查看: 2322|回復: 0
基于51單片機的醫院病房緊急呼叫系統(無線+語音)
ID:582867 發表于 2019-7-17 19:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 杜安安 于 2019-7-17 19:26 編輯
#include < reg52.h >
#include < intrins.h >
#define uint  unsigned int
void  Ok_Menu ();
void data_chuli();
void fangyin(uchar addr);
void ISD4004_Stop();
void ISD4004_Powerdown();
//bit result  ;
uchar data chs;
sbit LCD_RS = P2^5 ;
sbit LCD_RW = P2^6 ;
sbit LCD_EN = P2^7 ;
sbit Led=P3^0;
sbit sendd=P2^4;
sbit add=P3^7;         //上翻
sbit sub=P3^6;         //下翻
sbit affirm=P3^5; //應答
uchar code  cdis1[ ] = {"         "} ;
unsigned char data  shuju_sbit[6] ={0x00,0x00,0x00,0x00,0x00,0x00} ;
uchar data shuju[][4]={  {0x00,0x00,0x00,0x00},//組號,房號(地址),次數,是否應答
                                         {0x01,0x00,0x00,0x00},
                                         {0x02,0x00,0x00,0x00},
                                         {0x03,0x00,0x00,0x00},
                                                 {0x04,0x00,0x00,0x00},
                                         {0x05,0x00,0x00,0x00},
                                         {0x06,0x00,0x00,0x00},
                                         {0x07,0x00,0x00,0x00}
flag為組號標志                     flag1         為收到信號置位           flag5用來判斷數據是否有效
flag3為 應答標志          flag2  用來判斷是否為同一個病房呼叫         flag4 用來標志收到信號
uchar  flag2=0,flag=1,flag1,flag4,flag5,Flag_ReqSend,jieshou=0;
uint flag3;
uint a=0;
uchar temp;
//語音所用的口
sbit K_luying=P3^4;
sbit K_fangyin=P3^3;
sbit K_Tingzhi=P3^1;
sbit ISD4004_SS=P1^4;          //語音
sbit ISD4004_MOSI=P1^5;
sbit ISD4004_SCLK=P1^6;
//sbit ISD4004_INT=P1^7;//  要換回來
code unsigned char table1[]={0,1,2,3,4,5,6,7,8,9,10,11}         ;
code unsigned char table[]={0x00,0x00,0x00,0x65,           //語音地址表
                            0x00,0xc9,0x01,0x2d,
                            0x01,0x91,0x01,0xf5,
                            0x02,0x59,0x02,0xbd,
                                   0x03,0x21,0x03,0x85,
                                   0x03,0xb7,0x03,0xe8,
                                    0x04,0x1a,0x04,0x4c,
                            0x04,0x7e,0x04,0xb0,
                                    0x04,0xe2,0x05,0x14,
                            0x05,0x46,0x05,0x78,
                                    0x05,0xaa,0x05,0xdc,
                            0x06,0x0e,0x06,0x40,
                                    0x06,0x72,0x06,0xa4,
                                    0x06,0xd6,0x07,0x08,
                                    0x07,0x3a,0x07,0x6c };
#define delayNOP() ; {_nop_() ;_nop_() ;_nop_() ;_nop_() ;} ;
  void delay10ms(uchar hehe)
    uint i;
        for(hehe;hehe>0;hehe--)
                for(i=1240;i>0;i--);
void delay1(int ms)
unsigned char y ;
  while(ms--)
  for(y = 0 ; y<25; y++)
   _nop_() ;
   _nop_() ;
   _nop_() ;
   _nop_() ;
/*檢查LCD忙狀態                                                   */
/*lcd_busy為1時,忙,等待。lcd-busy為0時,閑,可寫指令與數據。   */
bit lcd_busy()
   bit result ;
    LCD_RS = 0 ;
    LCD_RW = 1 ;
    LCD_EN = 1 ;
    delayNOP() ;
    result = (bit)(P0&0x80) ;
    LCD_EN = 0 ;
    return(result) ;
/*寫指令數據到LCD                                                  */
/*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。          */
void lcd_wcmd(uchar cmd)
   while(lcd_busy()) ;
    LCD_RS = 0 ;
    LCD_RW = 0 ;
    LCD_EN = 0 ;
    _nop_() ;
    _nop_() ;
    P0 = cmd ;
    delayNOP() ;
    LCD_EN = 1 ;
    delayNOP() ;
    LCD_EN = 0 ;
/*寫顯示數據到LCD                            */
