查看: 1965|回復(fù): 1
51單片機(jī) 簡(jiǎn)單計(jì)算器
代碼:
#include <reg51.h>
#include <stdio.h>
unsigned char table[]={0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90};
unsigned char pos[]={0x00, 0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x01};
uint num[10];
uint cnt,flag,num1,num2,op,st;
unsigned long  res;
uint col,row;
/*--------------?óê±10ms×ó3ìDò---------*/
void delay10ms(void)
unsigned int TempCyc = 5552*2;
  while(TempCyc--);
void update()
   cnt = 1;
   num[cnt] = res % 10;
   for (;;)
      if (res>10)
  res = res/10;
  cnt++;
  break;
   st = 1;
void delay(unsigned int k)
   unsigned int j;
   for (j=0; j<k; j++)
void main(void)
    uchar keyval;
    uint i;
    cnt = 0;
    flag = 0;
    num1 = 0;
    num2 = 0;
    op = 0;
    st = 0;
    for (;;)
       P1 = 0xf0;
       keyval = 0xf0;
       if ((P1&0xf0) != 0xf0)
   if (st != 0)
      st = 0;
      cnt = 0;
   keyval = P1^0xf0;
   switch (keyval)    //col
      case (0x10):
  col = 1;
  break;
      case (0x20):
  col = 2;
  break;
      case (0x40):
  col = 3;
  break;
      case (0x80):
  col = 4;
         break;
   delay10ms();
   P1 = 0x0f;
   keyval = P1^0x0f;
   switch (keyval)
      case (0x01):
  row = 1;
  break;
      case (0x02):
  row = 2;
  break;
      case (0x04):
  row = 3;
  break;
      case (0x08):
  row = 4;
         break;
   if ((col<4 && row<4))  //1~9
      cnt++;
      if (flag == 0)
  num1 = num1*10 + 9 - 3*row + col;
  num[cnt] = 9 - 3*row + col;
  num2 = num2*10 + 9 - 3*row + col;
   if (row == 4 && col == 1) //0
      if (cnt!=0)
  cnt++;
      if (flag == 0)
  num1 = num1*10;
  if (cnt != 0)
     num[cnt] = 0;
  num2 = num2*10;
  if (cnt != 0)
     num[cnt] = 0;
   if (row == 4 && col == 2) //C
      cnt = 0;
      flag = 0;
      num1 = 0;
      num2 = 0;
      op = 0;
   if (col == 4)  //option
      flag = 1;
      cnt = 0;
      op = row;
   if (row == 4 && col == 3)     //=
      switch (op)
  case (1):
     res = num1+num2;
     update();
     break;
  case (2):
     res = num1-num2;
     update();
     break;
  case (3):
     res = num1*num2;
     update();
     break;
  case (4):
     res = (num1*10/num2+5)/10;
     update();
     break;
      flag = 0;
      num1 = 0;
      num2 = 0;
      op = 0;
  P1 = 0xf0;
  while((P1&0xf0)!=0xf0);
       P2 = 0x00;
       for (i = 1; i <=cnt; i++)
   P2 = pos[i];
   if (st == 0)
      P0 = table[num[cnt-i+1]];
      P0 = table[num[i]];
   delay(300);
   while (1)
原理圖
原理圖
ID:543557 發(fā)表于 2019-7-21 11:19 | 只看該作者
正好需要,謝謝分享
