查看: 2371|回復: 0
STM32薄片矩陣鍵盤驅動程序
ID:583354 發表于 2019-8-9 13:10 | 顯示全部樓層 |閱讀模式
基于STM32的薄片矩陣鍵盤,實驗現象為1,2,3,A為d的加減,分精調和粗調。4,5,6,B為a的精調和粗調,調完后需按下7確定,才能在串口中顯示
  1. #include "stm32f10x.h"
  2. #include "key.h"
  3. #include "sys.h"
  4. #include "delay.h"
  5.
  6. void KEY_Init(void) //IO初始化
  7. {
  8.         GPIO_InitTypeDef GPIO_InitStructure;
  9.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//使能PORTA,PORTC時鐘
  10.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;//PA0~4
  11.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  12.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  13.         GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA0,1,2,3,
  14.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  15.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  16.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
  17.         GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA4,5,6,7
  18.         GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
  19.         GPIO_ResetBits(GPIOA,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  20. }
  21. u8 Read_KeyValue(void)
  22. {
  23.         u8 KeyValue=0;
  24.         if((GPIO_ReadInputData(GPIOA)&0xff)!=0x0f)
  25.         {
  26.                 delay_ms(10);
  27.                 if((GPIO_ReadInputData(GPIOA)&0xff)!=0x0f)
  28.                 {
  29.                         GPIO_SetBits(GPIOA,GPIO_Pin_0);
  30.                         GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
  31.       switch(GPIO_ReadInputData(GPIOA)&0xff)
  32.                         {
  33.                                         case 0x11:KeyValue=1;break;
  34.                                         case 0x21:KeyValue=2;break;
  35.                                         case 0x41:KeyValue=3;break;
  36.                                         case 0x81:KeyValue=10;break;
  37.                         }
  38.                         GPIO_SetBits(GPIOA,GPIO_Pin_1);
  39.                         GPIO_ResetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3);
  40.       switch(GPIO_ReadInputData(GPIOA)&0xff)
  41.                         {
  42.                                         case 0x12:KeyValue=4;break;
  43.                                         case 0x22:KeyValue=5;break;
  44.                                         case 0x42:KeyValue=6;break;
  45.                                         case 0x82:KeyValue=11;break;
  46.                         }
  47.                         GPIO_SetBits(GPIOA,GPIO_Pin_2);
  48.                         GPIO_ResetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_3);
  49.       switch(GPIO_ReadInputData(GPIOA)&0xff)
  50.                         {
  51.                                         case 0x14:KeyValue=7;break;
  52.                                         case 0x24:KeyValue=8;break;
  53.                                         case 0x44:KeyValue=9;break;
  54.                                         case 0x84:KeyValue=12;break;
  55.                         }
  56.                         GPIO_SetBits(GPIOA,GPIO_Pin_3);
  57.                         GPIO_ResetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2);
  58.       switch(GPIO_ReadInputData(GPIOA)&0xff)
  59.                         {
  60.                                         case 0x18:KeyValue=14;break;
  61.                                         case 0x28:KeyValue=0;break;
  62.                                         case 0x48:KeyValue=15;break;
  63.                                         case 0x88:KeyValue=13;break;
  64.                         }
  65.                         GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
  66.                         GPIO_ResetBits(GPIOA,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  67.                         while((GPIO_ReadInputData(GPIOA)&0xff)!=0x0f);
  68.                         return KeyValue;
  69.                 }
  70.         }
  71.         return 0;
  72. }
按鍵輸入.7z (181.04 KB, 下載次數: 12)