/*RS=H,RW=L,E=高脈沖,D0-D7=數據。       */
void lcd_wdat(uchar dat)
   while(lcd_busy()) ;
    LCD_RS = 1 ;
    LCD_RW = 0 ;
    LCD_EN = 0 ;
    P0 = dat ;
    delayNOP() ;
    LCD_EN = 1 ;
    delayNOP() ;
    LCD_EN = 0 ;
/*  LCD初始化設定                                                  */
void lcd_init()
    delay1(15) ;
    lcd_wcmd(0x01) ;      //清除LCD的顯示內容
    lcd_wcmd(0x38) ;      //16*2顯示,5*7點陣,8位數據
    delay1(5) ;
    lcd_wcmd(0x38) ;
    delay1(5) ;
    lcd_wcmd(0x38) ;
    delay1(5) ;
    lcd_wcmd(0x0c) ;      //顯示開,關光標
    delay1(5) ;
    lcd_wcmd(0x06) ;      //移動光標
    delay1(5) ;
    delay1(5) ;
/*  設定顯示位置                                    */
void lcd_pos(uchar pos)
  lcd_wcmd(pos | 0x80) ;  //數據指針=80+地址變量
///數據位分離
void sbitseparate(uchar a,uchar b,uchar c,uchar d)
   shuju_sbit[0]=a;
   shuju_sbit[1]=b/10;                   //房號
   shuju_sbit[2]=b%10;
   shuju_sbit[3]=c/10;                        //次數
   shuju_sbit[4]=c%10;
   shuju_sbit[5]=d;
///顯示數據
  void display(flag)
           sbitseparate(shuju[flag][0],shuju[flag][1],shuju[flag][2],shuju[flag][3]);
       lcd_pos(0x03) ;
     lcd_wdat(shuju_sbit[0]+'0') ;        //組號
       lcd_pos(0x05) ;
     lcd_wdat(shuju_sbit[1]+0x30) ;        // 房號
       lcd_pos(0x06) ;
     lcd_wdat(shuju_sbit[2]+0x30) ;        //
       lcd_pos(0x08) ;
     lcd_wdat(shuju_sbit[3]+0x30) ;        //呼叫次數
           lcd_pos(0x09) ;
     lcd_wdat(shuju_sbit[4]+0x30) ;        //
       lcd_pos(0x0B) ;
     lcd_wdat(shuju_sbit[5]+0x30) ;        // 是否應答
void fasong()
  Led=0;
  P2=0x00;
  EA=0;                  //保證數據發送完
  P2=shuju[flag-1][1]&0x0f;         //要是這樣就把sendd變為0了,沒有電源就不能發送了
  sendd=1;
  delay10ms(10);//延時100ms
  sendd=0;
  EA=1;
  Led=1;
//數據初使化
void data_init()
  TCON = 0x00;
  IT0=1;    //負邊沿觸發
  IE = 0x00;
  EA=1;
  EX0=1;
  flag=1;
  Led=1;
  sendd=0;
Ok_Menu ();
   void jieshou_dat()
     uchar a,b,c,d;
         Led=0;
        temp=P1&0x0f;
    delay10ms(50);
        Led=1;
    a=(temp<<3)&0x08;        //數據位的第四位和第一位反了,第二位和第三位反了
        b=(temp<<1)&0x04;
        c=(temp>>1)&0x02;
        d=(temp>>3)&0x01;
        temp=a|b|c|d;
// INT0中斷
void int00(void) interrupt 0
                       EX0=0;
                           jieshou_dat();
                           data_chuli();                         //有信號則進行對信號的處理
                          // display(flag-1);
                       EX0=1;
                         對于有呼叫的時候對信號的處理
void data_chuli()
   uchar i,j;
         if((0x00==temp)||(0x0f==temp))                 //防干擾
                goto  abc;
                jieshou=1;
                if(0==shuju[0][0])
                  for(i=1;i<9;i++)
                    shuju[i-1][0]=shuju[i-1][0]+1;
           for(i=1;i<8;i++)                                     //i從1到7變化         temp為收到的數據  對了
                  if(shuju[i-1][1]==temp)                //判斷呼叫的地址是否與已有的地址相同 即房號  ////////////////////////////////
                          flag=i;                    //保存地址相同的數組的標號
                          flag2=1;
          if(flag2==1)                                  //有地址相同就呼叫加一
                    shuju[flag-1][2]=shuju[flag-1][2]+1;           //呼叫次數加1
                        shuju[flag-1][3]=0;                     //對應答進行清零
                        flag2=0;        //標志清零
           else                                                //如果房號沒有,數據往后移
                          for(i=8;i>1;i--)                            //數據轉移
                            for(j=1;j<4;j++)
