沒有搜到8針的oled,這個是我自己用的,僅供參考。
- #include <intrins.h>
- #include <STC8.H>
- sbit lcd_sclk=P5^0; /*接口定義:lcd_sclk就是CLK*/
- sbit lcd_sid=P5^1; /*接口定義:lcd_sid就是MOSI*/
- sbit lcd_rs=P5^2; /*接口定義:lcd_rs就是DC*/
- sbit lcd_cs1=P5^3; /*接口定義:lcd_cs1就是OLED的片選CS1*/
- sbit Rom_OUT=P5^4; /*字庫IC接口定義:Rom_OUT就是FSO*/
- sbit Rom_CS=P5^5; /*字庫IC接口定義Rom_CS就是字庫IC的CS2*/
- unsigned char code ASCII[] = {'0','1','2','3','4','5','6','7','8','9'};
- #define uchar unsigned char
- #define uint unsigned int
- #define ulong unsigned long
- uchar code bmp1[];
- /*寫指令到LCD模塊*/
- void transfer_command_lcd(int data1)
- char i;
- lcd_rs=0;
- lcd_sclk=0;
- for(i=0;i<8;i++)
- if(data1&0x80) lcd_sid=1;
- else lcd_sid=0;
- lcd_sclk=1;
- _nop_();
- lcd_sclk=0;
- data1<<=1;
- /*寫數據到LCD模塊*/
- void transfer_data_lcd(int data1)
- char i;
- lcd_rs=1;
- lcd_sclk=0;
- for(i=0;i<8;i++)
- else lcd_sid=0;
- lcd_sclk=1;
- _nop_();
- lcd_sclk=0;
- data1<<=1;
- /*延時*/
- void delay(int n_ms)
- int j,k;
- for(j=0;j<n_ms;j++)
- for(k=0;k<110;k++);
- /*等待一個按鍵,我的主板是用P2.0與GND之間接一個按鍵*/
- //void waitkey()
- // repeat:
- // if (P2&0x01) goto repeat;
- // else delay(6);
- // else
- // delay(40);;
- /*LCD模塊初始化*/
- void initial_lcd()
- lcd_cs1=0;
- Rom_CS = 1;
- // lcd_reset=0; /*低電平復位*/
- delay(20);
- //lcd_reset=1; /*復位完畢*/
- delay(20);
- transfer_command_lcd(0xAE); //display off
- transfer_command_lcd(0x20); //Set Memory Addressing Mode
- transfer_command_lcd(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
- transfer_command_lcd(0xb0); //Set Page Start Address for Page Addressing Mode,0-7
- transfer_command_lcd(0xc8); //Set COM Output Scan Direction
- transfer_command_lcd(0x00);//---set low column address
- transfer_command_lcd(0x10);//---set high column address
- transfer_command_lcd(0x40);//--set start line address
- transfer_command_lcd(0x81);//--set contrast control register
- transfer_command_lcd(0x7f);
- transfer_command_lcd(0xa1);//--set segment re-map 0 to 127
- transfer_command_lcd(0xa6);//--set normal display
- transfer_command_lcd(0xa8);//--set multiplex ratio(1 to 64)
- transfer_command_lcd(0x3F);//
- transfer_command_lcd(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
- transfer_command_lcd(0xd3);//-set display offset
- transfer_command_lcd(0x00);//-not offset
- transfer_command_lcd(0xd5);//--set display clock divide ratio/oscillator frequency
- transfer_command_lcd(0xf0);//--set divide ratio
- transfer_command_lcd(0xd9);//--set pre-charge period
- transfer_command_lcd(0x22); //
- transfer_command_lcd(0xda);//--set com pins hardware configuration
- transfer_command_lcd(0x12);
- transfer_command_lcd(0xdb);//--set vcomh
- transfer_command_lcd(0x20);//0x20,0.77xVcc
- transfer_command_lcd(0x8d);//--set DC-DC enable
- transfer_command_lcd(0x14);//
- transfer_command_lcd(0xaf);//--turn on oled panel
