查看: 5436|回復: 1
自制萬用表Proteus仿真(RLC檢測電路+單片機程序)
ID:348634 發表于 2019-8-8 00:10 | 顯示全部樓層 |閱讀模式
自制儀表仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. #include<reg52.h>
  2. #define uchar unsigned char   //宏定義
  3. #define uint  unsigned int
  4. sbit RS=P2^6;                 //液晶控制端口
  5. sbit RW=P2^5;
  6. sbit E=P2^7;
  7. sbit R=P2^2;                  //RLC控制按鍵
  8. sbit C=P2^3;
  9. sbit L=P2^4;
  10. sbit A=P2^0; //控制IO口
  11. sbit B1=P2^1;
  12. sbit jd1=P1^0; //繼電器1
  13. sbit jd2=P1^1; //繼電器2
  14. sbit LED_R=P1^3;                  //RLC指示燈
  15. sbit LED_C=P1^4;
  16. sbit LED_L=P1^5;
  17. uchar code table1[11]={"R=        R"};    //RLC顯示數組
  18. uchar code table2[11]={"C=       pF"};
  19. uchar code table3[11]= {"L=       mH"};
  20. uchar code f_table[88]={13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100};
  21. uchar code f_correct[88]={9,10,11,12,12,12,13,14,15,16,17,18,18,18,19,20,21,21,22,23,24,25,25,26,26,27,28,29,29,30,30,31,32,33,33,34, 35,35,36,37,38,38,39,40,41,41,42,42,43,44,45,45,46,47,48,49,49,50,51,51,52,53,54,54,55,55,56,57,57,58,59,60,60,62,62,63,64,64,65,66,66,67,67,68,69,70,71,71,};
  22. uchar data7,data6,data5,data4,data3,data2,data1;    //數據變量
  23. uchar flag;                                   //轉換完成標志位
  24. unsigned long cnt,cnt1;                       //長整形數據 記錄振蕩器計數的次數
  25. uchar f_cnt;                                  //時間溢出次數變量
  26. //函數聲明
  27. void delay_us();          //us延時
  28. void delay_ms(uint);      //ms延時
  29. void lcd_init();          //1602初始化
  30. void lcd_write_com(uchar com);     //寫命令
  31. void lcd_write_dat(uchar dat);     //寫數據
  32. void lcd_display(uchar add,uchar dat);  //指定地址寫數據
  33. void delay_us()             //us延時
  34. {
  35.         uchar x=6;
  36.         while(x--);
  37. }
  38. void delay_ms(uint aa)       //ms延時
  39. {
  40.         uint x,y;
  41.         for(x=0;x<aa;x++)
  42.                 for(y=0;y<110;y++);
  43. }
  44. void lcd_write_com(uchar com)    //寫命令
  45. {
  46.   E=0;
  47.   RS=0;
  48.   RW=0;
  49.   delay_us();
  50.   P0=com;
  51.   E=1;
  52.   delay_us();
  53.   E=0;
  54. }
  55. void lcd_write_dat(uchar dat)     //寫數據
  56. {
  57.   E=0;
  58.   RS=1;
  59.   RW=0;
  60.   delay_us();
  61.   P0=dat;
  62.   E=1;
  63.   delay_us();
  64.   E=0;
  65. }
  66. void lcd_init()                  //lcd初始化
  67. {
  68.    delay_ms(10);
  69.    lcd_write_com(0x38);         //設置顯示模式
  70.    delay_ms(10);
  71.    lcd_write_com(0x0c);
  72.          lcd_write_com(0x06);
  73.          lcd_write_com(0x01);        //清屏指令
  74.          delay_ms(2);
  75. }
  76. void timer_init(void)  //定時器初始化函數
  77. {
  78.         TMOD=0X51;          //設置定時器工作模式
  79.         PT0=1;
  80.         TH0=0x3c;           //給定時器0裝設初值 50ms
  81.         TL0=0xb0;
  82.         TH1=0;              //不設初值
  83.         TL1=0;
  84.         ET0=1;              //開中斷
  85.         ET1=1;
  86.         TR0=1;              //開定時器
  87.         TR1=1;
  88.         EA=1;               //開總中斷
  89. }
  90. void lcd_display(uchar add,uchar dat)           //lcd指定地址寫數據
  91. {
  92.         lcd_write_com(add);
  93.         lcd_write_dat(dat);
  94.         delay_us();
  95. }
  96. void real_display(void)                        //數據顯示函數
  97. {
  98.   if(!R)                                        //檢測的是電阻
  99.    {
  100.       A=0;B1=0;
  101.                         LED_R=0;
  102.       LED_L=1;
  103.       LED_C=1;
  104.                         lcd_display(0x80,table1[0]);
  105.                         lcd_display(0x80+1,table1[1]);
  106.                         lcd_display(0x80+9,table1[9]);
  107.                         lcd_display(0x80+10,table1[10]);