                                      shuju[i-1][j]=shuju[i-2][j];
                //         for(i=1;i<4;i++)                             //測試用的移入數據,實際用時是傳過來的數據(房號)
                            //  shuju[1][1]=temp;                        // 存入房號
                  flag=1;                        //當前顯示呼叫的病房的信息
                          shuju[0][1]=temp;            //存入房號          /////////////////////////////////////////////////
                          shuju[0][2]=0x01;                 //呼叫次數存入1           不用對應答清零,初始化時就是0x00了
           abc:        ;
//         語音部分的程序
//函數名稱:void delay25ms()
//函數功能:延遲25ms
//日期:2007.03.31
void delay25ms()
    unsigned int i;
    for(i=0;i<=5000;i++);
//函數名稱:void ISD4004_ISD4004_Send(unsigned char m)
//函數功能:給ISD4004送命令
//日期:2007.03.31
void ISD4004_Send(unsigned char m)
    unsigned char i,j;
    for(i=0;i<8;i++)
        ISD4004_SCLK = 0;
        for(j=0;j<5;j++);
        if(m&0x01)
            ISD4004_MOSI=1;
            ISD4004_MOSI=0;
                ISD4004_SCLK=1;
        for(j=0;j<5;j++);
        m=m>>1;
//函數名稱:void ISD4004_Powerup()
//函數功能:ISD4004上電
//日期:2007.03.31
    ISD4004_SS=0;                        //開片選
    ISD4004_Send(0x20);                  //上電:等待TPUD后器件可以工作
    delay25ms();
    ISD4004_SS=1;                        //關片選
//函數名稱:void ISD4004_Stop()
//函數功能:ISD4004停止
//日期:2007.03.31
void ISD4004_Stop()
    ISD4004_SS=0;
    ISD4004_Send(0x30);                //停止當前操作
    ISD4004_SS=1;
//函數名稱:void ISD4004_Powerdown()
//函數功能:下電  停止并掉電
//日期:2007.03.31
    ISD4004_SS=0;
    ISD4004_Send(0x10);
    ISD4004_SS=1;
//函數名稱:void ISD4004_Play(unsigned char addr_h,unsigned char addr_l)
//函數功能:放音
//日期:2007.03.31
    ISD4004_SS=0;
    ISD4004_Send(addr_l);
    ISD4004_Send(addr_h);
    ISD4004_Send(0xe0);           //從指定地址開始放音。
    ISD4004_SS=1;
    ISD4004_SS=0;
    ISD4004_Send(0xf0);          //從當前地址開始放音(直至EOM或OVF)
    ISD4004_SS=1;
//函數功能:錄音
void ISD4004_Rec(unsigned char addr_h,unsigned char addr_l)
    ISD4004_SS=0;
    ISD4004_Send(addr_l);       //傳送地址
    ISD4004_Send(0xa0);         //從指定地址開始錄音。
    ISD4004_SS=1;
    ISD4004_SS=0;
    ISD4004_Send(0xb0);         //從當前地址開始錄音(直至OVF或停止)
    ISD4004_SS=1;
//函數名稱:void fangyin()
//函數功能:語音 addr為地址
//日期:2007.03.31
    uchar a;
        Led=0;
    ISD4004_Powerup();
    delay25ms();
    a = addr * 2;
    ISD4004_Play(table[a],table[a+1]);
        Led=1;
//函數名稱:void luyin()
//函數功能:語音 addr為地址
//日期:2007.03.31
void luyin(uchar addr)
    uchar a;
    ISD4004_Powerup();     //上電
    delay25ms();
        delay25ms();
    a = addr * 2;          //對地址進行處理
    ISD4004_Rec(table[a],table[a+1]);
  鍵盤處理及相應的數據處理
void keyscan()
    if(add==0)        //上翻
           delay1(5);
                   while(!add) ;
                         flag++;
                         if(flag==9)
                          flag=1;
         if(sub==0)                //下翻
           delay1(5);
                        while(!sub) ;
                        flag--;
                        if(flag==0)
                          flag=8;
         if(affirm==0)         //應答
           delay1(5);
           while(!affirm);
                 flag3++;
        //         shuju[flag-1][3]=flag3%2;
           shuju[flag-1][3]=1;
                 fasong();
             if(K_fangyin==0)               //放音
                   delay1(5);
                   if(K_fangyin==0)
                    {          P1=0xff;
                        fangyin(a);
