查看: 1392|回復: 0
24L01發送原程序
ID:595056 發表于 2019-8-9 08:35 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include ".\\nRF24L01\\nRF24L01.h"
#include "def.h"
#define TX_PLOAD_WIDTH 20 // 20字節TX有效載荷
#define RX_PLOAD_WIDTH 20 // 20字節TX有效載荷
sbit n=P2^1;                 //定義光電對管的輸出端口
sbit RS = P1^0;
sbit RW = P1^1;
sbit EN = P2^5;
sbit DU = P2^6;
uint g,s,b,q,w;
uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};    //本地地址
uint const RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01};     //接收地址
uchar         bdata sta;
sbit        RX_DR        =sta^6;
sbit        TX_DS        =sta^5;
sbit        MAX_RT        =sta^4;
void delay(uint k)
uint a,j;
for(a=0;a<k;a++)
for(j=0;j<121;j++);
void inerDelay_us(unsigned char n)
        for(;n>0;n--)
                _nop_();
void init_NRF24L01(void)
    inerDelay_us(100);
        CE=0;
        CSN=1;
        SCK=0;
        SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);    // 寫本地地址
        SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 寫接收端地址
        SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);   // 頻道0自動ACK應答允許
        SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  //允許接收地址只有頻道0
        SPI_RW_Reg(WRITE_REG + RF_CH, 0); //設置信道工作為2.4GHZ,收發一致
        SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH);
//設置接收數據長度,本次設置為4字節
        SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);
//設置發射速率為1Mkbps,發射功率為最大值0dB
uchar SPI_RW(uint uchar)
        uint bit_ctr;
           for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit
                MOSI = (uchar & 0x80);         //輸出 'uchar'到 MOSI
                uchar = (uchar << 1);
                SCK = 1;
                uchar |= MISO;
                SCK = 0;
    return(uchar);                             //返回uchar
uchar SPI_Read(uchar reg)
        uchar reg_val;
        CSN = 0;                // 置低CSN, 激活 SPI通信
        SPI_RW(reg);            // 選擇寄存器
        reg_val = SPI_RW(0);    // 讀取寄存器數值
        CSN = 1;                //置高CSN,終止SPI通信
        return(reg_val);        // 返回值
uchar SPI_RW_Reg(uchar reg, uchar value)
        uint status;
        CSN = 0;                   // CSN 拉低,激活SPI
        status = SPI_RW(reg);        // 選擇寄存器
        SPI_RW(value);             //寫入數值..
        CSN = 1;                   // 置高CSN
        return(status);               // 返回模塊狀態
uchar SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars)
        uint status,uchar_ctr;
        CSN = 0;
        for(uchar_ctr=0;uchar_ctr<uchars;uchar_ctr++)
                pBuf[uchar_ctr] = SPI_RW(0);
        CSN = 1;
        return(status);
uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars)
        CSN = 0;            //SPI使能
        for(uchar_ctr=0; uchar_ctr<uchars; uchar_ctr++)
                SPI_RW(*pBuf++);
        CSN = 1;           //關閉SPI
        return(status);
void SetRX_Mode(void)
        CE=0;
        SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);  // IRQ收發完成中斷響應
        CE = 1;
        inerDelay_us(130);
unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
    unsigned char revale=0;
        sta=SPI_Read(STATUS);        // 讀取狀態寄存其來判斷數據接收狀況
        if(RX_DR)                                // 判斷是否接收到數據
            CE = 0;                         //SPI使能
                SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);
                revale =1;                        //讀取數據完成標志
        SPI_RW_Reg(WRITE_REG+STATUS,sta);
//接收到數據后RX_DR,TX_DS,MAX_PT都置高為1,通過寫1來清楚中斷標志
        return revale;
void nRF24L01_TxPacket(unsigned char * tx_buf)
        CE=0;                        //StandBy I模式
        SPI_Write_Buf(WRITE_REG+RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);
// 裝載接收端地址
        SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH);
// 裝載數據
        SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);
// IRQ收發完成中斷響應,16位CRC,主發送
        CE=1;                 //置高CE,激發數據發送
        inerDelay_us(10);
bit LCD_Check_Busy(void)
P0= 0xFF;
RS=0;
RW=1;
delay(5);
EN=0;
delay(5);
EN=1;
return (bit)(P0 & 0x80);
void LCD_Write_Com(uchar com)
while(LCD_Check_Busy());
P0= com;
RS=0;
RW=0;
delay(5);
EN=1;
delay(5);
EN=0;
void LCD_Write_Data(uchar Data)
P0= Data;
RS=1;
RW=0;
delay(5);
EN=1;
delay(5);
EN=0;
void LCD_Init(void)
   LCD_Write_Com(0x38);
   LCD_Write_Com(0x08);
   LCD_Write_Com(0x01);
   LCD_Write_Com(0x06);
   LCD_Write_Com(0x0C);
void display(unsigned long int n,uchar address)
    g=n%10;
    s=n%100%10;
    b=n/100%10;
    q=n/1000%10;
    w=n/10000%10;
        //sw=n/100000%10;
    LCD_Write_Com(0x80 + address);
    LCD_Write_Data('T');
        LCD_Write_Data('/');
        LCD_Write_Data(w+48);
        //LCD_Write_Data(q+48);
        LCD_Write_Data(46);
        LCD_Write_Data(b+48);
    LCD_Write_Data(s+48);
        LCD_Write_Data(g+48);
unsigned long int i;//z;
uint m=0;//,t;
unsigned char TxBuf[20]={0};
unsigned char RxBuf[20]={0};
        DU=1;
                P0=0X00;
                DU=0;
    TMOD=0x01;
    TH0=(65536-100)/256;
    TL0=(65536-100)%256;
    ET0=1;
    EA=1;
LCD_Init();
init_NRF24L01();
   if(n==0)
          delay(5);
         while(!n);      //記得分號
                TR0=1;
                   m++;
          if(m>11)
            TR0=0;
                delay(100);
            TxBuf[0]=g;
            TxBuf[1]=s;
                TxBuf[2]=b;
                TxBuf[3]=q;
                TxBuf[4]=w;
            //TxBuf[5]=sw;
                delay(100);
        nRF24L01_TxPacket(TxBuf);            // Transmit Tx buffer data
        SPI_RW_Reg(WRITE_REG+STATUS,0XFF);
            delay(1000);
                  TxBuf[0]=0;
            TxBuf[1]=0;
                TxBuf[2]=0;
                TxBuf[3]=0;
                TxBuf[4]=0;
                //TxBuf[5]=0;
                //i=0;
                {EA=0; }
             display(i+15872,0x00);
void t1_i() interrupt 1
  i++;