  108.    }
  109.    else
  110.           if(!C)                                        //檢測的是電容
  111.      {
  112.         A=1;B1=0;
  113.        LED_C=0;
  114.        LED_L=1;
  115.        LED_R=1;
  116.        lcd_display(0x80,table2[0]);
  117.        lcd_display(0x80+1,table2[1]);
  118.        lcd_display(0x80+9,table2[9]);
  119.        lcd_display(0x80+10,table2[10]);
  120.      }
  121.       else
  122.          if(!L)                                           //檢測的是電感
  123.      {
  124.          A=0;B1=1;
  125.         LED_L=0;
  126.         LED_R=1;
  127.         LED_C=1;
  128.         lcd_display(0x80,table3[0]);
  129.                                 lcd_display(0x80+1,table3[1]);
  130.                                 lcd_display(0x80+9,table3[9]);
  131.                                 lcd_display(0x80+10,table3[10]);
  132.      }
  133.                  else
  134.      {
  135.                    LED_L=1;
  136.        LED_R=1;
  137.        LED_C=1;
  138.                  }
  139.                 if(data7)
  140.      lcd_display(0x80+2,0x30+data7);         //最高位數據不等于零就顯示
  141.     else
  142.      lcd_display(0x80+2,' ');             //否則顯示空格     以下同樣
  143.     if(data7||data6)
  144.      lcd_display(0x80+3,0x30+data6);         //最高位數據不等于零就顯示
  145.     else
  146.      lcd_display(0x80+3,' ');             //否則顯示空格     以下同樣
  147.     if(data7||data6||data5)
  148.      lcd_display(0x80+4,0x30+data5);
  149.     else
  150.      lcd_display(0x80+4,' ');
  151.     if(data7||data6||data5||data4)
  152.      lcd_display(0x80+5,0x30+data4);
  153.     else
  154.      lcd_display(0x80+5,' ');
  155.     if(data7||data6||data5||data4||data3)
  156.      lcd_display(0x80+6,0x30+data3);
  157.     else
  158.      lcd_display(0x80+6,' ');
  159.     if(data7||data6||data5||data4||data3||data2)
  160.      lcd_display(0x80+7,0x30+data2);
  161.     else
  162.      lcd_display(0x80+7,' ');
  163.      lcd_display(0x80+8,0x30+data1);       //顯示最低位
  164. }
  165. void correct(void)                   //誤差修正函數
  166. {
  167.   uchar i,k;
  168.         unsigned long wucha;
  169.         if(cnt<100000)                     //修正頻率范圍
  170.          {
  171.                  if(cnt>980&&cnt<2100)           //在不同頻率對數據進行修改 經驗值 資料參考
  172.                         cnt-=1;
  173.                  if(cnt>=2100&&cnt<3900)
  174.                         cnt-=2;
  175.                  if(cnt>=3900&&cnt<4800)
  176.                         cnt-=3;
  177.                  if(cnt>=4800&&cnt<5700)
  178.                         cnt-=4;
  179.                  if(cnt>=5700&&cnt<8000)
  180.                         cnt-=5;
  181.                  if(cnt>=8000&&cnt<9100)
  182.                         cnt-=6;
  183.                  if(cnt>=9100&&cnt<10900)
  184.                         cnt-=7;
  185.                  if(cnt>=10900&&cnt<11900)
  186.                         cnt-=8;
  187.                  if(cnt>=11900&&cnt<13000)
  188.                         cnt-=9;
  189.                  if(cnt>=13000&&cnt<=100000)
  190.                          {
  191.                                  k=cnt/1000;
  192.                                  for(i=0;i<88;i++)
  193.                                         {
  194.                                                         if(k==f_table[i])
  195.                                                         {
  196.                                                          cnt-=f_correct[i];
  197.                                                         }
  198.                                         }
  199.                          }
  200.   }
  201.          if(cnt>100000)
