查看: 1602|回復: 1
用c8051f120單片機點亮LCD 為啥不能顯示
ID:511588 發表于 2019-7-14 15:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我編的程序 用c8051f120點亮LCD 為啥不能顯示呢,以下是我的程序
#include <C8051F120.H>
unsigned long x;                 //"wwwxhlcomcn"
unsigned char xdata Netdata[16]={0x77,0x77,0x77,0x2e,0x78,0x68,0x6c,0x2e,0x63,0x6f,
                                0x6d,0x2e,0x63,0x6e};
                                 //"  BT F020 V1.0  "
unsigned char xdata NCDdata[17]={0x20,0x20,0x42,0x54,0x20,0x46,0x30,0x32,0x30,0x20,
                                 0x56,0x31,0x2e,0x30,0x20,0x20};
unsigned char *lcdpoint;
unsigned char lcd_data_count;
void SYSCLK_Init (void);
void PORT_Init (void);
void LCD_Init(void);
void main (void)
        static unsigned char data1;
    WDTCN = 0xde;
    WDTCN = 0xad;
    SYSCLK_Init ();
    PORT_Init ();
         while(1){
                LCD_Init();
            P2  = 0xA0;
            for(x=0;x<5000;x++);
            lcdpoint=&NCDdata;
            for(lcd_data_count=14;lcd_data_count>0;lcd_data_count--
                    data1=*lcdpoint;
                    P3 = data1;
                        P2 = 0X20;
                P2 = 0XA0;
                lcdpoint++;
                P2 = 0X80;
                   P3 = 0xc0;
                   P2 = 0x00;
                   P2 = 0x80;
                   for(x=0;x<1000;x++);
            lcdpoint=&Netdata;
                    data1=*lcdpoint;
                    P3 = data1;
        //        P2 = 0x20;
        //                P2 = 0xA0;
                    P2 = 0xA0;
            P2 = 0x20;
                lcdpoint++;
//   int i;                              // delay counter
//   OSCXCN = 0x67;                      // start external oscillator with
//                                       // 22.1184MHz crystal
//   for (i=0; i < 256; i++) ;           // Wait for osc. to start up
//   while (!(OSCXCN & 0x80)) ;          // Wait for crystal osc. to settle
//   OSCICN = 0x88;
  OSCICN = 0x05;
   SFRPAGE   = CONFIG_PAGE;
   XBR0     = 0x00;                       // ûóDÑ¡Ôñêy×Öíaéè
   XBR2     = 0x40;
   P2MDOUT  = 0xe0;                       // P2¿úéèÎaíÆíì·½ê½
void LCD_Init(void)
   P2 = 0X80;
   for(x=0;x<50000;x++);
   //P7 = 0x30;                                /*ò»DDÏÔê¾*/
   P3 = 0x38;                                /*á½DDÏÔê¾*/
   P2 = 0X00;//0x08;
   P2 = 0X80;//0x09;
   P3 = 0x0e;
   P2 = 0x00;
   P2 = 0x80;
   P3=  0x06;
   P2 = 0x00;
   P2 = 0x80;
   P3 = 0x01;
   P2 = 0x00;
   P2 = 0x80;
ID:511588 發表于 2019-7-19 14:57 | 只看該作者
已解決