- lcd_cs1=1;
- void lcd_address(uchar page,uchar column)
- transfer_command_lcd(0xb0 + column); /*設置頁地址*/
- transfer_command_lcd(((page & 0xf0) >> 4) | 0x10); /*設置列地址的高4位*/
- transfer_command_lcd((page & 0x0f) | 0x00); /*設置列地址的低4位*/
- /*全屏清屏*/
- void clear_screen()
- unsigned char i,j;
- lcd_cs1=0;
- Rom_CS = 1;
- for(i=0;i<8;i++)
- transfer_command_lcd(0xb0+i);
- for(j=0;j<128;j++)
- transfer_data_lcd(0x00);
- lcd_cs1=1;
- /*顯示128x64點陣圖像*/
- //void display_128x64(uchar *dp)
- // uint i,j;
- // lcd_cs1=0;
- // for(j=0;j<8;j++)
- // lcd_address(0,j);
- // for (i=0;i<128;i++)
- // transfer_data_lcd(*dp); /*寫數據到LCD,每寫完一個8位的數據后列地址自動加1*/
- // dp++;
- // lcd_cs1=1;
- /*顯示16x16點陣圖像、漢字、生僻字或16x16點陣的其他圖標*/
- void display_graphic_16x16(uint page,uint column,uchar *dp)
- uint i,j;
- lcd_cs1=0;
- Rom_CS = 1;
- for(j=2;j>0;j--)
- lcd_address(column,page);
- for (i=0;i<16;i++)
- transfer_data_lcd(*dp); /*寫數據到LCD,每寫完一個8位的數據后列地址自動加1*/
- dp++;
- page++;
- lcd_cs1=1;
- /*顯示8x16點陣圖像、ASCII, 或8x16點陣的自造字符、其他圖標*/
- void display_graphic_8x16(uint page,uchar column,uchar *dp)
- uint i,j;
- lcd_cs1=0;
- for(j=2;j>0;j--)
- for (i=0;i<8;i++)
- dp++;
- page++;
- lcd_cs1=1;
- /*顯示5*7點陣圖像、ASCII, 或5x7點陣的自造字符、其他圖標*/
- //void display_graphic_5x7(uint page,uchar column,uchar *dp)
- // uint col_cnt;
- // uchar page_address;
- // uchar column_address_L,column_address_H;
- // page_address = 0xb0+page-1;
- // lcd_cs1=0;
- // column_address_L =(column&0x0f)-1;
- // column_address_H =((column>>4)&0x0f)+0x10;
- // transfer_command_lcd(page_address); /*Set Page Address*/
- // transfer_command_lcd(column_address_H); /*Set MSB of column Address*/
- // transfer_command_lcd(column_address_L); /*Set LSB of column Address*/
- // for (col_cnt=0;col_cnt<6;col_cnt++)
- // dp++;
- // lcd_cs1=1;
- /****送指令到億陽字庫IC***/
- void send_command_to_ROM( uchar datu )
- uchar i;
- for(i=0;i<8;i++ )
- if(datu&0x80)
- lcd_sid = 1;
- else
- lcd_sid = 0;
- datu = datu<<1;
- lcd_sclk=0;
- lcd_sclk=1;
- /****從億陽字庫IC中取漢字或字符數據(1個字節)***/
- static uchar get_data_from_ROM( )
- uchar i;
- uchar ret_data=0;
- lcd_sclk=1;
- for(i=0;i<8;i++)
- Rom_OUT=1;
- lcd_sclk=0;
- ret_data=ret_data<<1;
- if( Rom_OUT )
- ret_data=ret_data+1;
- else
- ret_data=ret_data+0;
- lcd_sclk=1;
- return(ret_data);
- /*從相關地址(addrHigh:地址高字節,addrMid:地址中字節,addrLow:地址低字節)中連續讀出DataLen個字節的數據到 pBuff的地址*/
- /*連續讀取*/
- void get_n_bytes_data_from_ROM(uchar addrHigh,uchar addrMid,uchar addrLow,uchar *pBuff,uchar DataLen )
- uchar i;
- Rom_CS = 0;
- lcd_cs1=1;
- lcd_sclk=0;
- send_command_to_ROM(0x03);
- send_command_to_ROM(addrHigh);
- send_command_to_ROM(addrMid);
- send_command_to_ROM(addrLow);
- for(i = 0; i < DataLen; i++ )
- *(pBuff+i) =get_data_from_ROM();
- Rom_CS = 1;
- /*顯示坐標*/
- ulong fontaddr=0;
- void display_GB2312_string(uchar y,uchar x,uchar *text)//y為行地址 x為點陣像素漢字為16,ASCII碼符號為8
