查看: 4524|回復: 4
單片機串口和定時器0沖突了怎么辦?
ID:584919 發表于 2019-7-16 10:33 | 顯示全部樓層 |閱讀模式
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include <stdio.h>
  4. #define uint unsigned int
  5. #define uchar unsigned char
  6. sbit up = P1^0;
  7. sbit down = P1^1;
  8. sbit thousand = P2^0;    //數碼管com與顯示數組
  9. sbit hundred = P2^1;
  10. sbit tan = P2^2;
  11. sbit one = P2^3;
  12. uchar table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  13. uint frequency;    //電機上下的次數,上升算一次,下降算一次
  14. uint num = 0;    //定時器計數
  15. void putin(uchar c)    ;     //串口輸出
  16. void ddelay(uint z);     //設置一秒
  17. void show(uint z);         //數碼管顯示數字
  18. void main()
  19. {
  20.     uint q = 0;
  21.     frequency = 0;
  22.     up = 0;
  23.     down = 1;
  24.     TMOD = 0x21;    //定時器1方式2  定時器0方式1
  25.     TH0  = (65536-45872)/256; //裝初值11.0592M晶振定時50ms數為45872
  26.     TL0  = (65536-45872)%256;
  27.     TH1  = 0xf4;    //裝載初值
  28.     TL1  = 0xf4;
  29.
  30.     SCON = 0x50;    //串口方式1
  31.     PCON = 0x00;    //不倍增
  32.
  33.     EA     = 1;        //打開全局中斷
  34.     ES     = 1;        //打開串口中斷
  35.     ET0  = 1;         //打開定時器0中斷
  36.     TR0  = 1;        //打開定時器0,開始計時
  37.     TR1  = 1;        //打開定時器1,用于串口通信
  38.     while(1)
  39.     {
  40.         if(num == 20) //如果到了20次,說明1秒時間
  41.         {
  42.             q++;
  43.             num=0;
  44.
  45.             if(q == 3) //每3秒串口發送數據
  46.             {
  47.                 up = ~up;        //指示燈
  48.                 down = ~down;
  49.                 frequency++;
  50.                 q = 0;            //重置時間
  51.                 putin(0xff);
  52.             }
  53.         }
  54.         putin(0xfe);
  55.         show(frequency);
  56.     }
  57. }
  58. void ddelay(uint z)  //設置一秒
  59. {
  60.     unsigned char h, i, j, k, l;
  61.     for (l = z; l > 0; l--)
  62.     for (h = 5; h > 0; h--)
  63.     for (i = 4; i > 0; i--)
  64.     for (j = 116; j > 0; j--)
  65.     for (k = 214; k > 0; k--);
  66. }
  67. void putin(uchar c)        //串口輸出
  68. {
  69.      SBUF = c;
  70.     while(TI == 0);
  71.     TI = 0;
  72. }
  73. void show(uint z) //數碼管顯示數字
  74. {
  75.     uchar i,j,k,l;
  76.     i = z/1000;
  77.     j = (z%1000)/100;
  78.     k = (z%100)/10;
  79.     l = z%10;
  80.
  81.     P0 = 0xff;
  82.     P0 = table[i];
  83.     thousand = 0;
  84.     thousand = 1;
  85.
  86.     P0 = 0xff;
  87.     P0 = table[j];
  88.     hundred  = 0;
  89.     hundred  = 1;
  90.
  91.     P0 = 0xff;
  92.     P0 = table[k];
  93.     tan = 0;
  94.     tan = 1;
  95.
  96.     P0 = 0xff;
  97.     P0 = table[l];
  98.     one = 0;
  99.     one = 1;
  100. }
  101. void T0_time()interrupt 1    //定時器0中斷
  102. {
  103.     TH0=(65536-45872)/256; //重新裝載初值
  104.     TL0=(65536-45872)%256;
  105.     num++;
  106. }
ID:123289 發表于 2019-7-16 13:41 | 顯示全部樓層
T0中斷優串口中斷,串口中斷時間間隔是一個字節的串轉并時間,相對來說是較長的。只有T0的中斷服務程序運行時間,小于串口的“一個字節的串轉并時間”,串口是不會丟數據的。
解決的方案是:
兩種中斷的服務程序盡可能用時少。
ID:7485 發表于 2019-7-16 17:40 | 顯示全部樓層
串口別用循環等待,也用中斷方式。如果一個字節還沒發送或接收完,這時產生了定時器中斷,有可能會影響到串口發送和接收。需要根據需要設置中斷優先權。
11.0592的晶振的初裝值不對啊應該是65536-46080    就是(11.0592/12)*50000=46080
ID:585414 發表于 2019-7-16 21:59 | 顯示全部樓層
可以在進入串口的子程里面把總中斷給關了,快出去了再開,被定時器打斷會出好多亂碼
ID:123289 發表于 2019-7-17 10:43 | 顯示全部樓層
地板的方式是錯誤的,沙發OK。
