感謝眾大網(wǎng)友的無私奉獻(xiàn),在mqtt協(xié)議的編碼本分采集了網(wǎng)友們的mqtt協(xié)議解碼分享。程序主要實(shí)現(xiàn)在arduino上的整合部分,寫程序的時(shí)候水平有限,請大家多多原諒!
單片機(jī)源程序如下:
- *程序描述:esp8285透傳串口處理系統(tǒng)
- #include "esp.h"
- #include "mqtt.h"
- //#include <SoftwareSerial.h>
- //信息緩沖區(qū)大小
- #define read_num 64
- #define send_num 50
- //信息緩沖區(qū)
- unsigned char buff[send_num];
- unsigned char read_buff[read_num];
- unsigned char msgas[50];
- int lenstr=0;
- //定時(shí)器0的時(shí)間定義
- unsigned long time_ding=0;
- unsigned long time_ms=0;
- int ding=0;
- //定時(shí)器1的時(shí)間定義
- unsigned long time_ding1=0;
- unsigned long time_ms1=0;
- int ding1=0;
- //定時(shí)器2的時(shí)間定義
- unsigned long time_ding2=0;
- unsigned long time_ms2=0;
- int ding2=0;
- //mqtt服務(wù)器的定時(shí)器時(shí)間定義
- unsigned long timeoutt=0;
- unsigned long timeoutr=0;
- //設(shè)備標(biāo)志定義
- bool wf=0; //wifi連接標(biāo)志位
- bool tcps=0; //tcp發(fā)送標(biāo)志位
- bool tcpc=0; //tcp連接標(biāo)志位
- int led=0;
- int error=0; //異常代碼
- //mqtt服務(wù)器定義
- bool mqttc=0; //mqtt服務(wù)器連接標(biāo)志
- //SoftwareSerial woshi(2, 3);
- void setup()
- Serial.begin(115200);
- // woshi.begin(9600);
- pinMode(13,OUTPUT);
- pinMode(2,OUTPUT);
- // digitalWrite(2,HIGH);
- void loop()
- while(1)
- net();
- bendi_loop();
- * 函數(shù):void bendi_loop()
- * 功能:管理本地事物
- void bendi_loop() //處理本地事務(wù)
- if(ding1>0)
- if((millis()-time_ding1)>time_ms1) //如果定時(shí)器到時(shí)間了就執(zhí)行,否則就跳出
- switch(ding1) //選自跳轉(zhuǎn)的位置
- case 1:
- ding1=0;
- break;
- default:
- break;
- else //定時(shí)器沒有到時(shí)間就跳出
- return ;
- void net()
- int msgnum;
- if(error>0) //錯(cuò)誤代碼處理
- error_chuli(error);
- if(ding>0)
- if((millis()-time_ding)>time_ms) //如果定時(shí)器到時(shí)間了就執(zhí)行,否則就跳出
- switch(ding) //選自跳轉(zhuǎn)的位置
- case 1:
- ding=0;
- goto one;
- break;
- case 2:
- ding=0;
- goto two;
- break;
- case 3:
- ding=0;
- goto three;
- break;
- default:
- break;
- return ;
- if(wf) //判斷wifi是否連接
- if(tcpc) //判斷tcp是否連接
- if(tcps) //判斷是否在透傳中
- mqtt_loop();
- else //進(jìn)入透傳模式
- three:if(tcp_begin_send())
- tcps=1;
- else
- delay_ms(500,3);
- error=3;
- else //tcp連接
- two:if(tcp_client())
- tcpc=1;
- else
- delay_ms(1000,2);
- else //wifi檢測
- one:if(ap_can())
- wf=1;
- else
- delay_ms(3000,1);
- bool mqtt_subscribe(const char *da,unsigned int Nu,unsigned char RequestedQo)
- int num;
- qing_buff();
- num=GetDataSUBSCRIBE(buff,da,Nu,RequestedQo);
- Serial.write(buff,num);
- qing_buff();
- delay(500);
- if(serial_can()==2)
- qing_read();
- return 1;
- else
- qing_read();
- return 0;
- void mqtt_publish(unsigned char du, unsigned char qo,unsigned char retai,const char *topi ,const char *ms)
- int num;
- qing_buff();
- num=GetDataPUBLISH(buff,du,qo,retai,topi,ms);
- qing_buff();
- void msg_chuli()
- int len=0,i;
- if((msgas[23]=='o')&&(msgas[24]=='n'))
- digitalWrite(2,HIGH);
- mqtt_publish(0,0,0,MQTT_Topic,"on");
- if((msgas[23]=='o')&&(msgas[24]=='f'))
- digitalWrite(2,LOW);
- mqtt_publish(0,0,0,MQTT_Topic,"off");
- for(i=0;i<50;i++)msgas[i]='\0';
- // mqtt_publish(0,0,0,MQTT_Topic,msg);
- // len=strlen(msg);
- // if((msg[0]=='o')&&(msg[1]=='n'))
- // digitalWrite(13,HIGH);
- // mqtt_publish(0,0,0,MQTT_Topic,"on");
- // else if((msg[0]=='o')&&(msg[1]=='f'))
