查看: 1963|回復: 3
關于單片機陣列按鈕的檢測問題
ID:598105 發表于 2019-8-9 01:28 | 顯示全部樓層 |閱讀模式
看到郭天祥新概念51單片機C語言教程的按鈕陣列時,我完全被弄暈了,先上代碼
我寫的是用鍵盤陣列去改變P3管腳的電平,通過電平的改變去改變P2管腳從而驅動LED小燈,功能都實現了,但是我現在唯一搞不懂的地方就是檢測矩陣鍵盤的地方
  1. 比如說我現在已經按下了矩陣鍵盤第2行的第2列,那么這個時候P3管腳的電平應該是11011101也就是0xDD
哪位大神幫小弟解決一下這個問題啊,這個問題已經困擾我兩天了
  1. #include <reg52.h>
  3. #define uint  unsigned int
  4.
  5. uchar key;
  6. void delayms(uint xms) {
  7.         uint i, j;
  8.         for(i = xms; i > 0; i--)
  9.                 for(j = 110; j > 0; j--);
  10. }
  11. void matrixKeyScan() {
  12.
  13.         uchar _temp;
  14.
  15.         //檢測第一行
  16.         P3    = 0xFE;
  17.         _temp = P3;
  18.         _temp = _temp & 0xF0;
  19.         if(_temp != 0xF0){
  20.                 delayms(10);
  21.                 _temp = P3;
  22.                 _temp = _temp & 0xF0;
  23.                 if(_temp != 0xF0){
  24.                         _temp = P3;
  25.                         switch(_temp) {
  26.                                 case 0xEE:
  27.                                         key = 0;
  28.                                         break;
  29.                                 case 0xDE:
  30.                                         key = 1;
  31.                                         break;
  32.                                 case 0xBE:
  33.                                         key = 2;
  34.                                         break;
  35.                                 case 0x7E:
  36.                                         key = 3;
  37.                                         break;
  38.                         }
  39.                         while(_temp != 0xF0){
  40.                                 _temp = P3;
  41.                                 _temp = _temp & 0xF0;
  42.                         }
  43.                 }
  44.         }
  45.
  46.         //檢測第二行
  47.         P3 = 0xFD;
  48.         _temp = P3;
  49.         _temp = _temp & 0xF0;
  50.         if(_temp != 0xF0){
  51.                 delayms(10);
  52.                 _temp = P3;
  53.                 _temp = _temp & 0xF0;
  54.                 if(_temp != 0xF0){
  55.                         _temp = P3;
  56.                         switch(_temp) {
  57.                                 case 0xED:
  58.                                         key = 4;
  59.                                         break;
  60.                                 case 0xDD:
  61.                                         key = 5;
  62.                                         break;
  63.                                 case 0xBD:
  64.                                         key = 6;
  65.                                         break;
  66.                                 case 0x7D:
  67.                                         key = 7;
  68.                                         break;
  69.                         }
  70.                         while(_temp != 0xF0){
  71.                                 _temp = P3;
  72.                                 _temp = _temp & 0xF0;
  73.                         }
  74.                 }
  75.         }
  76.
  77.         //檢測第三行
  78.         P3 = 0xFB;
  79.         _temp = P3;
  80.         _temp = _temp & 0xF0;
  81.         if(_temp != 0xF0){
  82.                 delayms(10);
  83.                 _temp = P3;
  84.                 _temp = _temp & 0xF0;
  85.                 if(_temp != 0xF0){
  86.                         _temp = P3;
  87.                         switch(_temp) {
  88.                                 case 0xEB:
  89.                                         key = 8;
  90.                                         break;
  91.                                 case 0xDB:
  92.                                         key = 9;
  93.                                         break;
  94.                                 case 0xBB:
  95.                                         key = 10;
  96.                                         break;
  97.                                 case 0x7B:
  98.                                         key = 11;
  99.                                         break;
  100.                         }
  101.                         while(_temp != 0xF0){
  102.                                 _temp = P3;
  103.                                 _temp = _temp & 0xF0;
  104.                         }
  105.                 }
  106.         }
  107.
  108.         //檢測第四行
  109.         P3 = 0xF7;
  110.         _temp = P3;
  111.         _temp = _temp & 0xF0;
  112.         if(_temp != 0xF0){
  113.                 delayms(10);
  114.                 _temp = P3;
  115.                 _temp = _temp & 0xF0;
  116.                 if(_temp != 0xF0){
  117.                         _temp = P3;
  118.                         switch(_temp) {
  119.                                 case 0xE7:
  120.                                         key = 12;
  121.                                         break;
  122.                                 case 0xD7:
  123.                                         key = 13;
  124.                                         break;
  125.                                 case 0xB7:
  126.                                         key = 14;
  127.                                         break;
  128.                                 case 0x77:
  129.                                         key = 15;
  130.                                         break;
  131.                         }
  132.                         while(_temp != 0xF0){
  133.                                 _temp = P3;
  134.                                 _temp = _temp & 0xF0;
  135.                         }
  136.                 }
  137.         }
  138.
  139. }
  140. void main() {
  141.
  142.         key = 99;
  143.
  144.         while(1) {
  145.                 matrixKeyScan();
  146.