                           delay25ms();
                           delay25ms();
                if(K_luying==0)                        //錄音
                         delay1(5);
                        if(K_luying==0)
                          {          P1=0xff;
                                 ISD4004_Powerup();
                                 delay25ms();
                             luyin(a);
                 if(K_Tingzhi==0)
                      delay1(5);
                   if(K_Tingzhi==0)
                      {     P1=0xff;
                              ISD4004_Stop();
                                  delay25ms();
void  Ok_Menu ()
    uchar  m ;
    lcd_init() ;                //初始化LCD
    lcd_pos(0) ;                //設置顯示位置為第一行的第1個字符
     m = 0 ;
    while(cdis1[m] != '\0')
     {                         //顯示字符
       lcd_wdat(cdis1[m]) ;
       m++ ;
/* 主函數     */
   data_init();
   keyscan();
   if(1==jieshou)
                EA=0;  //防止中斷影響語音
                     Led=0;                       //亮燈
                        fangyin(a);
                           delay25ms();
                           delay25ms();
                                 EA=1;
                                 jieshou=0;
   display(flag-1);
二、從機程序:
#include<AT89X52.H>
sbit sing=P2^7;
sbit key=P2^5;
sbit sendd=P1^4;//電源控制
sbit led=P2^6;
uchar temp=0x03;        //本機地址
uchar th[]={0xf8,0xf9,0xfa,0xfa,0xfb,0xfb,0xfc,
            0xfc,0xfc,0xfd,0xfd,0xfd,0xfd,0xfe,
            0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xff};
uchar tl[]={0x8c,0x5b,0x15,0x67,0x04,0x90,0x0c,   //低音1-7
            0x44,0xac,0x09,0x34,0x82,0xc8,0x06,  //中音1-7
            0x22,0x56,0x85,0x9a,0xc1,0xe4,0x03}; // 高音1-7
uchar  i,timer;
uint a,sum=0;
uchar code song[]={10,12,                                           //2
                    13,13,13,13,13,13,13,15,14,13,12,10,12,  //16    13,13,13,
                    10,10,10,10,10,10,10,10,10,6,8,          //14  10,10,10,
                    9,9,9,9,9,9,9,10,9,8,9,8,7,                 //16    9,9,9,
                    6,6,6,6,6,6,6,6,6,6,          //14     6,6,6,6,
                    6,6,10,10,10,10,9,8,7,7,8,8,7,7,6,5,             //16
                    8,8,8,8,6,8,9,9,9,9,10,11,10,9,              //16  8,8,
                    10,10,10,10,10,10,10,10,10,12,       //14   10,10,10,10,
                    13,13,13,13,12,10,9,9,9,9,8,9,         //16  9,9,13,13,   4*30+2
                    10,10,10,10,9,10,6,6,6,6,6,          //16  10,10,6,6,6,
                    7,7,7,6,5,5,7,7,7,7,5,3,8,8,7,7,             //16
                                         //14 6,6,6,6,6,6,6,6,6,6,6,6,6,6,
                    6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,                 //16
                    6,6,13,13,13,13,12,12,10,12,10,12,13,13,13,13,   //16
                    12,12,9,9,9,9,10,12,10,9,10,10,10,10,      //16   10,10,
                    8,6,6,6,6,6,6,6,10,9,10,10,10,10,12,13,           //16
                    10,9,10,10,10,10,10,10,10,10,10,10,    //16  10,10,10,10,
                    12,12,9,9,9,9,10,12,10,9,10,10,10,10,         //16  10,10,   160-2
                    10,9,10,10,10,10,10,10,10,                //12   10,10,10,
                    8,6,6,6,6,6,6,6,8,6,6,6,6,6,6,6,                    //16
                    10,9,10,10,10,10,10,9,10,10,10,10,      //16  110,10,0,10,
                    10,10,12,12,12,12,5,5,                            //8
