查看: 3152|回復(fù): 1
stm8單片機(jī)IIC讀寫24c32芯片源程序
ID:125378 發(fā)表于 2019-8-9 14:02 | 顯示全部樓層 |閱讀模式
大家一起學(xué)習(xí)探討
單片機(jī)源程序如下:
  1. /*
  2.   ******************************************************************************
  3.   * @file    24c32.c
  4.   * @author  Wang
  5.   * @version V1.0.0
  6.   * @date    6-August-2019
  7.   * @brief   This file contains all the functions for the read or write 24c32
  8.   ******************************************************************************
  9. */
  10. /* Includes ------------------------------------------------------------------*/
  11. #include "24c32.h"
  12. /* Private typedef -----------------------------------------------------------*/
  13. /* Private define ------------------------------------------------------------*/
  14. /* Private macro -------------------------------------------------------------*/
  15. /* Private variables ---------------------------------------------------------*/
  16. /* Private function prototypes -----------------------------------------------*/
  17. /* Private functions ---------------------------------------------------------*/
  18. /* Public functions ----------------------------------------------------------*/
  19. /*
  20.   * @brief  Write data to 24c32 device
  21.   * @param  addr : slaver address
  22.   * @param  reg_addr : register address
  23.   * @param  send_data : send data
  24.   * @retval None
  25. */
  26. void Write_24c32(uint8_t addr , uint8_t reg_addr , uint8_t send_data )
  27. {
  28.         Soft_iic_Start();
  29.         Soft_iic_Write_Byte(addr);
  30.         Soft_iic_Write_Byte(reg_addr>>8);        /*High address */
  31.         Soft_iic_Write_Byte(reg_addr%256);        /*Low address */
  32.         Soft_iic_Write_Byte(send_data);
  33.         Soft_iic_Stop();
  34. }
  35. /*
  36.   * @brief  Read data from 24c32 device
  37.   * @param  addr : slaver address
  38.   * @param  reg_addr : register address
  39.   * @retval return read data from DS1307 device
  40. */
  41. uint8_t Read_24c32(uint8_t addr , uint8_t reg_addr)
  42. {
  43.         uint8_t data = 0;
  44.         Soft_iic_Start();
  45.         Soft_iic_Write_Byte(addr);
  46.         Soft_iic_Write_Byte(reg_addr>>8);        /*High address */
  47.         Soft_iic_Write_Byte(reg_addr%256);        /*Low address */
  48.
  49.         Soft_iic_Start();
  50.         Soft_iic_Write_Byte(addr | 0x01);
  51.         data = Soft_iic_Read_Byte(0);
  52.         Soft_iic_Stop();
  53.         return data;
  54. }
  55. /*
  56.   * @brief  Test the 24c32 about read and write
  57.   * @param  None
  58.   * @retval None
  59. */
  60. void Test_24c32(void)
  61. {
  62.         uint8_t recv_data;
  63.         Write_24c32(0xA0,0,10);
  64.         Soft_delay_10us(500);  /* need to add delay */
  65.         recv_data = Read_24c32(0xA0,0);
  66.
  67.         if(recv_data == 10)
  68.                 {
  69.                         LED_On();
  70.                         Timer1_Delay_1ms(100);
  71.                         LED_Off();
  72.                         Timer1_Delay_1ms(100);
  73.                 }
  74. }
  75. /****************************END OF FILE**************************************/
Project_2.7z (3.8 MB, 下載次數(shù): 52)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
ID:612010 發(fā)表于 2019-9-17 10:39 | 顯示全部樓層
收藏學(xué)習(xí)一下
