查看: 4357|回復(fù): 0
用visio簡(jiǎn)單做一個(gè)倒計(jì)時(shí)器 附程序源代碼
用visio studio 2012簡(jiǎn)單學(xué)習(xí)上位機(jī)的做法,做了一個(gè)簡(jiǎn)單的倒計(jì)時(shí)器。有進(jìn)度條和提示框,大家互相學(xué)習(xí)。
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace 阿三
    public partial class Form1 : Form
        int count,time;
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            int i;
            for (i = 0; i < 100; i++)
                comboBox1.Items.Add(i.ToString()+" 秒");
            label3.Text = " ";
        private void timer1_Tick(object sender, EventArgs e)
            count++;
            label3.Text=(time-count).ToString()+"秒";
            progressBar1.Value = count;
            if (count == time)
                timer1.Stop();
                System.Media.SystemSounds.Asterisk.Play();
                MessageBox.Show("時(shí)間到了!", "提示");
                count = 0;
        private void button1_Click(object sender, EventArgs e)
            string str=comboBox1.Text;
            time = Convert.ToInt16(str.Substring(0, 2));
            progressBar1.Maximum = time;
            timer1.Start();
上位機(jī)1.0.zip
53.4 KB, 下載次數(shù): 8, 下載積分: 黑幣 -5
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