  202.          {
  203.                 wucha=(cnt/1000)*73065/100000;
  204.                 cnt-=wucha;
  205.          }
  206. }
  207. void main()
  208. {
  209.         jd2=0;
  210.         timer_init();             //定時器初始化
  211.         lcd_init();               //液晶初始化
  212.         if(!C)                                        //檢測的是電容
  213.      {
  214.         A=1;B1=0;
  215.                  }else
  216.                  if(!R)                                        //檢測的是電阻
  217.    {
  218.       A=0;B1=0;
  219.          }else
  220.          if(!L)                                           //檢測的是電感
  221.      {
  222.          A=0;B1=1;
  223.                  }
  224.   while(1)
  225.   {
  226.                 if(flag==1)             //數據轉化完成
  227.                 {
  228.                          real_display();       //數據處理并顯示
  229.                          flag=0;
  230.                 }
  231.   }
  232. }
  233. void timer0() interrupt 1          //定時器0中斷函數
  234. {
  235.         uchar timer0;
  236.         TH0=0x3c;          //50ms定時
  237.         TL0=0xb0;
  238.         timer0++;          //時間變量
  239.         if(timer0==20)     //1s進入一次
  240.          {
  241.                 timer0=0;
  242.                 TR1=0;                        //定時器1中斷關閉
  243.                 EA=0;                         //總中斷關閉
  244.                 cnt=TL1+TH1*256+f_cnt*65536;  //計算1S計數的個數
  245.                 correct();                   //修正一下數據
  246.                 cnt1=(1e+9)/(2*0.693 *cnt)-20000/2;  //如果開關都不按下 計算數值并且顯示
  247.         if(!R)
  248.         {
  249.                  A=0;B1=0;
  250.                 cnt1=(500000/(0.2*0.693*cnt))-120;    //計算電阻值 R1=T/(ln2*C-2R2)  此處電容200uf (ln2=0.693)
  251.         }                                      //1000000us=1s   此處是修正好的數據
  252.         else
  253.         if(!C)
  254.         {
  255.                  A=1;B1=0;
  256.                 cnt1=100000000/(0.693*3*510*cnt);   //計算電容值 C=T/((R1+2R2)ln2) 此處        R1=R2=5100
  257.         }
  258.         else
  259.         if(!L)
  260.         {
  261.      A=0;B1=1;
  262.                 cnt1=(1e+9)/(4*3.14*3.14*cnt*cnt*0.0463);  //計算電感值  L=T/(4*3.14*3.14*C)  C=(C1+C2)/(C1*2C)  電容三點式
  263.         }
  264.         if(!R)
  265.         {
  266.    if(cnt1>1000)
  267.          {
  268.            jd1=1;
  269.          }
  270.          else
  271.          {jd1=0;}
  272.          }
  273.         if(!C)
  274.         {
  275.    if(cnt1>1000)
  276.          {
  277.            jd2=1;
  278.          }
  279.          else
  280.          {jd2=0;}
  281.          }
  282.     data7=cnt1/1000000;
  283.                 data6=cnt1%1000000/100000;          //將數據的各位取出
  284.                 data5=cnt1%100000/10000;
  285.                 data4=cnt1%10000/1000;
  286.                 data3=cnt1%1000/100;
  287.                 data2=cnt1%100/10;
  288.                 data1=cnt1%10;
  289.                 flag=1;                    //測量完成標志位
  290.                 TH1=0;                     //給定時器裝設初始值 T0 T1
  291.                 TL1=0;
  292.                 TH0=0x3c;                  //定時器0裝設初值  50ms
  293.                 TL0=0xb0;
  294.                 cnt=0;                     //記錄時間清零
  295.                 f_cnt=0;                   //記錄時間清零
  296.                 EA=1;                      //打開總中斷
  297.                 TR1=1;                     //打開定時器1中斷
  298.         }
  299. }
  300. void int1() interrupt 3        // 定時器1中斷函數 計算時間(溢出次數)
  301. {
  302.   f_cnt++;
  303. }
仿真(RLC檢測電路).zip (275.26 KB, 下載次數: 125)
ID:727862 發表于 2020-4-15 16:13 | 顯示全部樓層
用的仿真軟件不是proteus??
