#include "reg52.h"
typedef unsigned char uchar;
typedef unsigned int uint;
typedef unsigned long ulong;
uint time;//定義時間
uint code txiang2[];
uint code txiang1[];
uint code txiang[];
uchar code mao_hao[];
uchar code num0[];
uchar code num1[];
uchar code num2[];
uchar code num3[];
uchar code num4[];
uchar code num5[];
uchar code num6[];
uchar code num7[];
uchar code num8[];
uchar code num9[];
uchar code shi[];
uchar code du[];
sbit cs=P1^1;
sbit reset=P1^0;
sbit rs=P3^0;
sbit sclk=P3^1;
sbit sid=P3^2;
// 延時
void delay(ulong i)
ulong j;
uint k;
for(j=0;j<i;j++)
for(k=0;k<110;k++);
//數(shù)據(jù)命令
void pen(uchar data1)
uint i;
cs=0;
rs=1;
for(i=0;i<8;i++)
sclk=0;
if(data1&0x80) sid=1;
else sid=0;
sclk=1;
data1<<=1;
cs=1;
//指令命令
void tan(uchar data1)
uint i;
cs=0;
rs=0;
for(i=0;i<8;i++)
sclk=0;
else sid=0;
sclk=1;
data1<<=1;
cs=1;
//調(diào)用漢字
void dis_1616(uchar page,uchar lie,uchar *dp)
uchar i;
uint j;
for(j=0;j<2;j++)
tan(0xb0+page+j);//設(shè)計頁地址
tan(0x10+((lie>>4)&0x0f)); //設(shè)計列高四位
tan(0x00+(lie&0x0f)); //設(shè)計列低四位
for(i=0;i<16;i++)
pen(*dp);
dp++;
//調(diào)用數(shù)字
void dis_816(uchar page,uchar lie,uchar *dp)
uchar i;
uint j;
for(j=0;j<2;j++)
for(i=0;i<8;i++)
pen(*dp);
dp++;
//清屏
void clear()
uchar i;
uint j;
for(j=0;j<8;j++)
tan(0xb0+j);//設(shè)計頁地址
tan(0x10); //設(shè)計列高四位
tan(0x00); //設(shè)計列低四位
for(i=0;i<128;i++)
pen(0x00);
//調(diào)用圖像
void clear1(uint *dp)
uchar i;
uint j;
for(j=0;j<8;j++)
for(i=0;i<128;i++)
pen(*dp);
dp++;
//屏幕全白
void display()
uchar i;
uint j;
for(j=0;j<8;j++)
for(i=0;i<128;i++)
pen(0x00);
void cshua()
reset=0;
delay(100);
reset=1;
delay(100);
tan(0xe2); //軟復(fù)位
delay(10);
tan(0x2f); //打開升壓VC,VS,VR
delay(10);
tan(0x23); //粗調(diào)對比度,0x20~0x27
tan(0x81); //與下一條指令配套
tan(0x20); //細調(diào)對比度,
tan(0xa2); //偏壓設(shè)計,1/9
tan(0xaf); //打開顯示
cshua();
clear();
display();
tan(0xc8);
tan(0xa0);
dis_1616(0,0,shi);
dis_1616(0,16,du);
dis_1616(0,32,mao_hao);
delay(1000);
clear1(txiang);
delay(1000);
clear();
clear1(txiang1);
delay(1000);
clear1(txiang2);
delay(1000);
uint code txiang2[]={
/*-- 調(diào)入了一幅圖像:C:\Users\gx\Desktop\新建文件夾\20091006225237-2071841023.bmp --*/
/*-- 寬度x高度=128x64 --*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xBF,0xFF,
0xDF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xBF,0xFF,0xFB,0xFF,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFD,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
uint code txiang1[]={
/*-- 調(diào)入了一幅圖像:C:\Users\gx\Desktop\新建文件夾\00451QK1-9.bmp --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xB0,0xF0,
