庫(kù)函數(shù):
void TIM_SetCompare2(TIM_TypeDef* TIMx, uint16_t Compare2)
/* Check the parameters */
assert_param(IS_TIM_LIST6_PERIPH(TIMx));
/* Set the Capture Compare2 Register value */
TIMx->CCR2 = Compare2;
uint16_t TIM_GetCapture2(TIM_TypeDef* TIMx)
/* Get the Capture 2 Register value */
return TIMx->CCR2;
貌似只說(shuō)CRR2=TIM_GetCapture2(TIM3)+1,因?yàn)門(mén)IM_GetCapture2的返回值是CCR2,而TIMx->CCR2 = Compare2=TIM_GetCapture2(TIM3)+1,其實(shí)就是TIM_GetCapture2=TIM_GetCapture2(TIM3)+1,所以是自加 |