                    6,6,6,6,6,6,6,6              //12    ,6,6,6,6 160-32
                    };//歌譜       408-64
    uint i;
  void send()
    P0=0x00;
          led=0;
        sendd=1;
    P0=temp&0x0f;
    delay10ms(10);//延時50ms
    sendd=0;
    led=1;
void dat_init()
    sing=1;          //變量初始化
    timer=0;
    i=1;
    a=0;
    sendd=0;
    TH1=(65536-50000)/256;   //定時器1初始化
    TL1=(65536-50000)%256;
        TCON = 0x00;
    TMOD=0x11;  //兩個定時器都工作在方式1
    IT0=1;    //負邊沿觸發
    EA=1;    //開總中斷
    ET0=1;   //定時器允許
    ET1=1;
        EX0=1;
void main()           //主函數
    dat_init();
    {           sendd=0;
                 if(0==key)
                  {         delay10ms(5);
                     while(!key);
                     send();
void time1() interrupt  1     //定時器0中斷作音頻控制器
    TH0=th[i-1];
    TL0=tl[i-1];
    sing=!sing;
        sum++;
        if(15000==sum)
                   TR0=0;   //關定時器中斷   #include < reg52.h >
void  Ok_Menu ();
void data_chuli();
//bit result  ;
uchar data chs;
sbit Led=P3^0;
sbit sendd=P2^4;
sbit add=P3^7;         //上翻
sbit sub=P3^6;         //下翻
uint flag3;
uint a=0;
uchar temp;
//語音所用的口
sbit K_luying=P3^4;
    uint i;
void delay1(int ms)
unsigned char y ;
  while(ms--)
   _nop_() ;
   _nop_() ;
   _nop_() ;
   _nop_() ;
/*檢查LCD忙狀態                                                   */
bit lcd_busy()
   bit result ;
    LCD_RS = 0 ;
    LCD_RW = 1 ;
    LCD_EN = 1 ;
    delayNOP() ;
    LCD_EN = 0 ;
    return(result) ;
/*寫指令數據到LCD                                                  */
   while(lcd_busy()) ;
    LCD_RS = 0 ;
    LCD_RW = 0 ;
    LCD_EN = 0 ;
    _nop_() ;
    _nop_() ;
    P0 = cmd ;
    delayNOP() ;
    LCD_EN = 1 ;
    delayNOP() ;
    LCD_EN = 0 ;
/*寫顯示數據到LCD                            */
   while(lcd_busy()) ;
    LCD_RS = 1 ;
    LCD_RW = 0 ;
    LCD_EN = 0 ;
    P0 = dat ;
    delayNOP() ;
    LCD_EN = 1 ;
    delayNOP() ;
    LCD_EN = 0 ;
/*  LCD初始化設定                                                  */
void lcd_init()
    delay1(15) ;
    delay1(5) ;
    lcd_wcmd(0x38) ;
    delay1(5) ;
    lcd_wcmd(0x38) ;
    delay1(5) ;
    delay1(5) ;
    delay1(5) ;
    delay1(5) ;
/*  設定顯示位置                                    */
///數據位分離
   shuju_sbit[0]=a;
   shuju_sbit[2]=b%10;
   shuju_sbit[4]=c%10;
   shuju_sbit[5]=d;
///顯示數據
  void display(flag)
       lcd_pos(0x03) ;
       lcd_pos(0x05) ;
       lcd_pos(0x06) ;
       lcd_pos(0x08) ;
           lcd_pos(0x09) ;
       lcd_pos(0x0B) ;
void fasong()
  Led=0;
  P2=0x00;
  EA=0;                  //保證數據發送完
  sendd=1;
  sendd=0;
  EA=1;
  Led=1;
//數據初使化
void data_init()
  TCON = 0x00;
  IT0=1;    //負邊沿觸發
  IE = 0x00;
  EA=1;
  EX0=1;
  flag=1;
  Led=1;
  sendd=0;
Ok_Menu ();
   void jieshou_dat()
     uchar a,b,c,d;
         Led=0;
        temp=P1&0x0f;
    delay10ms(50);
        Led=1;
        b=(temp<<1)&0x04;
        c=(temp>>1)&0x02;
        d=(temp>>3)&0x01;
        temp=a|b|c|d;
// INT0中斷
                       EX0=0;
                           jieshou_dat();
                          // display(flag-1);
                       EX0=1;
                         對于有呼叫的時候對信號的處理
void data_chuli()
   uchar i,j;
                goto  abc;
                jieshou=1;
                if(0==shuju[0][0])
                  for(i=1;i<9;i++)
                          flag2=1;
                        flag2=0;        //標志清零
           else                                                //如果房號沒有,數據往后移