0xE0,0xE0,0xF4,0xE8,0xEC,0xFC,0xFC,0xFA,0xFD,0xBD,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xBF,0xFF,0xFD,0xFF,0xFF,0xFB,0xFF,0x7F,0xF4,0xFC,0xFC,0xEC,0xFC,0xEC,0xF9,0xF3,
0xF3,0xF3,0xF0,0xC7,0x1F,0x9F,0x83,0xBB,0xFF,0xFF,0xFF,0xFD,0xFF,0xFB,0xFC,0xEF,
0xFC,0xFC,0xFC,0xBC,0xF0,0xC0,0x80,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0xFE,
0xFF,0xFF,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,0xBF,
0xBF,0xBF,0xDB,0xFF,0xDE,0xFD,0xFF,0xFB,0xFF,0xFF,0xBD,0xFF,0xFF,0xDE,0x7F,0xFF,
0xFF,0xFE,0xDF,0xFF,0xF3,0xFF,0xFF,0xFF,0xFF,0xFF,0xC7,0xC1,0xBF,0x9F,0xBF,0xFF,
0xDF,0xFF,0xBB,0x7F,0xFF,0xDF,0xBF,0x7F,0xFB,0xFF,0xF2,0xF0,0xF0,0xE0,0xC0,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF7,0xFE,
0xBF,0x83,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFE,0xFE,0xFF,0xDF,0xBF,0xBF,0x47,
0xFF,0xB3,0xA3,0xFB,0xDF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF7,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xEE,0xDD,0xBF,0xAF,0x3E,0x7D,0xF9,0xFB,0xF7,0xF7,0xFE,0xED,
0xDF,0xBF,0xBF,0xF7,0x7F,0xF7,0xDB,0xFF,0xBF,0xFF,0xFF,0xDF,0xFE,0xFF,0x7F,0xFF,
0xFE,0xDE,0xAE,0xB0,0xE0,0xC0,0xC0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFD,0xFF,
0xF0,0xFF,0xFF,0xFF,0x47,0xFF,0xEF,0xFF,0x5F,0xBF,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xBF,0xBE,0xBE,0xBE,0x3E,0x7E,0x7E,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,
0xFF,0xDF,0xFF,0xFF,0xBD,0xDF,0x6F,0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFD,
0xFF,0xFA,0xFF,0xF7,0xF3,0xF7,0xFE,0xEF,0xFD,0xFE,0xFC,0xFE,0xF6,0xF4,0xF0,0xF0,
0xF0,0xF0,0xF0,0xF0,0xB0,0xF8,0xF8,0x80,0xC0,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0xFB,
0xFF,0xF8,0xE7,0xFF,0x7F,0xFB,0xF7,0xFF,0xFE,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFB,0xFF,0xFD,0xFF,0xFD,0xFC,0xFC,0xFF,0xFE,0xFE,0xF6,0xFE,0xFF,0xFB,
0xFF,0xF7,0xFF,0xFD,0xFF,0xDF,0xEF,0xFF,0xFF,0xF9,0xC1,0xF0,0xB6,0xDF,0xFF,0xF9,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEF,0xDF,0xFF,0x1F,0xDF,0xBF,0xBF,0xBF,0xFF,
0x7D,0x7B,0xFB,0xF7,0xE7,0xFF,0xBF,0x5F,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFD,0xFD,0xFF,0xFB,0xFF,0xF7,0xFF,0xEF,0xFF,0xFF,0xFE,0xFF,0xFE,0xFF,0xBE,0xFF,
0xFF,0xF0,0xF8,0xFC,0xF8,0xF8,0xD0,0xE0,0xE0,0xC0,0xC0,0x20,0x20,0x00,0x00,0x00,
0x00,0x00,0xC0,0x77,0xDE,0xFF,0xFD,0xFF,0xFF,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,
0xBF,0xEF,0xFF,0xF1,0xD1,0xD3,0xF3,0xD1,0xEF,0xFF,0xFF,0xFE,0xFF,0xFF,0xFD,0xFF,
0x7D,0xFF,0xFE,0xDD,0xFF,0x7F,0xE7,0xCF,0xFF,0xFF,0xFF,0xBE,0xFB,0xD7,0xF7,0xF3,
