查看: 2266|回復: 6
我想用stc15單片機在1602上顯示占空比,程序燒到板子上,1602上沒數(shù)據(jù),串口沒錯,...
ID:480680 發(fā)表于 2019-7-23 09:55 | 顯示全部樓層 |閱讀模式
#include"15.h"
sbit lcden=P2^7;     //1602引腳
sbit lcdrw=P2^6;
sbit lcdrs=P2^5;
sbit s1=P2^0;       //按鍵
sbit s2=P2^1;
sbit s3=P2^2;
uchar zhankongbi=0x80;
uchar code table1[]="zhankongbi";
void delay(uint z);
void pwminit()                        //占空比初始化
                CMOD=0x02;
                CL=0x00;
                CH=0x00;
                PCA_PWM0=0x00;
                CCAPM0=0x42;
                CCAP0H=0xff;
                CCAP0L=0xff;
                CR=1;
void pwmshe(uchar t)//這是占空比調節(jié)函數(shù)
                CCAP0H=t;
                CCAP0L=t;
void write_com(uchar com)
        lcdrs=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar dota)
        lcdrs=1;
        P0=dota;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void initlcd()
        lcden=0;
        write_com(0x38);
        delay(5);
        write_com(0x0c); delay(5);
        write_com(0x06);delay(5);
        write_com(0x01);delay(5);
void display()
    uchar num=0;
        initlcd();
           write_com(0x80);
        for(num=0;num<11;num++)
                write_data(table1[num]);
                delay(5);
void display1()
                uint a=0,b=0,c=0;
             initlcd();
    zhankongbi=zhankongbi/256*100;
        a=zhankongbi/100;
        b=zhankongbi%100/10;
        c=zhankongbi%10;
        write_com(0x80+0x40); delay(5);
        write_data('a');
        write_com(0x80+0x41);delay(5);
        write_data('b');
        write_com(0x80+0x42);delay(5);
        write_data('c');
void keyscan()
        if(s1==0)
        {        delay(5);
                if(s1==0)
                          while(!s1);
                    zhankongbi=zhankongbi-0x0a;
                        if(zhankongbi<10)
                            zhankongbi=0x0a;
                            pwmshe(zhankongbi);
                if(s2==0)
        {        delay(5);
                if(s2==0)
                                while(!s2);
                    zhankongbi=zhankongbi=0x0a;
                        if(zhankongbi>256)
                        zhankongbi=0x80;
                            pwmshe(zhankongbi);
                if(s3==0)
              delay(5);
                if(s3==0)
                            while(!s3);
                         if(zhankongbi<20)
                         zhankongbi++;
                     zhankongbi--;
                             pwmshe(zhankongbi);
        P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
    P6M0 = 0x00;
    P6M1 = 0x00;
    P7M0 = 0x00;
    P7M1 = 0x00;
         initlcd();
    pwminit();
        display();
        display1();
         keyscan();
void delay(uint z)
        uint i,j;
        for(i=z;i>=0;i--)
                for(j=110;j>=0;j--);
ID:588220 發(fā)表于 2019-7-23 10:43 | 顯示全部樓層
建議先復位,另外檢查下硬件電路確保硬件工作正常
ID:588220 發(fā)表于 2019-7-23 10:51 | 顯示全部樓層
板子是不是ok的?建議先寫一些簡單的底層驅動測試下硬件
ID:546770 發(fā)表于 2019-7-23 12:47 | 顯示全部樓層
哇哦,頭文件就一個"15.h"這么簡單?求教這塊單片機
ID:526437 發(fā)表于 2019-7-23 19:45 | 顯示全部樓層
ID:480680 發(fā)表于 2019-7-25 09:05 | 顯示全部樓層
自己已解決;軟件可能有點問題;
以下是程序:
#include"12.h"
sbit lcden=P3^5;
sbit lcdrs=P3^7;
sbit lcdrw=P3^6;
sbit s1=P2^0;
sbit s2=P2^1;
float zhankongbi=256;
uchar code table1[]="zkb";
void display1();
void pwminit();
void keyscan();
void delay(uint z)
  uint i,j;
   for(i=z;i>0;i--)
    for(j=110;j>0;j--);
void pwminit()
                CMOD=0x04;
                                CCON=0X00;
                CL=0x00;
                CH=0x00;
//                        PCA_PWM0=0x00;
                CCAPM0=0x42;
                CCAP0H=0xff;
                CCAP0L=0xff;
                CR=1;
                CCAP0H=t;
                CCAP0L=t;
void write_com(uchar com)//        液晶寫命令函數(shù)
      lcdrs=0;
      lcdrw=0;
      P0=com;
      delay(5);
      lcden=1;
      delay(5);
      lcden=0;
void write_date(uchar date)//液晶寫數(shù)據(jù)函數(shù)
     lcdrs=1;
     lcdrw=0;
     P0=date;
     delay(5);
     lcden=1;
     delay(5);
     lcden=0;
void init()        //初始化函數(shù)
        uchar num;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);//設置顯示初始坐標
        for(num=0;num<3;num++)//顯示年月日
                        write_date(table1[num]);
                        delay(5);
        P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
        init();
        pwminit();
    display1();
        while(1) //進入主程序大循環(huán)
                  keyscan();
                          display1();
                  pwmshe(zhankongbi);
void keyscan()
                        if(s1==0)
                delay(60);
                if(s1==0)
                          while(!s1);
                    zhankongbi--;
                if(s2==0)
             delay(60);
                if(s2==0)
                                while(!s2);
                    zhankongbi++;
                        if(zhankongbi>256)
                        zhankongbi=0x80;
void display1(float m)
                float a=0,c=0;
             uchar        b=0;
                          m=zhankongbi;
         m=(float)m*100/256;
             a=m/100;
             b=(uchar)m%100/10;
             c=(uchar)m%10;
        write_com(0x84);
        write_date(a+0x30);
        write_com(0x85);
        write_date(b+0x30);
        write_com(0x86);
        write_date(c+0x30);
        write_com(0x87);
        write_date('%');
        write_com(0x83);
        write_date(':');
ID:480680 發(fā)表于 2019-7-25 09:07 | 顯示全部樓層
引腳同的原因是我拿12芯片做測試的;12和15芯片1602的讀寫,使能引腳不同