- uchar i= 0;
- uchar addrHigh,addrMid,addrLow ;
- uchar fontbuf[32];
- while((text[i]>0x00))
- if(((text[i]>=0xb0) &&(text[i]<=0xf7))&&(text[i+1]>=0xa1))
- /*國標簡體(GB2312)漢字在億陽字庫IC中的地址由以下公式來計算:*/
- /*Address = ((MSB - 0xB0) * 94 + (LSB - 0xA1)+ 846)*32+ BaseAdd;BaseAdd=0*/
- /*由于擔心8位單片機有乘法溢出問題,所以分三部取地址*/
- fontaddr = (text[i]- 0xb0)*94;
- fontaddr += (text[i+1]-0xa1)+846;
- fontaddr = (ulong)(fontaddr*32);
- addrHigh = (fontaddr&0xff0000)>>16; /*地址的高8位,共24位*/
- addrMid = (fontaddr&0xff00)>>8; /*地址的中8位,共24位*/
- addrLow = fontaddr&0xff; /*地址的低8位,共24位*/
- get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,32 );/*取32個字節的數據,存到"fontbuf[32]"*/
- display_graphic_16x16(y,x,fontbuf);/*顯示漢字到LCD上,y為頁地址,x為列地址,fontbuf[]為數據*/
- i+=2;
- x+=16;
- else if(((text[i]>=0xa1) &&(text[i]<=0xa3))&&(text[i+1]>=0xa1))
- /*國標簡體(GB2312)15x16點的字符在億陽字庫IC中的地址由以下公式來計算:*/
- /*Address = ((MSB - 0xa1) * 94 + (LSB - 0xA1))*32+ BaseAdd;BaseAdd=0*/
- fontaddr = (text[i]- 0xa1)*94;
- fontaddr += (text[i+1]-0xa1);
- i+=2;
- x+=16;
- else if((text[i]>=0x20) &&(text[i]<=0x7e))
- unsigned char fontbuf[16];
- fontaddr = (text[i]- 0x20);
- fontaddr = (unsigned long)(fontaddr*16);
- fontaddr = (unsigned long)(fontaddr+0x3cf80);
- get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,16 );/*取16個字節的數據,存到"fontbuf[32]"*/
- display_graphic_8x16(y,x,fontbuf);/*顯示8x16的ASCII字到LCD上,y為頁地址,x為列地址,fontbuf[]為數據*/
- i+=1;
- x+=8;
- else
- i++;
- //void display_string_5x7(uchar y,uchar x,uchar *text)
- // unsigned char i= 0;
- // unsigned char addrHigh,addrMid,addrLow ;
- // while((text[i]>0x00))
- // if((text[i]>=0x20) &&(text[i]<=0x7e))
- // unsigned char fontbuf[8];
- // fontaddr = (text[i]- 0x20);
- // fontaddr = (unsigned long)(fontaddr*8);
- // fontaddr = (unsigned long)(fontaddr+0x3bfc0);
- // addrHigh = (fontaddr&0xff0000)>>16;
- // addrMid = (fontaddr&0xff00)>>8;
- // addrLow = fontaddr&0xff;
- // get_n_bytes_data_from_ROM(addrHigh,addrMid,addrLow,fontbuf,8);/*取8個字節的數據,存到"fontbuf[32]"*/
- // display_graphic_5x7(y,x,fontbuf);/*顯示5x7的ASCII字到LCD上,y為頁地址,x為列地址,fontbuf[]為數據*/
- // i+=1;
- // x+=6;
- // else
- // i++;
- void xianshiyiwei (uchar y,uchar x,uchar i) //顯示一個字符
- uchar j[4];
- j[0]=ASCII[i];
- display_GB2312_string(y,x,j);
- void displaynum (uchar y,uchar x,uint num)//顯示一串字符
- if(1000<=num&&num<=9999)
- xianshiyiwei(y,x,num%10000/1000);
- xianshiyiwei(y,x+8,num%1000/100);
- xianshiyiwei(y,x+16,num%100/10);
- xianshiyiwei(y,x+24,num%10);
- if(100<=num&&num<=999)
- xianshiyiwei(y,x,num%1000/100);
- xianshiyiwei(y,x+8,num%100/10);
- xianshiyiwei(y,x+16,num%10);
- if(10<=num&&num<=99)
- xianshiyiwei(y,x,num%100/10);
- xianshiyiwei(y,x+8,num%10);
- if(0<=num&&num<=9)
- xianshiyiwei(y,x,num);
復制代碼 全部資料51hei下載地址:
ADC_OLED.zip
(53.12 KB, 下載次數: 51)
2019-8-5 09:54 上傳
