查看: 3647|回復: 1
ds3231單片機程序 時間和溫度發送到串口顯示
  1. #include<global.h>
  2. void DS3231WriteByte(unsigned char addr,unsigned char dat)
  3. {
  4.         bit ack;
  5.         IICStart();
  6.         ack = IICWrite(0xD0);//寫設備地址+寫操作
  7.         while(~ack);
  8.         ack = IICWrite(addr);//內部寄存器指針
  9.         while(~ack);
  10.         ack = IICWrite(dat);//寫數據
  11.         while(~ack);
  12.         IICStop();
  13. }
  14. void DS3231ReadByte(unsigned char addr,unsigned char *buf)
  15. {
  16.         bit ack;
  17.         IICStart();
  18.         ack = IICWrite(0xD0);//寫設備地址+寫操作
  19.         while(~ack);
  20.         ack = IICWrite(addr);//內部寄存器指針
  21.         while(~ack);
  22.         IICStop();
  23.
  24.         IICStart();
  25.         ack = IICWrite(0xD1);//寫設備地址+讀操作
  26.         while(~ack);
  27.         *buf = IICReadNAK();//讀一個字節數據
  28.         IICStop();
  29. }
  30. void DS3231Read7Byte(unsigned char *buf)
  31. {
  32.         bit ack;
  33.         unsigned char i;
  34.         IICStart();
  35.         ack = IICWrite(0xD0);//寫設備地址+寫操作
  36.         while(~ack);
  37.         ack = IICWrite(0x00);//秒寄存器地址
  38.         while(~ack);
  39.         IICStop();
  40.
  41.         IICStart();
  42.         ack = IICWrite(0xD1);//寫設備地址+讀操作
  43.         while(~ack);
  44.         for(i=0;i<6;i++)
  45.         {                                                //上面寫了秒寄存器地址,內部寄存器指針會自動+1
  46.                 *buf++= IICReadACK();//所以只需要發送一個開始地址
  47.         }                                                //讀數據,發送還需要讀數據的應答位
  48.         *buf= IICReadNAK();//讀數據,不需要再讀取數據應答位
  49.         IICStop();
  50.
  51. }
  52. void DS3231Write7Byte(unsigned char *dat)
  53. {
  54.         bit ack;
  55.         unsigned char i;
  56.         IICStart();
  57.         ack = IICWrite(0xD0);//寫設備地址+寫操作
  58.         while(~ack);
  59.         ack = IICWrite(0x00);//秒寄存器地址
  60.         while(~ack);
  61.         for(i=0;i<7;i++)
  62.         {
  63.                 ack = IICWrite(dat[i]);//連續寫入數據7次,和上面同理
  64.                 while(~ack);
  65.         }
  66.         IICStop();
  67. }
  68. void GetRealTime(struct sTime *time)
  69. {
  70.         unsigned char buf[8];
  71.
  72.         DS3231Read7Byte(buf);
  73.         time->year = buf[6];
  74.         time->mon =        buf[5];
  75.         time->day =        buf[4];
  76.         time->hour = buf[2];
  77.         time->min = buf[1];
  78.         time->sec = buf[0];
  79.         time->week = buf[3];
  80. }
  2. sbit SDA = P2^1;
  3. sbit SCL = P2^0;
  4. void Delay5us()                //@11.0592MHz
  5. {
  6.         unsigned char i;
  7.         _nop_();
  8.         i = 11;
  9.         while (--i);
  10. }
  11. void IICStart()
  12. {
  13.         SDA = 1;        //確保sda為高電平為開始信號做準備
  14.         SCL = 1;        //scl一直保持高電平等待讀取sda由高向低切換
  15.         Delay5us();        //協議規定:sda高電平狀態時間大于4.7us
  16.         SDA = 0;        //協議規定:在scl為高時sda由高向低切換,為iic開始信號
  17.         Delay5us();        //協議規定:sda低電平狀態時間大于4us
  18.         SCL = 0;        //拉低scl為后面sda數據做準備
  19. }
  20. void IICStop()
  21. {
  22.         SDA = 0;        //確保sda為低電平為結束信號做準備
  23.         SCL = 1;        //scl一直保持高電平等待讀取sda由低向高切換
  24.         Delay5us(); //協議規定:sda低電平時間大于4us
  25.         SDA = 1;        //協議規定:在scl為高時sda由低向高切換,為iic結束信號
  26.         Delay5us(); //協議規定:sda高電平狀態時間大于4.7us
  27. }
  28. bit IICWrite(unsigned char dat)
  29. {
  30.         bit ack;        //暫時存應答值
  31.         unsigned char mask;        //用于探測字節內一位的值
  32.         for(mask = 0x80; mask!=0; mask>>=1)        //從高位到低位依次進行
  33.         {
  34.                 if ((dat & mask) == 0)        //將該位值輸出到引腳
  35.                         SDA = 0;
  36.                 else
  37.                         SDA = 1;
  38.                 Delay5us();        //穩定數據
  39.                 SCL = 1;        //拉高時鐘
  40.                 Delay5us();        //維持時鐘時間大于4us
  41.                 SCL = 0;
  42.         }
  43.
  44.         SDA = 1; //釋放總線準備接收數據
  45.         Delay5us();
  46.         SCL = 1;//開始讀取應答位
  47.         ack = SDA;
  48.         Delay5us();
  49.         SCL = 0;
  50.
  51.         return ~ack;
  52. }
  53. unsigned char IICReadNAK()
  54. {
  55.         unsigned char dat;
  56.         unsigned char mask;
  57.         SDA = 1;//釋放總線準備接收數據
  58.         for(mask = 0x80; mask != 0; mask >>= 1)
  59.         {
  60.                 SCL = 1;
  61.                 if(SDA == 1)
  62.                         dat |= mask;
  63.                 else
  64.                         dat &= ~mask;
  65.                 Delay5us();
  66.                 SCL = 0;
  67.         }
  68.
  69.         SDA = 1;
  70.         Delay5us();
  71.         SCL = 1;
  72.         Delay5us();
  73.         SCL = 0;
  74.
  75.         return dat;
  76. }
  77. unsigned char IICReadACK()
  78. {
  79.         unsigned char dat;
  80.         unsigned char mask;
  81.         SDA = 1;//釋放總線準備接收數據
  82.         for(mask = 0x80; mask != 0; mask >>= 1)
  83.         {
  84.                 SCL = 1;
  85.                 if(SDA == 1)
  86.                         dat |= mask;
  87.                 else
  88.                         dat &= ~mask;
  89.                 Delay5us();
  90.                 SCL = 0;
  91.         }
  92.
  93.         SDA = 0;
  94.         Delay5us();
  95.         SCL = 1;
  96.         Delay5us();
  97.         SCL = 0;
  98.
  99.         return dat;
  100. }
全部資料51hei下載地址:
ds3231.rar (58.74 KB, 下載次數: 79)
收藏收藏6 分享淘帖 頂 踩
ID:117402 發表于 2020-5-6 21:52 | 只看該作者
謝謝樓主分享!!