- // digitalWrite(13,LOW);
- // mqtt_publish(0,0,0,MQTT_Topic,"off");
- void mqtt_loop()
- char *msgg=NULL;
- int num;
- if(ding2>0)
- if((millis()-time_ding2)>time_ms2) //如果定時(shí)器到時(shí)間了就執(zhí)行,否則就跳出
- switch(ding2) //選自跳轉(zhuǎn)的位置
- case 1:
- ding2=0;
- goto one;
- break;
- default:
- break;
- return ;
- if(mqttc==0) //判斷服務(wù)器是否連接上
- one:if(mqtt_client())
- mqttc=1;
- timeoutr=millis();
- timeoutt=millis();
- mqtt_subscribe(mqtt_Stopic,0,0);
- delay(1000);
- mqtt_publish(0,0,0,MQTT_Topic,"wo");
- else
- delay_ms2(5000,1);
- else
- if((millis()-timeoutt)>5000)
- mqtt_ping();
- if((millis()-timeoutr)>30000)
- mqttc=0;
- if(Serial.available())
- delay(300);
- num=serial_can();
- switch(num)
- case 3:
- break;
- case 4:
- msg_chuli();
- break;
- default:
- esp_cpu(num);
- break;
- void mqtt_ping()
- int len;
- len=GetDataPINGREQ(buff);
- Serial.write(buff,len);
- qing_buff();
- bool mqtt_client() //服務(wù)器連接
- int num;
- int i;
- qing_buff();
- num=GetDataConnet(buff);
- qing_buff();
- delay(1000);
- if(serial_can()==1)
- qing_read();
- return 1;
- else
- return 0;
- else
- return 0;
- 函數(shù)名稱:serial_can()
- 函數(shù)功能:判斷串口數(shù)據(jù)類型
- 返回值:
- 0 沒有匹配到任何值
- 1 mqtt連接成功
- 2 mqtt訂閱回應(yīng)包
- 3 mqtt心跳包
- 4 mqtt消息包
- 6 wifi斷開連接
- int serial_can() //判斷返回值
- int i;
- int num;
- qing_read();
- num=Serial.available();
- for(i=0;Serial.available()>0;i++)read_buff[i]=Serial.read();
- if((read_buff[0]==0x20)&&(read_buff[1]==0x02))
- return 1;
- if(read_buff[0]==0x90)
- return 2;
- if((read_buff[0]==0xd0)&&(read_buff[1]==0x00))
- return 3;
- // if(strstr(read_buff,mqtt_Stopic)!=NULL)
- if(read_buff[0]==0x30)
- lenstr=num;
- for(i=0;i<num;i++)msgas[i]=read_buff[i];
- return 4;
- if(strstr(read_buff,"disconnect from ssid")!=NULL)
- return 6;
- qing_read();
- return 0;
- void esp_cpu(int num) //設(shè)備處理
- switch(num)
- case 6: //wifi斷開連接處理
- error_chuli(1);
- break;
- default:
- break;
- 函數(shù)名稱:void error_chuli(int k)
- 函數(shù)功能:錯(cuò)誤處理
- 輸入?yún)?shù):
- 1 //錯(cuò)誤代碼1 WiFi斷開連接
- 3 //錯(cuò)誤代碼3 透傳模式失敗
- void error_chuli(int k)
- switch(k)
- case 1: //錯(cuò)誤代碼1 wifi斷開連接
- esp_res();
- break;
- case 3: //錯(cuò)誤代碼3 透傳模式開啟失敗
- error=0;
- break;
- default:
- break;
- void esp_res()
- wf=0;
- tcpc=0;
- mqttc=0;
- tcps=0;
- tcp_stop_send();
- Serial.println(at_esp_ret);
- delay(3000);
- qing_buff();
- qing_read();
- while(Serial.read() >= 0);
- bool tcp_begin_send() //開始透傳
- int i;
- Serial.println(at_tcp_mode);
- delay(300);
- Serial.println(at_tcp_send);
- delay(300);
- if(strstr(read_buff,"OK")!=NULL)
- qing_read();
- tcps=1;
- return 1;
- else
- qing_read();
- return 0;
- else
- return 0;
- void tcp_stop_send() //退出透傳模式
- if(tcps==1)
- Serial.print(at_tcp_ssend);
- tcps=0;
- bool tcp_client()
- int i;
- Serial.println(at_tcp_client);
- delay(4000);
- qing_read();
- if(strstr(read_buff,"CONNECT")!=NULL)
- qing_read();
- return 1;
- else if(strstr(read_buff,"ALREADY CONNECTED")!=NULL)
- qing_read();
- return 1;
- else
- qing_read();
- return 0;
- else
- qing_read();
- return 0;
- bool ap_can()
- int i;
2019-7-27 22:46 上傳
arduino對接esp8266版本4.0.zip
(8.99 KB, 下載次數(shù): 77)
2019-7-27 10:23 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
