查看: 2544|回復: 1
我這個msp430f169測頻率一直顯示65535Hz,怎么改,大佬幫忙看一下
ID:593810 發表于 2019-8-5 16:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
10黑幣
msp430f169 測量頻率
#include  <msp430x16x.h>
#define uint  unsigned int
void delay(void);
void InitSys();
//void ClearLCD(void);
extern const unsigned char shuzi_table[];
#define LCD_DataIn    P5DIR=0x00    //數據口方向設置為輸入
#define LCD_DataOut   P5DIR=0xff    //數據口方向設置為輸出
#define LCD2MCU_Data  P5IN
#define MCU2LCD_Data  P5OUT
#define LCD_CMDOut    P4DIR|=0x0F     //P3口的低三位設置為輸出
#define LCD_RS_H      P4OUT|=BIT0      //P3.0
#define LCD_RS_L      P4OUT&=~BIT0     //P3.0
#define LCD_RW_H      P4OUT|=BIT1      //P3.1
#define LCD_RW_L      P4OUT&=~BIT1     //P3.1
#define LCD_EN_H      P4OUT|=BIT2      //P3.2
#define LCD_EN_L      P4OUT&=~BIT2     //P3.2
#define LCD_PSB_P     P4OUT|=BIT3      //3.3
#define LCD_PSB_S     P4OUT&=~BIT3     //3.3
void Delay_1ms(void);
void Delay(unsigned int n);
void Write_Cmd(unsigned char cod);
void Write_Data(unsigned char dat);
void Ini_Lcd(void);
void Disp_HZ(unsigned char addr,const unsigned char * pt,unsigned char num);
void Disp_ND(unsigned char addr,unsigned int  thickness);
void Draw_TX(unsigned char Yaddr,unsigned char Xaddr,const unsigned char * dp) ;
void Draw_PM(const unsigned char *ptr);
//void ADC12(void);
void Clock_Init(void);
uint start,end;
uint width; //==用于存放脈寬==
uint period; //==用于存放周期==
uint frequency; //==用于存放頻率==
uint fy[7]; //==用于存放頻率顯示數據==
uint pd[7]; //==用于存放周期顯示數據==
uint wh[6]; //==用于存放脈寬顯示數據==
const unsigned char zhouqi[]={"周期為:(us) "};
const unsigned char us[]={"us "};
const unsigned char pinlv[]={"頻率為:(Hz) "};
const unsigned char hz[]={"HZ "};
void process(void);
/***************************主函數*************************/
void main( void )
   WDTCTL = WDTPW + WDTHOLD; //==關狗==
  InitSys(); //==初始化時鐘,SMCLK,MCLK均為8M==
  P1DIR&=~BIT2;
  P1SEL = BIT2; //==設置P1.2端口為功能模塊使用,即:做捕獲源==
  TACTL = TASSEL_2+ID_3+TACLR+TAIE+MC_1;//==定時器A時鐘信號選擇SMCLK,8分頻,同時設置定時器A計數模式為連續增計模式==
  CCTL1 = CM_1+SCS+CAP+CCIE; //==輸入上升沿捕獲,CCI0A為捕獲信號源==
  _EINT(); //==開全局中斷允許==
  //_BIS_SR(LPM0_bits+GIE);
   Ini_Lcd(); //==初始化液晶==
   //Clear_GDRAM(); //==清屏==
   Disp_HZ(0x80,zhouqi,6);
    Disp_HZ(0x88,pinlv,6);
        process();
        Write_Cmd(0x90);//==寫地址==
        Write_Data(pd[6]+0x30);
        Write_Data(pd[5]+0x30);
        Write_Data(pd[4]+0x30);
        Write_Data(pd[3]+0x30);
        Write_Data(pd[2]+0x30);
        Write_Data(pd[1]+0x30);
        Write_Data(pd[0]+0x30);
        Write_Cmd(0x98);//==寫地址==
        Write_Data(fy[6]+0x30);
        Write_Data(fy[5]+0x30);
        Write_Data(fy[4]+0x30);
        Write_Data(fy[3]+0x30);
        Write_Data(fy[2]+0x30);
        Write_Data(fy[1]+0x30);
        Write_Data(fy[0]+0x30);
        delay();
void InitSys()
   unsigned int i;
//--- 使用XT2振蕩器 ---
   BCSCTL1&=~XT2OFF; //==打開XT2振蕩器==
   do
     IFG1 &= ~OFIFG; //==清除振蕩器失效標志==
     for (i = 0xFF; i > 0; i--); //==延時,等待XT2起振==
  while ((IFG1 & OFIFG) != 0); //==判斷XT2是否起振==
  BCSCTL2 =SELM_2+SELS; //==選擇MCLK、SMCLK為XT2,8M==
  //ADC12CTL0 |=ENC+ADC12SC;//使能轉換;開始轉換
void process(void)
  while(end<start);
   //while(end<start)的話就讓其一直等待下去,直到end>start
    //width =10000/(end-start); //實際脈沖寬度的計算
    period =2*width;
    frequency=1000000/period;
    pd[6]=period/1000000;
    pd[5]=(period-1000000*pd[6])/100000;
    pd[4]=(period-1000000*pd[6]-100000*pd[5])/10000;