0x83,0xFF,0xFE,0xFF,0xDD,0xFF,0xFF,0xFF,0xE5,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xBF,
0xC7,0xFB,0xFF,0xBF,0xFF,0xF7,0x6F,0xBF,0xFF,0xFF,0xFF,0xFE,0x79,0xCF,0xF7,0xF7,
0xCF,0xFD,0xFB,0xF7,0xFF,0xFF,0x7F,0xEB,0xFF,0xFF,0xFF,0xF7,0x10,0x1F,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0xC0,
0xC0,0xE0,0x7F,0xD9,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xAF,0xFF,0x6F,0xFF,0xF7,0xF9,
0xF1,0xF9,0xF9,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0x2F,
0xFF,0x37,0x37,0xB7,0x87,0x87,0x0F,0x07,0x3F,0x3F,0x7F,0x7F,0x7F,0x7F,0x3F,0x7F,
0x7E,0x6F,0x6F,0x6F,0x7F,0x77,0x77,0x7B,0x2F,0x25,0x1E,0x2E,0x3B,0xBF,0xFF,0x7F,
0xFB,0xBF,0xB9,0xB9,0xB9,0xF9,0xBB,0xBE,0xBF,0xB7,0xBB,0x7D,0x7D,0x71,0x7F,0x79,
0xBF,0xBF,0xAE,0xBF,0x3F,0x3D,0x3F,0x0F,0x0F,0x01,0x01,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
0xFF,0xFF,0x3F,0xFF,0xFF,0xF9,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0x7F,0xBF,0xEF,0xFB,0xFD,0xBE,0xFD,0xFF,0xFF,0xFF,0xBF,0xFF,0xFF,0xFB,0xFF,0xFF,
0xFF,0xFF,0xFF,0xF9,0xFD,0xED,0xFC,0xDC,0xDC,0xE0,0xE0,0xE0,0xE0,0xE0,0x90,0x00,
uint code txiang[]={
/*-- 調(diào)入了一幅圖像:C:\Users\gx\Desktop\新建文件夾\9107d9a30a3c3dbc-d722c7ed9639ca55-a3154dafcbd271e781f49887a22244fa.bmp --*/
0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x30,0xB0,0x90,0x90,0xD0,0xD0,
0x40,0x60,0xE0,0xAC,0xA8,0xB4,0xB4,0xB4,0x94,0xB0,0xB8,0xD8,0x78,0xF8,0xF8,0xF8,
0xF8,0x58,0x58,0x58,0x58,0x58,0x58,0xD8,0x98,0x58,0x58,0x08,0x18,0x18,0x18,0x58,
0x58,0x1C,0x18,0x54,0x54,0x34,0x34,0x34,0xA0,0x60,0x60,0x40,0xC0,0x80,0xA0,0x20,
0x00,0xD0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x20,0xC0,0x60,0x30,0xB0,
0xCA,0x6E,0x34,0x9A,0xD8,0x6D,0xA4,0xD6,0x0A,0xBB,0xD1,0x69,0xE9,0x70,0xFA,0xC0,
0xC3,0xC1,0xC1,0xE1,0x81,0xC1,0xE0,0x40,0x42,0xC0,0xC0,0xC1,0x01,0x01,0x01,0x01,
0x00,0x3A,0x3E,0x3C,0x3A,0xDD,0xF0,0x30,0xE8,0xD8,0xF8,0xB8,0xD8,0xB8,0x60,0xCE,
0xCE,0xEC,0x5E,0xD8,0xB0,0xF8,0x70,0xD8,0xB1,0x73,0xB3,0xF9,0x78,0xCE,0xDD,0xBD,
0x6B,0xD6,0xF6,0xEC,0xD8,0x36,0x60,0xE8,0xD0,0xA8,0x78,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x07,0x03,0x07,0x07,0xEE,0x7C,0x38,0xE4,0xF8,0x1C,0x4F,0xC3,0xF9,
0x3C,0xDE,0xF7,0x35,0xCE,0xF9,0x7D,0x1E,0xC7,0xF1,0xFA,0x6D,0xB6,0xDB,0xED,0xED,
0xF6,0xDB,0x6D,0x36,0xDB,0xED,0xF6,0xFB,0x1B,0x16,0x0D,0x1E,0x9D,0x33,0x66,0xCF,
0x9F,0xBB,0x74,0xE8,0xFC,0xDC,0xBC,0xF5,0x4D,0xDD,0xBA,0x77,0xF7,0xCF,0x9D,0x7E,
0xFD,0xF3,0x1E,0xFD,0xF3,0xC5,0x7F,0xFE,0x7B,0xF7,0xDF,0x3B,0xE5,0xDE,0x7D,0x3B,
0xEF,0xFC,0x79,0xE3,0x8F,0x7E,0xF1,0xDC,0x71,0xF7,0x8E,0x7D,0xF3,0xCE,0x15,0xFF,
