查看: 2625|回復: 0
51單片機矩陣按鍵點陣顯示程序
ID:596979 發(fā)表于 2019-8-7 17:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "reg52.h"
unsigned char smg[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
sbit a=P2^2;
sbit b=P2^3;
sbit c=P2^4;
#define smgled P0
#define keynumber P1
unsigned char backvalue;
void delay(unsigned int i)
while(i--);
void scan(void)
    unsigned int k=0;
        keynumber=0x0f;
        if(keynumber!=0x0f)
        delay(1000);
        keynumber=0x0f;
        switch(keynumber)
        case(0x07):backvalue=0;break;
        case(0x0b):backvalue=1;break;
        case(0x0d):backvalue=2;break;
        case(0x0e):backvalue=3;break;
        keynumber=0xf0;
        switch(keynumber)
        case(0x70):backvalue=backvalue;break;
        case(0xb0):backvalue=backvalue+4;break;
        case(0xd0):backvalue=backvalue+8;break;
        case(0xe0):backvalue=backvalue+12;break;
  while((k<50)&&(keynumber!=0xf0))
   delay(1000);
   k++;
a=0;
b=0;
c=0;
scan();
smgled=smg[backvalue];
說明:
矩陣按鍵顯示前4位按下點陣顯示不同漢字,后12為顯示X