    pd[3]=(period-1000000*pd[6]-100000*pd[5]-10000*pd[4])/1000;
    pd[2]=(period-1000000*pd[6]-100000*pd[5]-10000*pd[4]-1000*pd[3])/100;
    pd[1]=(period-1000000*pd[6]-100000*pd[5]-10000*pd[4]-1000*pd[3]-100*pd[2])/10;
    pd[0]=period%10;
    fy[6]=frequency/1000000;
    fy[5]=(frequency-1000000*fy[6])/100000;
    fy[4]=(frequency-1000000*fy[6]-100000*fy[5])/10000;
    fy[3]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4])/1000;
    fy[2]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4]-1000*fy[3])/100;
    fy[1]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4]-1000*fy[3]-100*fy[2])/10;
    fy[0]=frequency%10;
#pragma vector=TIMERA1_VECTOR //==定時器A中斷處理==
__interrupt void timer_A1(void)
  uint temp;
  switch(TAIV) //==向量查詢==
  { case 2: //==捕獲中斷==
       if(CCTL1&CM0) //==捕獲到上升沿==
            CCTL1=(CCTL1&(~CM0))|CM1; //==更變設置為下降沿觸發==
            temp=TAR; //==記錄初始時間==
            period=temp-start;
            start=temp;
       else if (CCTL1&CM1) //==捕獲到下降沿==
           CCTL1=(CCTL1&(~CM1))|CM0; //==更變設置為上升沿觸發==
           end=TAR; //==用start,end,overflow計算脈沖寬度==
           width =end-start;
        break;
    default:break;
函數名稱:Delay_1ms
功    能:延時約1ms的時間
參    數:無
返回值  :無
        uchar i;
        for(i = 150;i > 0;i--)  _NOP();
函數名稱:Delay_Nms
功    能:延時N個1ms的時間
參    數:n--延時長度
返回值  :無
void Delay_Nms(uint n)
    uint i;
    for(i = n;i > 0;i--)    Delay_1ms();
函數名稱:Write_Cmd
功    能:向液晶中寫控制命令
參    數:cmd--控制命令
返回值  :無
void Write_Cmd(uchar cmd)
    uchar lcdtemp = 0;
    LCD_RS_L;
    LCD_RW_H;
    LCD_DataIn;
    do                       //判忙
        LCD_EN_H;
               _NOP();
               lcdtemp = LCD2MCU_Data;
               LCD_EN_L;
    while(lcdtemp & 0x80);
    LCD_DataOut;
    LCD_RW_L;
    MCU2LCD_Data = cmd;
    LCD_EN_H;
    _NOP();
    LCD_EN_L;
函數名稱:Write_Data
功    能:向液晶中寫顯示數據
參    數:dat--顯示數據
返回值  :無
void  Write_Data(uchar dat)
    uchar lcdtemp = 0;
    LCD_RS_L;
    LCD_RW_H;
    LCD_DataIn;
    do                       //判忙
        LCD_EN_H;
        _NOP();
        LCD_EN_L;
    LCD_DataOut;
    LCD_RS_H;
    LCD_RW_L;
    MCU2LCD_Data = dat;
    LCD_EN_H;
    _NOP();
    LCD_EN_L;
函數名稱:Ini_Lcd
功    能:初始化液晶模塊
參    數:無
返回值  :無
void Ini_Lcd(void)
    LCD_CMDOut;    //液晶控制端口設置為輸出
    Delay_Nms(500);
    Write_Cmd(0x30);   //基本指令集
    Delay_1ms();
    Write_Cmd(0x02);   // 地址歸位
    Delay_1ms();
        Write_Cmd(0x0c);   //整體顯示打開,游標關閉
    Delay_1ms();
        Write_Cmd(0x01);   //清除顯示
    Delay_1ms();
        Write_Cmd(0x06);   //游標右移
    Delay_1ms();
        Write_Cmd(0x80);   //設定顯示的起始地址
函數名稱:Disp_HZ
功    能:控制液晶顯示漢字
參    數:addr--顯示位置的首地址
          pt--指向顯示數據的指針
          num--顯示字符個數
返回值  :無
void Disp_HZ(uchar addr,const uchar * pt,uchar num)
    uchar i;
    Write_Cmd(addr);
           for(i = 0;i < (num*2);i++)
        Write_Data(*(pt++));
  uchar i;
  BCSCTL1&=~XT2OFF;                 //打開XT振蕩器
  BCSCTL2|=SELM1+SELS;              //MCLK為8MHZ,SMCLK為8MHZ
  do{
      IFG1&=~OFIFG;                   //清除震蕩標志
      for(i=0;i<100;i++)
      _NOP();                      //延時等待
  while((IFG1&OFIFG)!=0);           //如果標志為1,則繼續循環等待
  IFG1&=~OFIFG;
void delay(void)
  unsigned int i,j;
  for(i=0;i<100;i--)
    for(j=0;j<100;j--);
ID:290305 發表于 2019-8-6 17:00 | 只看該作者
因為你定義frequency時用的是uint,而你的uint是用unsigned int宏定義的,他的取值范圍為0—65536,所以你最大的顯示數為65536,你可以把frequency用u32定義就可以了