0x00,0x00,0x00,0xC0,0x40,0xE0,0x60,0xBF,0xC0,0xFF,0xFF,0xF9,0xF7,0xF9,0xFF,0xFF,
0xFF,0x8F,0x02,0xFE,0x3F,0xFF,0xF8,0xFE,0xBF,0xDD,0xDF,0xCF,0xDF,0xB7,0x9B,0x41,
0x41,0x42,0xC3,0x83,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC3,0x43,0xC3,0xC1,
0x41,0x7D,0xEB,0xE7,0xE7,0xEF,0xEB,0xFF,0xFF,0xFE,0xFF,0xFF,0xFE,0xFD,0xF3,0xE7,
0xCE,0xBB,0xAF,0xFC,0x73,0xFF,0xFE,0x11,0x8A,0xC3,0xE3,0xE3,0xC0,0xFF,0x1F,0xEB,
0xFF,0xFF,0xFE,0xFF,0xFF,0xFE,0xE3,0x3F,0x7F,0x4F,0x3D,0x60,0xFF,0xFF,0x00,0xFF,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x00,0xE0,0xFC,0xFE,
0x6E,0xB7,0xFB,0xBD,0xBD,0xBE,0xBF,0xBF,0xAF,0xAF,0xFE,0x7F,0xDF,0xDF,0xFF,0xFF,
0xFF,0xFF,0xFC,0xFF,0xFF,0xFF,0xFF,0xF3,0x5D,0xDF,0xBF,0x7F,0x5F,0x5F,0x5F,0x6F,
0x7F,0xBF,0xE3,0xAD,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x03,0x06,0x07,0x04,
0x07,0x3B,0x1D,0x21,0x0F,0x3F,0xBF,0x6F,0x7D,0x5F,0x5F,0x5F,0x6F,0x67,0xEF,0x3F,
0xFF,0xFF,0xFD,0xFF,0xFF,0x7F,0x06,0xE2,0xFC,0x3F,0xE7,0xFC,0xFF,0xDD,0xF8,0x7F,
0xFF,0xBF,0xC3,0xFF,0x1F,0xFF,0xFF,0x00,0xF8,0x78,0x98,0xFF,0xE1,0x1F,0xFF,0xFC,
0x7B,0xF3,0xEE,0xDF,0x7C,0xE0,0xE0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x67,0x7F,0xFD,0xFE,0x7E,0x03,0x7B,
0x2B,0x5B,0x2B,0xFB,0xFB,0xFA,0xFB,0xFF,0xFF,0x9F,0x0F,0x9F,0xBF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xF0,0xF1,0x9F,0xFF,0xFF,0xFF,0xFE,0xF8,0xF6,0xE6,0x5E,0xD4,0xB0,
0xB0,0xA0,0x60,0x00,0x4C,0xCC,0xCF,0xCF,0xEF,0xAF,0x5F,0xDE,0xD7,0xC0,0x80,0x40,
0x80,0x80,0x80,0x80,0x80,0xC0,0xC0,0xC0,0x40,0x40,0x30,0xF0,0xB0,0xD0,0xE0,0x7C,
0xDF,0xF3,0x7E,0xFF,0xFF,0xE0,0xFE,0xFF,0xCF,0xE0,0xDF,0x62,0xFE,0xFF,0xFF,0xFF,
0xFF,0xFF,0xDF,0xF1,0x1F,0xFF,0xF2,0xF5,0xFC,0xDF,0x46,0x3F,0xB7,0xCE,0x39,0xFF,
0xDE,0xBF,0xBF,0xC7,0xFF,0x38,0xCF,0x7E,0xE3,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x80,0x80,0x08,0xF8,0xE8,0xE8,0xF0,0xF3,0xF0,0x1F,0xEF,0xB0,0xF8,0xF8,
0x50,0x68,0xE7,0xFC,0xB3,0x8B,0xB7,0xAF,0x8F,0xDF,0xFF,0xFE,0xFD,0xFB,0xF7,0xF9,
0xFF,0xFF,0xFF,0xFF,0xF7,0xFF,0xFE,0xFB,0xEF,0xFF,0xFF,0xFF,0xFF,0x7F,0xF8,0x0F,
0x7F,0xF7,0xFF,0xFF,0xFF,0xFF,0xFE,0xFE,0x7F,0xBC,0xDD,0x4C,0x6E,0x7D,0xF9,0xFF,
0x3C,0xBD,0x1D,0x1D,0x2E,0x2E,0xE6,0x16,0x8B,0x03,0xCD,0xF1,0xFD,0xFF,0x3F,0xCF,
0xE3,0x3F,0xF8,0xCF,0x3F,0xFF,0xFF,0xFF,0x7F,0xFE,0xFE,0xFF,0xFF,0xFF,0x7F,0xBF,
0xEF,0xFD,0xFF,0xFF,0x00,0x20,0xE7,0xE7,0xFF,0xBF,0xC0,0x78,0x9F,0xC7,0xF0,0xFF,
0x7F,0x7F,0xFE,0xFD,0xE3,0xEE,0xFD,0xF3,0xE7,0xE8,0xD8,0xD8,0xD0,0xB0,0xA0,0x40,
0xF7,0xF4,0xD7,0xD9,0xFE,0xFF,0xFF,0xFF,0xBF,0xFF,0xFD,0xFF,0xBE,0xBF,0xFC,0xFC,
