查看: 1986|回復: 1
中穎單片機79H1612A采集不到數據是怎么回事?
ID:582708 發表于 2019-7-20 16:46 | 顯示全部樓層 |閱讀模式
本帖最后由 qiangrenliwei 于 2019-7-20 18:48 編輯
請教各位朋友,
中穎單片機79H1612A單片機AD采集不到數據是怎么回事?
下面是我的程序:
#include <SH79F1612A.H>
#include <intrins.h>
#include <config.h>
typedef unsigned char      uint8;
typedef signed   char      int8;
typedef unsigned short     uint16;
typedef signed   short     int16;
typedef unsigned long      uint32;
typedef signed   long      int32;
uint16 adval;
void delay(uint16 i)
        while(i--);
void Init_IO()
                P4M0 = 0x00;
                P4M1 = 0x04;
                P3M0 = 0x00;
                P3M1 = 0x04;
uint16 Sample_AD(uint8 ch,uint8 smdt)
         uint16 adval;
   if(smdt==0)
      ADT=Bin(00000000);
      ADT  =Bin(11101111);
   switch(ch)
      case 0:       //AN0
               ADCH=Bin(00000001);
         ADCON=Bin(10000001);
               break;
      case 1:       //AN1
               ADCH=Bin(00000010);
         ADCON=Bin(10000011);
               break;
      case 2:       //AN2
               ADCH=Bin(00000100);
         ADCON=Bin(10000101);
               break;
      case 3:       //AN3
               ADCH=Bin(00001000);
         ADCON=Bin(10000111);
               break;
      case 4:       //AN4
               ADCH=Bin(00010000);
         ADCON=Bin(10001001);
               break;
      case 5:       //AN5
               ADCH=Bin(00100000);
         ADCON=Bin(10001011);
               break;
      case 6:       //AN6
               ADCH=Bin(01000000);
         ADCON=Bin(10001101);
               break;
      case 7:       //AN7
               ADCH=Bin(10000000);
         ADCON=Bin(10001111);
               break;
      default:
               break;
   while((ADCON&Bin(01000000))==0)
      _nop_();
   adval=ADDH*4+ADDL;
   ADCON=Bin(00000000);
   return(adval);
** oˉêyÃû3Æ: main
** oˉêyÃèêö: Ö÷oˉêy
** êäèë2Îêy: ÎT
** êä3ö2Îêy: ÎT
                P4_2 = 1;
                Init_IO();
                //Init_AD();
Sample_AD(1,1);
                //GetADCH_8();
                //GetADCL_8();
                //GetADC_16();
                if(adval >1001001110)
                         P4_2 = 0;
                         P3_2 = 0;
                         delay(50000);
                   P3_2 = 1;
                   delay(50000);
                   P4_2 = 1;
ID:582708 發表于 2019-7-20 18:46 | 顯示全部樓層
問題補充:adval=ADDH*4+ADDL,這句看不明白為什么ADDH*4,這款單片機是10位的AD
