查看: 1401|回復: 0
12864液晶屏顯示超聲波程序
ID:535628 發表于 2019-7-30 08:55 | 顯示全部樓層 |閱讀模式
  1. #include   <reg52.h>
  2. #include   <intrins.h>
  3. /************????**************/
  4.     sbit     RX    =  P3 ^ 1; //ECH0
  5.     sbit     TX    =  P3 ^ 0;//TRIG
  6.     sbit     CS    =  P2 ^ 0;
  7.     sbit     SID   =  P2 ^ 1;        //RW
  8.     sbit     SCLK  =  P2 ^ 3;        //E
  9. /*************????**************/
  10. void Lcd_init(void);
  11. void Write_char(bit start, unsigned char ddata);
  12. void Send_byte(unsigned char bbyte);
  13. void Delaynms(unsigned int di);
  14. void Clr_Scr(void);
  15. void LCD_set_xy( unsigned char x, unsigned char y );
  16. void LCD_Write_string(unsigned char X,unsigned char Y,unsigned char *s);
  17. void LCD_Write_number(unsigned char s);
  18. void Lcd_Mark2(void);
  19. void Conut(void);
  20. void delayms(unsigned int ms);
  21. void  StartModule();
  22. unsigned char code num[]={"0123456789 :.-"};
  23. unsigned char code Q[] ={"ǰ:"};
  24. unsigned char code CM[] =  {"m"};
  25. unsigned int  time=0;
  26.          long S=0;
  27.          bit  flag =0;
  28. unsigned char disbuff[4]={ 0,0,0,0,};
  29. /**************************************************************/
  30. void Lcd_init(void)
  31. {
  32.         Delaynms(10);
  33.           CS=1;
  34.           Write_char(0,0x30);
  35.           Write_char(0,0x0c);
  36.           Write_char(0,0x01);
  37. }
  38. /***************************************************************/
  39. void Write_char(bit start, unsigned char ddata)
  40. {
  41.         unsigned char start_data,Hdata,Ldata;
  42.           if(start==0)
  43.                 start_data=0xf8;
  44.     else
  45.             start_data=0xfa;
  46.           Hdata=ddata&0xf0;
  47.           Ldata=(ddata<<4)&0xf0;
  48.           Send_byte(start_data);
  49.           Delaynms(5);
  50.           Send_byte(Hdata);
  51.           Delaynms(1);
  52.           Send_byte(Ldata);
  53.           Delaynms(1);
  54. }
  55. /***************************************************************/
  56. void Send_byte(unsigned char bbyte)
  57. {
  58.         unsigned char i;
  59.         for(i=0;i<8;i++)
  60.            {
  61.                    SID=bbyte&0x80;
  62.                 SCLK=1;
  63.                    SCLK=0;
  64.                    bbyte<<=1;
  65.            }
  66. }
  67. /***************************************************************/
  68. void Delaynms(unsigned int di)
  69. {
  70.         unsigned int da,db;
  71.         for(da=0;da<di;da++)
  72.                    for(db=0;db<10;db++);
  73. }
  74. /***************************************************************/
  75. void Clr_Scr(void)
  76. {
  77.         Write_char(0,0x01);
  78. }
  79. /****************************************************************/
  80. void LCD_set_xy( unsigned char x, unsigned char y )
  81. {
  82.     unsigned char address;
  83.         switch(x)
  84.         {
  85.                 case 0: address = 0x80 + y; break;
  86.             case 1: address = 0x80 + y; break;
  87.                 case 2: address = 0x90 + y; break;
  88.                     case 3: address = 0x88 + y; break;
  89.                 case 4: address = 0x98 + y; break;
  90.                 default:address = 0x80 + y; break;
  91.         }
  92.     Write_char(0, address);
  93. }
  94. /*****************************************************************/
  95. void LCD_Write_string(unsigned char X,unsigned char Y,unsigned char *s)
  96. {
  97.         LCD_set_xy( X, Y );
  98.     while (*s)
  99.     {
  100.                 Write_char( 1, *s );
  101.             s ++;
  102.                 Delaynms(1);
  103.         }
  104. }
  105. /******************************************************************/
  106. void LCD_Write_number(unsigned char s)
  107. {
  108.         Write_char(1,num[s]);
  109.         Delaynms(1);
  110. }
  111. /******************************************************************/
  112. void Lcd_Mark2(void)
  113. {
  114.         Clr_Scr();//??
  115.         LCD_Write_string(1,2,Q);
  116.         LCD_Write_string(1,6,CM);
  117. }
  118. /*************************************************************************************/
  119. /*************************************************************************************/
  120.     void Conut(void)
  121.         {
  122.            time=TH0*256+TL0;
  123.            TH0=0;
  124.            TL0=0;
  125.            S=time*1.87/100;
  126.            if(flag==1)
  127.           {
  128.            flag=0;
  129.            LCD_set_xy( 1, 4 );
  130.            LCD_Write_number(13);
  131.            LCD_Write_number(12);
  132.            LCD_set_xy( 1, 5 );
  133.            LCD_Write_number(13);
  134.            LCD_Write_number(13);
  135.            }
  136.          else
  137.           {
  138.            disbuff[1]=S%1000/100;
  139.            disbuff[2]=S%1000%100/10;
  140.            disbuff[3]=S%1000%10 %10;
  141.            LCD_set_xy( 1, 4 );
  142.            LCD_Write_number(disbuff[1]);
  143.            LCD_Write_number(12);
  144.            LCD_set_xy( 1, 5 );
  145.            LCD_Write_number(disbuff[2]);
  146.            LCD_Write_number(disbuff[3]);
  147.           }
  148.         }
  149. /********************************************************/
  150. void delayms(unsigned int ms)
  151. {
  152.         unsigned char i=100,j;
  153.         for(;ms;ms--)
  154.         {
  155.                 while(--i)
  156.                 {
  157.                         j=10;
  158.                         while(--j);
  159.                 }
  160.         }
  161. }
  162. /********************************************************/
  163.      void zd0() interrupt 1
  164.   {
  165.     flag=1;
  166.   }
  167. /********************************************************/
  168.    void  StartModule()
  169.   {
  170.           TX=1;
  171.           _nop_();
  172.           _nop_();
  173.           _nop_();
  174.           _nop_();
  175.           _nop_();
  176.           _nop_();
  177.           _nop_();
  178.           _nop_();
  179.           _nop_();
  180.           _nop_();
  181.           _nop_();
  182.           _nop_();
  183.           _nop_();
  184.           _nop_();
  185.           _nop_();
  186.           _nop_();
  187.           _nop_();
  188.           _nop_();
  189.           _nop_();
  190.           _nop_();
  191.           _nop_();
  192.           TX=0;
  193.   }
  194. /********************************************************/
  195. void main(void)
  196. {
  197.     TMOD=0x01;
  198.         TH0=0;
  199.         TL0=0;
  200.         TR0=1;
  201.         Lcd_init();
  202.         Clr_Scr();
  203.     Lcd_Mark2();
  204.         while(1)
  205.         {
  206.          StartModule();
  207.          while(!RX);
  208.          TR0=1;
  209.          while(RX);
  210.          TR0=0;
  211.          Conut();
  212.          delayms(80);                //80MS
  213.         }
  214. }