0xFA,0xFA,0xFF,0x7B,0xFD,0xFE,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0x8D,0x7F,0xFF,0xFF,
0xFF,0xFF,0xFF,0xF7,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7E,0xE7,0xE7,
0xF3,0x9F,0xCF,0xF7,0xFB,0xFD,0xF7,0xFE,0xFF,0xFF,0xFC,0xFB,0xF7,0xF6,0xEB,0xED,
0x7E,0xD6,0xD0,0xC0,0xD0,0xD0,0xD1,0x57,0xCF,0xC0,0xEF,0xFF,0xF7,0xCF,0x98,0xBB,
0xBD,0x7C,0x7D,0x7F,0x7F,0x78,0x0F,0xFF,0xFF,0x79,0xE7,0x8F,0xFF,0xFC,0xFE,0xC7,
0xF1,0xFF,0xFF,0x77,0xB8,0xDF,0xEF,0xF3,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xF7,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xF7,0xF7,0xFF,0xFF,0xF7,0xFF,0xFF,0xFF,0xFF,
uchar code mao_hao[]={ /*-- 文字: : --*/
/*-- Arial Rounded MT Bold12; 此字體下對應(yīng)的點陣為:寬x高=16x16 --*/
0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
uchar code num0[]={ /*-- 文字: 0 --*/ /*-- 宋體 12; 此字體下對應(yīng)的點陣為:寬 x 高=8x16 --*/ 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00 };
uchar code num1[]={ /*-- 文字: 1 --*//*-- 宋體 12; 此字體下對應(yīng)的點陣為:寬 x 高=8x16 --*/ 0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00 };
uchar code num2[]={ /*-- 文字: 2 --*/ /*-- 宋體 12; 此字體下對應(yīng)的點陣為:寬 x 高=8x16 --*/ 0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00 };
uchar code num3[]={ /*-- 文字: 3 --*/ /*-- 宋體 12; 此字體下對應(yīng)的點陣為:寬 x 高=8x16 --*/ 0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00 };
uchar code num4[]={ /*-- 文字: 4 --*/ /*-- 宋體 12; 此字體下對應(yīng)的點陣為:寬 x 高=8x16 --*/ 0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00 };
uchar code num5[]={ /*-- 文字: 5 --*/ /*-- 宋體 12; 此字體下對應(yīng)的點陣為:寬 x 高=8x16 --*/ 0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00 };
uchar code num6[]={ /*-- 文字: 6 --*/ /*-- 宋體 12; 此字體下對應(yīng)的點陣為:寬 x 高=8x16 --*/ 0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00 };
uchar code num7[]={ /*-- 文字: 7 --*/ /*-- 宋體 12; 此字體下對應(yīng)的點陣為:寬 x 高=8x16 --*/ 0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00 };
uchar code num8[]={ /*-- 文字: 8 --*/ /*-- 宋體 12; 此字體下對應(yīng)的點陣為:寬 x 高=8x16 --*/ 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00 };
uchar code num9[]={ /*-- 文字: 9 --*/ /*-- 宋體 12; 此字體下對應(yīng)的點陣為:寬 x 高=8x16 --*/ 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00 };
uchar code shi[]={
/*-- 文字: 濕 --*/
0x10,0x60,0x02,0x8C,0x00,0xFE,0x92,0x92,0x92,0x92,0x92,0x92,0xFE,0x00,0x00,0x00,
0x04,0x04,0x7E,0x01,0x44,0x48,0x50,0x7F,0x40,0x40,0x7F,0x50,0x48,0x44,0x40,0x00,
uchar code du[]={
/*-- 文字: 度 --*/
0x00,0x00,0xFC,0x24,0x24,0x24,0xFC,0x25,0x26,0x24,0xFC,0x24,0x24,0x24,0x04,0x00,
0x40,0x30,0x8F,0x80,0x84,0x4C,0x55,0x25,0x25,0x25,0x55,0x4C,0x80,0x80,0x80,0x00,
