查看: 1867|回復: 1
ATMEGA16A 按鍵數(shù)碼管
ID:587926 發(fā)表于 2019-7-24 12:26 來自觸屏版 | 顯示全部樓層 |閱讀模式
* 【編譯環(huán)境】: ICCAVR
* 【函數(shù)功能】: 按鍵K5 K6 實現(xiàn)數(shù)碼管加減1  初始值 8888
* 【晶    振】:  8M
* 【芯    片】:  ATMEGA16A
          #define uint  unsigned int
          #include <iom16v.h>
          #define Set_Bit(val, bitn)    (val |=(1<<(bitn)))
      #define Clr_Bit(val, bitn)    (val&=~(1<<(bitn)))
      #define Get_Bit(val, bitn)    (val &(1<<(bitn)) )
      uchar disbuf[4]={0,0,0,0};
      uchar  discode[10]={ 0xC0, 0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90 };  //段碼表
      uchar  disbit[4]  ={ 0xFE, 0xFD,0xFB,0xF7}; //選通值
      uchar  Key_Up;
      uchar  Key_Down;
          static uint k=8888;
//延時函數(shù)
      void delay(void)
           {uint i;
             for(i=0;i<500;i++);
//顯示函數(shù)
          void Display(void)
         {  uchar i;
            for(i=0;i<4;i++)
                         PORTB=discode[disbuf[i]];
                 PORTA=disbit[i];
                 delay();
                 PORTA=0xff;
//顯示數(shù)據(jù)處理
      void Process(uint i,uchar *disbuf)
         { disbuf[0]=i/1000;
                   i=i%1000;
                   disbuf[1]=i/100;
                   i=i%100;
                   disbuf[2]=i/10;
                   i=i%10;
                   disbuf[3]=i;
//按鍵處理子程序
      void Get_Key(void)
                     if(Get_Bit(PINA,4)==0)    //PA4 按鍵處理函數(shù)
                           Display();
                           Display();
                           Display();
                           Display();
                          while(!(Get_Bit(PINA,4)))//等待按鍵松開
                                  Display();
                                  k++;
                  if(k>9999)k=0;
                  Process(k,disbuf);
                      if(Get_Bit(PINA,5)==0)   //PA5 按鍵處理函數(shù)
                                  Display();
                                  Display();
                                  Display();
                                 while(!Get_Bit(PINA,5))  //等待按鍵松開
                                  Display();
                                   Display();
                  k--;
                                     if(k==65535)k=9999;
                      Process(k,disbuf);
         void main (void)
                           DDRA|=1<<0|1<<1|1<<2|1<<3|0<<4|0<<5;//設置PA0,PA1,PA2為輸出,PA4,PA5為輸入
                   PORTA=0x00;
               DDRB=0xFF;
               PORTB=0xFF;
               Process(k,disbuf);
                    Get_Key();
                                    Display();
ID:1 發(fā)表于 2019-7-24 14:32 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