  147.                 switch(key) {
  148.                         case 0:
  149.                                 P2 = 0xFE;
  150.                                 break;
  151.                         case 1:
  152.                                 P2 = 0xFD;
  153.                                 break;
  154.                         case 2:
  155.                                 P2 = 0xFB;
  156.                                 break;
  157.                         case 3:
  158.                                 P2 = 0xF7;
  159.                                 break;
  160.                         case 4:
  161.                                 P2 = 0xEF;
  162.                                 break;
  163.                         case 5:
  164.                                 P2 = 0xDF;
  165.                                 break;
  166.                         case 6:
  167.                                 P2 = 0xBF;
  168.                                 break;
  169.                         case 7:
  170.                                 P2 = 0x7F;
  171.                 }
  172.         }
  173. }
ID:164602 發表于 2019-8-9 08:29 | 顯示全部樓層
給你一個例子程序吧,比你的程序好、實用。
本實例為矩陣鍵盤的實驗
1、按不同的鍵,顯示所按的鍵的數字。其實主要是實驗出按的哪個鍵,程序判斷對不對
   完全可以通過按鍵執行其它任務
2、矩陣鍵盤得到所按哪個鍵的過程相對復雜一點,注意理解。
#include<reg51.h>
#define GPIO_DIG P0//數碼管
#define GPIO_KEY P1//矩陣鍵盤
sbit LSA=P2^2;//數碼管位碼CBA分別為000第一位,001第二位,010第三位
sbit LSB=P2^3;//                   011第四位,100第五位,101第六位
sbit LSC=P2^4;//                                   110第七位,111第八位
unsigned char code DIG_CODE[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
0x77,0x7c,0x39,0x5e,0x79,0x71};//0、1、2、3、4、5、6、7、8、9、A、b、C、d、E、F的顯示碼
unsigned char KeyValue;//用來存放讀取到的鍵值
bit KeyState;        //記錄按鍵的狀態,0沒有,1有
unsigned char DisplayData[8];//用來存放要顯示的8位數的值,一個管分配一個數組
void Delay10ms();   //延時10ms
void KeyDown();                 //檢測按鍵函數
void DigDisplay(); //動態顯示函數
void main(void)
        KeyState=0;//初始化按鍵
                KeyDown();//檢測按鍵
                 if(KeyState==1)//有鍵按下才執行
                        DisplayData[7]=DisplayData[6];//顯示的內容左移一位
                        DisplayData[6]=DisplayData[5];
                        DisplayData[5]=DisplayData[4];
                        DisplayData[4]=DisplayData[3];
                        DisplayData[3]=DisplayData[2];
                        DisplayData[2]=DisplayData[1];
                        DisplayData[1]=DisplayData[0];
                        DisplayData[0]=DIG_CODE[KeyValue];
                        KeyState=0;//顯示完畢要初始化
                DigDisplay();//顯示
* 函 數 名         : DigDisplay
* 函數功能                   : 使用數碼管顯示
* 輸    入         : 無
* 輸    出         : 無
void DigDisplay()
        unsigned char i;
        unsigned int j;
        for(i=0;i<8;i++)//只有8個數碼管
                switch(i)         //位選,選擇點亮的數碼管,
                        case(0):
                                LSA=0;LSB=0;LSC=0; break;//顯示第0位
                        case(1):
                                LSA=1;LSB=0;LSC=0; break;//顯示第1位
                        case(2):
                                LSA=0;LSB=1;LSC=0; break;//顯示第2位
                        case(3):
                                LSA=1;LSB=1;LSC=0; break;//顯示第3位
                        case(4):
                                LSA=0;LSB=0;LSC=1; break;//顯示第4位
                        case(5):
                                LSA=1;LSB=0;LSC=1; break;//顯示第5位
                        case(6):
                                LSA=0;LSB=1;LSC=1; break;//顯示第6位
                        case(7):
                                LSA=1;LSB=1;LSC=1; break;//顯示第7位
                GPIO_DIG=DisplayData[i];//發送段碼
                j=10;                                                 //掃描間隔時間設定
                while(j--);
                GPIO_DIG=0x00;//消隱
* 函 數 名         : KeyDown
* 函數功能                   : 檢測有按鍵按下并讀取鍵值
* 輸    入         : 無
* 輸    出         : 無
void KeyDown(void)//其實最簡單的就是逐行掃描,就不難懂了。這里的行列掃描法有點
                                  //難理解,程序也復雜。
        unsigned char a=0;
        GPIO_KEY=0x0f;//測試列
        if(GPIO_KEY!=0x0f)
                Delay10ms();//此處按鍵消抖,不可在測試列之后,那樣顯示時間不對,亮度很小
                if(GPIO_KEY!=0x0f)
                        KeyState=1;//有按鍵按下
                        switch(GPIO_KEY)
                                case(0X07):        KeyValue=0;break;
                                case(0X0b):        KeyValue=1;break;
                                case(0X0d): KeyValue=2;break;
                                case(0X0e):        KeyValue=3;break;
                        //測試行
                        GPIO_KEY=0Xf0;
                        Delay10ms();//此處延時為了消抖
                        switch(GPIO_KEY)
                                case(0X70):        KeyValue=KeyValue;break;
                                case(0Xb0):        KeyValue=KeyValue+4;break;
                                case(0Xd0): KeyValue=KeyValue+8;break;
                                case(0Xe0):        KeyValue=KeyValue+12;break;
                        while((a<200)&&(GPIO_KEY!=0xf0))//按鍵松手檢測,a的值太小,就會在按下不松
        //手時,產生多次按鍵的結果,現在有2s時間
                                Delay10ms();
                                a++;
                        a=0;
* 函 數 名         : Delay10ms
* 函數功能                   : 延時函數,延時10ms
* 輸    入         : 無
* 輸    出         : 無
void Delay10ms(void)   //誤差 0us
    unsigned char a,b,c;
    for(c=1;c>0;c--)
        for(b=38;b>0;b--)
            for(a=130;a>0;a--);
ID:282095 發表于 2019-8-9 08:52 | 顯示全部樓層
通過按鍵進行掃描矩陣的處理
ID:302534 發表于 2019-8-9 18:48 | 顯示全部樓層
列掃描和豎掃描
