查看: 2821|回復(fù): 5
有關(guān)C語言軟件漢字字庫建立(不允許輸入不完整的類型)
ID:443291 發(fā)表于 2019-7-17 14:43 | 顯示全部樓層 |閱讀模式
錯(cuò)誤為:incomplete type is not allowed struct typeFNT_HZ32 codeHZ_32p[]={
結(jié)構(gòu)體定義為:
struct typFNT_HZ32
        unsigned char Index[3];
        unsigned char Msk[128];
字庫頭文件如下:
#ifndef __ZK_H
#define __ZK_H
struct typFNT_HZ32 codeHZ_32[]={
"ÖØ",0x08,0x02,0x08,0x02,0x28,0x0A,0x2B,0xEA,0x2A,0xAA,0x2A,0xAA,0x2A,0xAA,0x3F,0xFE,
0x4A,0xAA,0x4A,0xAA,0x4A,0xAA,0xCB,0xEA,0x48,0x0A,0x08,0x02,0x08,0x02,0x00,0x00,/*0*/
"Çì",0x00,0x02,0x00,0x0C,0x3F,0xF0,0x20,0x01,0x21,0x02,0x21,0x04,0x21,0x18,0xA1,0x60,
0x6F,0x80,0x21,0x60,0x21,0x18,0x21,0x04,0x21,0x02,0x21,0x01,0x20,0x01,0x00,0x00,/*1*/
#endif
求大佬解惑,謝謝!
ID:215444 發(fā)表于 2019-7-17 17:46 | 顯示全部樓層
1. unsigned char Index[3];這個(gè)是中文的肯定不行
2. struct typFNT_HZ32
};你這種寫法,你必須保證Msk里面有128個(gè)字節(jié),因?yàn)榈刂肥沁B續(xù)的,你不能在unsigned char Msk[128]又接收16進(jìn)制,又接受字符串這個(gè)是個(gè)錯(cuò)
3.struct typFNT_HZ32 codeHZ_32[],應(yīng)該寫成struct typFNT_HZ32 codeHZ_32[2],不寫不會報(bào)錯(cuò)但應(yīng)該寫
4.正確如下:
#include <stdio.h>
struct typFNT_HZ32
        unsigned char Msk[256];
struct typFNT_HZ32 codeHZ_32[2]=
        {"12",0x08,0x02,0x08,0x02,0x28,0x0A,0x2B,0xEA,0x2A,0xAA,0x2A,0xAA,0x2A,0xAA,0x3F,0xFE,
        {"21",0x08,0x02,0x08,0x02,0x28,0x0A,0x2B,0xEA,0x2A,0xAA,0x2A,0xAA,0x2A,0xAA,0x3F,0xFE,
int main(void)
        printf("%s\r\n",codeHZ_32[0].Index);
        printf("%x\r\n",codeHZ_32[0].Msk[0]);
        printf("%s\r\n",codeHZ_32[1].Index);
        printf("%x\r\n",codeHZ_32[1].Msk[0]);
ID:443291 發(fā)表于 2019-7-18 09:05 | 顯示全部樓層
k455619 發(fā)表于 2019-7-17 17:46
謝謝,我試試啊
ID:443291 發(fā)表于 2019-7-18 09:43 | 顯示全部樓層
提示:expected a “;”typedef unsigned int size_t;是咋回事啊
ID:123289 發(fā)表于 2019-7-18 17:28 | 顯示全部樓層
1、庫長什么樣子?(放多少個(gè)字,如何排列)
2、一個(gè)字如何表達(dá)?(用多少個(gè)點(diǎn)?多少行?多少列?)
3、如何用內(nèi)存來表達(dá)漢字?(字、字節(jié)……)
以上問題你弄清楚后,問題就解決了。
ID:443291 發(fā)表于 2019-7-19 08:45 | 顯示全部樓層
yzwzfyz 發(fā)表于 2019-7-18 17:28
3、 ...
好的,謝謝