                            for(j=1;j<4;j++)
           abc:        ;
//         語音部分的程序
//函數功能:延遲25ms
//日期:2007.03.31
void delay25ms()
    unsigned int i;
//函數功能:給ISD4004送命令
//日期:2007.03.31
    unsigned char i,j;
    for(i=0;i<8;i++)
        ISD4004_SCLK = 0;
        for(j=0;j<5;j++);
        if(m&0x01)
            ISD4004_MOSI=1;
            ISD4004_MOSI=0;
                ISD4004_SCLK=1;
        for(j=0;j<5;j++);
        m=m>>1;
//函數功能:ISD4004上電
//日期:2007.03.31
    ISD4004_SS=0;                        //開片選
    delay25ms();
    ISD4004_SS=1;                        //關片選
//函數功能:ISD4004停止
//日期:2007.03.31
void ISD4004_Stop()
    ISD4004_SS=0;
    ISD4004_SS=1;
//函數功能:下電  停止并掉電
//日期:2007.03.31
    ISD4004_SS=0;
    ISD4004_Send(0x10);
    ISD4004_SS=1;
//函數功能:放音
//日期:2007.03.31
    ISD4004_SS=0;
    ISD4004_SS=1;
    ISD4004_SS=0;
    ISD4004_SS=1;
//函數功能:錄音
    ISD4004_SS=0;
    ISD4004_SS=1;
    ISD4004_SS=0;
    ISD4004_SS=1;
//函數功能:語音 addr為地址
//日期:2007.03.31
    uchar a;
        Led=0;
    ISD4004_Powerup();
    delay25ms();
    a = addr * 2;
        Led=1;
//函數名稱:void luyin()
//函數功能:語音 addr為地址
//日期:2007.03.31
    uchar a;
    delay25ms();
        delay25ms();
  鍵盤處理及相應的數據處理
void keyscan()
    if(add==0)        //上翻
           delay1(5);
                   while(!add) ;
                         flag++;
                         if(flag==9)
                          flag=1;
         if(sub==0)                //下翻
           delay1(5);
                        while(!sub) ;
                        flag--;
                        if(flag==0)
                          flag=8;
         if(affirm==0)         //應答
           delay1(5);
           while(!affirm);
                 flag3++;
           shuju[flag-1][3]=1;
                 fasong();
                   delay1(5);
                   if(K_fangyin==0)
                    {          P1=0xff;
                        fangyin(a);
                           delay25ms();
                           delay25ms();
                         delay1(5);
                        if(K_luying==0)
                          {          P1=0xff;
                                 ISD4004_Powerup();
                                 delay25ms();
                             luyin(a);
                 if(K_Tingzhi==0)
                      delay1(5);
                   if(K_Tingzhi==0)
                      {     P1=0xff;
                              ISD4004_Stop();
                                  delay25ms();
void  Ok_Menu ()
    uchar  m ;
     m = 0 ;
     {                         //顯示字符
       m++ ;
/* 主函數     */
   data_init();
   keyscan();
   if(1==jieshou)
                EA=0;  //防止中斷影響語音
                     Led=0;                       //亮燈
                        fangyin(a);
                           delay25ms();
                           delay25ms();
                                 EA=1;
                                 jieshou=0;
   display(flag-1);
二、從機程序:
#include<AT89X52.H>
sbit sing=P2^7;
sbit key=P2^5;
sbit led=P2^6;
uchar  i,timer;
uint a,sum=0;
                    };//歌譜       408-64
    uint i;
  void send()
    P0=0x00;
          led=0;
        sendd=1;
    P0=temp&0x0f;
    sendd=0;
    led=1;
void dat_init()
    sing=1;          //變量初始化
    timer=0;
    i=1;
    a=0;
    sendd=0;
        TCON = 0x00;
    IT0=1;    //負邊沿觸發
    EA=1;    //開總中斷
    ET0=1;   //定時器允許
    ET1=1;
        EX0=1;
基于51單片機的醫院病房緊急呼叫系統(無線 語音).zip
511.33 KB, 下載次數: 45, 下載積分: 黑幣 -5
