查看: 9174|回復: 7
基于51單片機的LCD12864B顯示時鐘源程序
我自己有試過然后 看論壇里沒有關于12864的顯示時鐘的有關程序 就給大家說一下仿真圖沒有做 僅僅做了實物 ,板子是用的qingxiang的板子 顯示屏是12864B
#include <reg51.h>
#include <intrins.h>
#define uint  unsigned int
/*12864端口定義*/
#define LCD_data  P0             //數據口
sbit LCD_RS  =  P3^5;            //寄存器選擇輸入
sbit LCD_RW  =  P3^6;            //液晶讀/寫控制
sbit LCD_EN  =  P3^4;            //液晶使能控制
sbit LCD_PSB =  P3^1;            //串/并方式控制
sbit wela    =  P2^6;
sbit dula    =  P2^7;
sbit K1=P3^0;
sbit K2=P3^3;
sbit K3=P3^2;
uchar code table[] =  " 2019-7-19 FIR ";
uchar code table1[] = "  00: 00: 00AM ";
uchar code table2[] = "濟南今日  晴天";
uchar code table3[] = "  無風   34-29 ";
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
uchar IRDIS[2];
uchar IRCOM[4];
int num=0,num1=0;
uchar i,t;
uchar K1num;
char s,f,m;
void key();
//unsigned char TIM[8]={0,0,':',0,0,':',0,0};
void  dataconv();
void lcd_pos(uchar X,uchar Y);  //確定顯示位置
/*  延時函數                                                       */
void delay(int ms)
    while(ms--)
      uchar i;
          for(i=0;i<250;i++)
            _nop_();
                _nop_();
                _nop_();
                _nop_();
/*檢查LCD忙狀態                                                    */
/*lcd_busy為1時,忙,等待。lcd-busy為0時,閑,可寫指令與數據。      */
bit lcd_busy()
    bit result;
    LCD_RS = 0;
    LCD_RW = 1;
    LCD_EN = 1;
    delayNOP();
    result = (bit)(P0&0x80);
    LCD_EN = 0;
    return(result);
/*寫指令數據到LCD                                                  */
/*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。                             */
void write(uchar com)
   while(lcd_busy());
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _nop_();
    _nop_();
    P0 = com;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*寫顯示數據到LCD                                                  */
/*RS=H,RW=L,E=高脈沖,D0-D7=數據。                               */
void read(uchar date)
   while(lcd_busy());
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    P0 = date;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*  LCD初始化設定                                                  */
void lcd_init()
    LCD_PSB = 1;         //并口方式
    write(0x38);      //顯示設置模式
    delay(5);
    write(0x06);      //光標設置
    delay(5);
    write(0x0C);      //顯示開,關光標
    delay(5);
    write(0x01);      //清除LCD的顯示內容
    delay(5);
          write(0x80);      //數據地址初始位
    delay(5);
        for(num=0;num<16;num++)
         read(table[num]);
                delay(20);
        write(0x90);
         read(table2[num]);
                delay(20);
        write(0x98);
         read(table3[num]);
                delay(10);
        write(0x88);
         read(table1[num]);
                delay(20);
void write_sfm(uchar add,uchar date        )
uchar shi,ge;
        shi=date/10;
        ge=date%10;
        write(0x83+add);
        read(0x30+shi);
        read(0x30+ge);
void key() //按鍵控制 光標的 左移右移加減
  if(K1==0)
          delay(5);
                if(K1==0)
                  K1num++;
                        while(!K1);
                        if(K1num==1)
                          TR0=0;
                                write(0x83+10);
                                write(0x0f);
                if(K1num==2)
                  write(0x83+8);
                  if(K1num==3)
                          write(0x83+6);
                          if(K1num==4)
                                  K1num==0;
                                        write(0x0c);
                                        TR0=1;
        if(K1num!=0)
          if(K2==0)
         delay(5);
                                if(K2==0)
                                         while(!K2);
                                        if(K1num==1)
                                           m++;
                                                 if(m==60)
                                                         m=0;
                                                 write_sfm(10,m);
                                                 write(0x83+10);
                                         if(K1num==2)
                                           f++;
                                                 if(f==60)
                                                         f=0;
                                                 write_sfm(8,f);
                                                 write(0x83+8);
                                         if(K1num==3)
                                           s++;
                                                 if(s==23)
                                                         s=0;
                                                 write_sfm(6,s);
                                                 write(0x83+6);
                                                 K1num==0;
        if(K3==0)
          delay(5);
                if(K3==0)
                 while(!K3);
                        if(K1num==1)
                          m--;
                                if(m==-1)
                                        m=59;
                                write_sfm(10,m);
                                write(0x83+10);
                        if(K1num==2)
                          f--;
                                if(f==-1)
                                        f=59;
                                write_sfm(8,f);
                                write(0x83+8);
                        if(K1num==3)
                          s--;
                                if(s==-1)
                                        s=23;
                                write_sfm(6,s);
                                write(0x83+6);
                                K1num==0;
/* 主程序        */
{                 //延時
     wela=0;
          dula=0;
         delay(10);
    lcd_init();
         TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TR0=1;
        IE = 0x82; //1001 0000 EA=1; ES=1;
          key();
void T_t0() interrupt 1 //外部中斷
        num1++;
        if(num1==2)
                num1=0;
                m++;
                if(m==60)
                  m=0;
                        f++;
                        if(f==60)
                          f=0;
                                s++;
                                if(s==24)
                                   s=0;
                                write_sfm(6,s);
                        write_sfm(8,f);
    write_sfm(10,m);
全部資料51hei下載地址:
12864顯示時鐘.zip (30.84 KB, 下載次數: 245)
收藏收藏7 分享淘帖 頂2 踩
ID:258542 發表于 2019-7-21 10:15 | 只看該作者
下載程序試一下
ID:247810 發表于 2019-7-28 10:02 | 只看該作者
謝謝分享
ID:586674 發表于 2019-8-8 18:16 | 只看該作者
下載程序試試,感謝分享
ID:78901 發表于 2019-9-5 21:44 | 只看該作者
天氣是如何做的
ID:950673 發表于 2021-7-30 09:37 | 只看該作者
用的是哪個芯片啊
ID:354309 發表于 2022-8-23 09:14 | 只看該作者
用的時間芯片是什么
ID:863362 發表于 2022-8-29 10:14 | 只看該作者
阿斯蘭 發表于 2022-8-23 09:14
用的時間芯片是什么
沒用到時間芯片,顯示的內容可以在源程序里任意修改。
