2019-7-29 18:01 上傳
單片機(jī)源程序如下:
- #include"AD7715.h"
- //發(fā)送數(shù)據(jù)
- void WriteADData(unsigned char write_data)
- uchar i;
- for(i=0;i<8;i++)
- if((write_data&0x80)!=0)
- AD_DIN=1;
- else
- AD_DIN=0;
- write_data=write_data<<1;
- AD_SCLK=1;
- AD_SCLK=0;
- AD_SCLK=1;
- AD_DIN=1;
- //接收數(shù)據(jù)
- uint ReadADData(uchar z)
- uchar i;
- int ad_data =0;
- for(i=0;i<z*8;i++)
- AD_SCLK = 1;
- AD_SCLK= 0;
- AD_SCLK = 0;
- ad_data= ad_data << 1;
- if(AD_DOUT == 1)
- ad_data += 1;
- AD_SCLK= 1;
- return ad_data;
- //初始化
- void InitAD7715(void)
- WriteADData(0x10); //設(shè)置增益為1;
- WriteADData(0x46); //設(shè) 置校準(zhǔn)為自標(biāo)定,主頻率為大于2M,更新頻率為20Hz,單極;
- //啟動(dòng)轉(zhuǎn)換
- uint GetADNum(void)
- while(AD_DRDY==1); //等待轉(zhuǎn)換完成;
- WriteADData(0x38); //
- return ReadADData(2);
- main()
- uint ad_num;
- InitAD7715();
- while (1)
- ad_num = GetADNum();
AD7715.7z
(787 Bytes, 下載次數(shù): 20)
2019-7-29 14:52 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
