                        //T1 start running
  77. }
  78. /*----------------------------
  79. Send one byte data to PC
  80. Input: dat (UART data)
  81. Output:-
  82. ----------------------------*/
  83. void SendData(BYTE dat)
  84. {
  85.     while (!TI);                    //Wait for the previous data is sent
  86.     TI = 0;                         //Clear TI flag
  87.     SBUF = dat;                     //Send current data
  88. }
  89. /*----------------------------
  90. Software delay function
  91. ----------------------------*/
  92. void Delay(WORD n)
  93. {
  94.     WORD x;
  95.     while (n--)
  96.     {
  97.         x = 5000;
  98.         while (x--);
  99.     }
  100. }
